Question about HP Officejet 9110 All-In-One InkJet Printer
HP 6110 all in one printer error press enter to alighn cartridges
Keep getting this error out of no where, keep re-setting, powering off and on and checking cartridges still same error, nothing looks wrong and it won' allow anything to print help me....
I just changed my black ink cartridge and I keep getting a message that reads: pree enter to align catridges. Each time that I press enter the test runs and the screen reads alignment failed. HELP
Hi
in order to get alignment you need to have ink
in both cartridges
You need to replace and color cartridge or refill it
like this
If I help you pls vote me
Sep 06, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6110 Printer, add wider paper size. Also align cartridge keeps appearing even after I've pressed enter and the process keeps repeating.
Press the enter key and hold it while you press the menu button. That will make the align message go away, but if just one color is missing it will always fail the alignment. The paper size is chosen in control panel and printer properties, printing preferences.
Feb 22, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My HP officejet 6110 all-in-one will not print. It keeps saying to align cartriges which i've done several times.
If you do a test print and any color is missing it won't pass alignment and keep giving the error. If you're happy with the printing, when it says press enter to align, press and hold the enter button and press the menu button. The error will go away and let you print.
Feb 19, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My hp 6110 won't printer get message "remove and check cartridge"
please go ahead and check with a new set off cartridge..
if you are getting the same error then you need unplug the power cable and tap the on button for 10 times then replug that...if still u r getting the same error then press and hold the # 6 and unplug the power cable at the same time..and while pressing those two buttons replug it...
it will reset ur printer....if still u r getting the error..printer needs to be replaced.
Jan 21, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
Apr 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
CANNOT ALIGN CARTRIDGES
Press and hold the Enter button, and then press Menue.
Also visit
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu00657#Bypass_Alignment
Jun 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Alighning test
Problem The following error message appears on the LCD panel on top of the printer after you insert a cartridge: Press enter to align cartridges . You press Enter , but the error message does not go away. The printer will not print. Solution To bypass the cartridge alignment, do the following:
  1. Press and hold the Setup button.
  2. Press the Options button. The printer should be ready to print.
If the print quality is unacceptable after bypassing alignment, follow the steps below until the error is corrected. Step 1 - Check the paper Make sure the printer is loaded with clean, unused, white paper. If the paper is not feeding properly, check the paper path. For information about how to do that, see the instructions under "If the paper does not feed correctly" at the end of this document. Step 2 - Remove and inspect the cartridges
NOTE: The "problem" cartridge is the cartridge indicated by the error message.
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge. Figure 1: Removing the cartridge c00143341.gif
Mar 03, 2008 | HP PSC 2210 All-In-One InkJet Printer
Press Enter to Align Cartridges
Press and hold " setup" button then press " option "  will skiip alignment
Sep 22, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP Officejet 9110 All-In-One InkJet Printer Logo
139 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
