Question about Siemens Efficient Networks SpeedStream SS1020 Network Adapter
RDE20.1 fault code flashing 5.0 and 65.0
Hi
I have a Siemnes RDE20.1 theromstat controlling a floor probe for under floor heating, it first start flashing a code 5.0 and then went to 65.0, I try to reset it but that does'nt work, what do the codes mean and how do I fix it
Hamish
Whirlpool adp8966
Open heat circuit control does not sense a temperature rise during the heating phase four parts comprise the heat circuit the controller the thermistor the hi limit thermostat and the heating element unit designed to shut down on this fault
Aug 24, 2014 | Whirlpool Dishwashers
Tip
Broiling and baking element in my electric oven are not heating.
Hi.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in series on the circuit from electroning oven control to elements. The probe will control both baking and broiling element, opening the circuit when limit temperature is reached.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
Regards.
on Mar 03, 2010 | Whirlpool RBS275PD Electric Single Oven
P-1 code is flashing on temperature display
P1 is almost always a fault on the sensing (control) probe. Check it's end is not wet or covered in thick ice, and check the connections at the controller. If you can, change the probe connections on the controller temporarily. If P2 then shows it proves the probe is faulty. If P1 still shows, it proves the controller is at fault.
Apr 20, 2012 | True 72 cu. ft. / 2039 liter Commercial...
Thermador Built in oven scd302 not heating upper oven, lower oven fine. Heating element not glowing red as the oven below it does.
Hi.
Problem is usually either temperature probe or heating element.
Grab a multimeter and set it on impedance (Ohms).
Remove first temperature probe and then heating element.
If either probe or element is reading open (ohms infinity), then replace the part.
If both probe and elements are not open, then the problem is either wiring or oven electronic control. The most common fault resulting in no heat is the temperature sensor located inside the oven cavity.
Regards.
Ginko
May 31, 2011 | Thermador SECD302BPSS Electric Double Oven
Oven has stopped heating up
Hi.
This oven should have two elements.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Baumatic B180 Electric Single Oven
Neither the oven or broil element comes on. No error code appears, any thoughts?
Hi.
Regards.
Mar 02, 2010 | KitchenAid Ovens
The car keeps coming up a code 23 on a 1999 chrysler 300 for the
Code 23= Blend door feedback control
On cars with automatic climate control: To enter diagnostic mode, set the temperature to 75F, press the the off button. Press Floor, Defrost\Floor, Front Defrost simutaneously for 3 seconds until the temperature display begins to flash.
On cars without automatic climate control, set the blower to any speed, turn the temperature control in between warm and cold. Press Floor, Defrost\Floor, and Front Defrost. All codes will flash via the Front Defrost button.
When the test is over all fault codes will be displayed (on cars without automatic climate control, they will be blinked out on the Front Defrost button).
Code Action
23 Blend door feedback control
24 ATC mode door feedback failure
25 Ambient temperture sensor failure
26 ATC in-car sensor
27 Sun sensor failure
31 ATC recirculate door stall failure
32 ATC blend door failure
33 ATC mode door stall failure
34 Engine temperture sense failure
35 Evap temperature sense failure
36 ATC head command failure
Mar 23, 2009 | 1999 Chrysler 300M
Hobart lx 40 - problem D 1
Does it show a wrench icon and P1?
error codes are p 1to 3 for probe errors, or E1 to 7 for error codes.
P1 is the probe on the wash tank. It's a thermistor with two black wires to a white connector. There is another on the booster front (P2) and a 3rd on the rear airgap, (p3). You could try exchanging 1 and 3 to see if the fault changes too. You have to drain the booster to swap P2. If it can't determine the wash tank temp, it won't know to control the heat and shows the error.
Mar 20, 2009 | Hobart 25 in. LXIH-4 Built-in Dishwasher
Whirlpool Range Error code F1 F3
Unplug the range.
Remove the rear panel to access the temp probe.
Unplug the temp probe and test for 1100 ohms.
Test the temp probe to ground also.
Sometimes the connectors are bad.and must be direct wired.
Unplug and re-plug the ribbon connector to the ERC.
F-1 is a connection problem since you have a new control.
Mar 14, 2009 | Kitchen Ranges
My stove is a Ge Profile from 1998- when I turn on the oven F3 flashes- and shuts off-
Every fault code I have found for GE model ranges says this fault code is an oven sensor error. The oven sensor is a small probe that sticks out from the oven wall (usually along the back or side somewhere). This probe varies in resistance as the oven heats and sends a signal to the control board. If the probe is defective, or if you have a broken wire, you will get this fault code. The following link explains how to troubleshoot and/or replace an oven probe:
http://www.fixya.com/support/r393313-checking_replacing_oven_probe
I hope this is a simple fix for you. The repair is simple if you follow the instructions. If you require assistance locating any replacement parts, please post back with your complete model number. I hope this helps you.
Jul 24, 2008 | GE Kitchen Ranges
Siemens Efficient Networks SpeedStream SS1020 Network Adapter Logo
121 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
