Question about Refrigerators
Kitchenaid refrigeratorice make no water
Kitchenaid refrigerator ice maker not recieving water to make ice. In door water depencer operats with no problems
  • 358 Answers
When the ice maker stops to fill with water ,check if the solenoid (dual valve) gets power (110 volts) ,if it does and won't open you have to replace it ,but if it doesn't get any power ,the problem is the ice maker itself.
Posted on Sep 05, 2009
Testimonial: "appreciatde the help. Up and making ice."
KitchenAid KBFA25ERSS01 I replaced the water
if its computerized make sure someone didnt turn icemaker off check to make sure its in all the way
Oct 27, 2013 | KitchenAid KBFS25EVMS Stainless Steel...
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
uiouio67
May 24, 2010 | KitchenAid Architect 25.3 Cu. Ft....
Ice maker is not making ice, yet the red light that indicates the ice maker is "ON" is flashing..
KitchenAid KSGR25FTSSOO side by side one day just quit making ice. We have blown out the lines and replaced the filter. The red light does blick when we open the door. The water despenser as a flow of water that is real slow. How and what do we do next?
Oct 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
KitchenAid door ice and water dispensers don't work
Hi
If  the ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Mar 31, 2009 | KitchenAid KSRG22FK Side by Side...
Kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Mar 30, 2009 | Refrigerators
could be watervalve icemaker or sensor boards try valve first
Mar 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker won't fill
leaky solenoid? could cause ice build up
Jul 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
107 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
