Question about WYSE WY-150 AMBER 80 (90098307) Network Terminal
I work on Wyse terminals, I have had one big problem with the wy-150, the horz. drive xistor overheats and the screen shifts to the left, i have replaced the flyback, horz. xixtor , and some caps in the sweep circuit, this seems to be a problem on about 1/3 of the units out there and i have spents houres and houres trying to find a fix for this. Any one knows how ti fix this? Bob
  • 1 more comment
  • robert neilson Sep 11, 2009
    The horz. output transistor on the Wyse 150 part # 2SC2898, overheats and not the horz. drive. and screen shifts to the left.
    The transistor that over heats is the Horz. Output transistor(2S2898) and not the drive transistor, need some one that has had the problem on the exact same model, to tell me what parts to replace to fix the problem. Bob
  • robert neilson Sep 22, 2009
    Solved the problem, I replaced the MC 1391 Horz., TV IC, and the problem went away...Bob
  • 5,807 Answers
1) you're problem might be on the horizontal deflection circuits
a) possible fault might be the diode that is parallel to the horizontal deflection output transistor. ( they are in series with each other if there are available)
b) possible fault might be the supply of the horizontal output
transistor is a little bit high.
c) possible fault might be the HDT transformer is partially shorted
just a possibility due to horizontal drive xsistor overheating.
d) the screen shifts to the right can also be caused by the horizontal
oscillator circuits, maybe a changed value Mylar capacitor.
e) can also be caused by the electronic controls controlling or aiding
the horizontal oscillator circuits
f) the solution to these problems can be an actual replacement of
the said components, if you don't have an ESR tester or any equivalent good quality capacitance meter
g) try trimming the power supply output that goes to the pin of the
flyback transformer that goes to the horizontal def output transistor.
h) try also lowering the screen resolution from the video card of the computer, try 800 X 600 just for testing, eliminating the possibilities
i) if there seems to be a fold-over on the raster then still in the oscillator circuits to the driver stages.
j) might try also to put temporarily a bigger heatsink for the said
overheating horiz drive xsistor while still on the process of trouble-shooting
k) try also to note down the supply voltages of the horiz out xsistor from the pin of the flyback
l) the supply voltage of the HDT transistor, before and after the series resistor.
m) you might need also to plug the unit to a lower AC input supply
when having to troubleshoot the problem.
please note that horiz drive means the one driving the horiz out transistor.
just don't forget to unplug the unit when extracting electronic components, and be careful on the flyback area.
hope i have helped you, thanks for using Fixya!
Posted on Sep 11, 2009
  • 1 more comment
  • Rommel Cana
    Rommel Cana Sep 22, 2009
    there are also some possible causes why the horizontal output is having too much heat
    a) may not have the exact replacement of the flyback transformer
    b) may not have the original output transistor
    c) the output transistor is overdriven, try having a 19 ohms shunted on the base and emitter of the
    horizontal out
    d) try doubling the horizontal output
    sometimes it heats too much due to the loads
    a) check the supply that goes to the video outputs maybe about 180V , check the capacitor
    shunted to it, replace if necessary.
    b) sometimes it is on the series capacitor that goes to the yoke
    c) sometimes you have a slightly higher supply of voltages on the flyback section
    d) you have a high G2 voltage
  • Rommel Cana
    have a look also on the 2 series diode that is parallel to the horizontal output
  • Rommel Cana
    Rommel Cana Sep 23, 2009
    nice to hear you made it, it is inside the IC, congrats
    d and e possible causes
  • 3,741 Answers
Click this link for why horizontal transistor gets hot and shortedhttp://www.repairfaq.org/sam/reppic/horiz-tv.pdf ---------------- and for more information horizontal transistor is a power transistor.if its getting short that means power board is having power supply issue.the board has to be checked to locate the faulty component that is making the horizontal transistor short again n again. ----------- thanks.keep updated.
  • charlymonty Sep 22, 2009
    thanks.for the update.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A few ideas you may want to consider/try:
  • modify/replace (with a slightly higher value) the dropping resistor supplying the horizontal drive transistor through the HD transformer;
  • substitute the HD transistor with a higher rating/capacity;
  • select a substitute HD transistor in TO-126 packing that would allow a small heatsink to be attached.
Unfortunately, no available schematics for the 150 on my end, but on others that use a 2SC1213 as the HD transistor, replaced  the 39 ohms dropping resistor with  47 ohms
Good luck and thank you for asking FixYa.
Posted on Sep 04, 2009
Is't opossible to get complete schematic for an
http://fileshare.eshop.bg/
is the only place I can think of
Jan 15, 2010 | WYSE WY-370 (wy370)
BigmoneyPTC paga?
No no paga es un ladron yege a tener 100 referidos y no pago
no pierdas el tiempo con eso de las ptc
Jul 14, 2009 | WYSE WY-GPT (909099-05) Network Terminal
Only one line
Hold the G key down on power up and leave the G key pushed in till you get a screen, then go to set up and defult all, then re set up the unit.
Jul 04, 2009 | WYSE NEW WY-60 AMBER 80 (90010907) Network...
Wyse S30 power settings
You can check the settings in the bios (password will be "Fireport") I dont think there is anything in there that would trigger this.
Is there a screen-saver option in the control panel for the device? If so, see if it is set. If not, then try using the Wyse website to update the terminals OS to the latest. This will hopefully solve the problem. It might just be an incompatability with the older OS version.
Jun 22, 2009 | WYSE Winterm S30 Network Terminal
Saving things in the WYSE WY-150
As far as i know the monitor can do very little and internal storage capacity is not big at all.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 e 240
rcardenas@mrp.to
May 08, 2009 | WYSE WY-150 Network Terminal
The wyse 50 terminal does not work properly
Wyse 50/60/150/160 monitors were my specialty!
From what you were explaining it seems to me that you have a bad internal battery and it needs to be changed and a factory reset/ calibration needs to be performed.
I can repair wyse terminals at my facility if you like. The repair cost is not that high and we can also perform the regular repair and adjustments on all wyse monitors if needed.
Please contact me if you have any questions.
Thanks
Rory Cardenas
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Mar 18, 2009 | WYSE 50 Terminal
Does other terminal emulation VT220/VT100 work on WYSE?
vt220 on wyse
Sort of but f3 and f4 wont work and f1 would be ctrl + o
Dec 11, 2008 | WYSE WT3235LE (902032-68) Network Terminal
How to connect wyse wy-185 to at&t 577 printer
Dear mm6529, I have an At&t 577 printer, but do not have a manual for it. Any ideas where to get one or could make a copy for me.
blevinsb33@aol.com
Dec 03, 2008 | WYSE 900986-07 185 Terminal Amber w/o...
Wyse Terminal
Do you have a print screen button, sometimes abbreviated PrtScr on the keytops. I would get the contractor back on site and have them setup the machine so you can print, they left the job unfinished and I would emphasize that when you call back.
Jan 08, 2008 | Computers & Internet
WYSE WY-150 AMBER 80 (90098307) Network Terminal Logo
94 people viewed this question
Top WYSE Computers & Internet Experts
Sunday Ojelabi
Sunday Ojelabi
Edward Greene
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
