Question about Weiser Lock Powerbolt 1000 Lock
I have had the powerbolt 1000 for two years and it worked fine for a long time but recently it just keeps beeping. I have changed the batteries several times, sometimes the unit works for a while and then starts beeping, other times it happens just a few minutes after changing the batteries! I had an older unit that lasted for about four years before it died and I replaced it with the current one, and for the last several months I have had the beeping problem.
I have my random beeping problem now solved. Like so many of you, I too would have beeping sounds coming from my lock and there wasn't anything that I did could to fix it. My symptoms were EXACTLY like so many other postings which led me to believe there could be a mfct defect. I called Weiser's toll free number. After describing my problem to the lady(grouchy lady #1) she said she would send me a new key pad and it should arrive in six or seven days.I asked if this was truly the problem, response"I'm sending you a new one aren't I".I also asked if this was a common problem.response" I don't know, there's thousandsof them out there". After waiting one week I again call the same toll free number and(HAPPY CHEERY Lady #2) says, Oh yes, I'm sorry for the delay but we have run out of stock and have had to get the mfctr to produce more keypads and there is a delay as they are on backorder.Still cheery and friendly says there has been a problem(yay Someone admitted it) and you sould get the key pad in two weeks.If you have any other questions or concerns about delivery please call back.Thankyou Happy Lady. My new keypad arrived yesterday installed it right away and VOILA, problem solved.(note:grouchy lady#1 could have very easily turned this consumer to a shlage only customer,Happy lady #2 has regained my faith in positive customer relations.
Posted on Sep 09, 2009
  • 14 Answers
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
The woman was very friendly. Great customer support!
-=dån=-
Posted on Sep 14, 2009
My Weiser powerbolt lock is beeping-changed batteries-won't stop
Why is my Powerbolt 1000 unit beeping?
To determine why your lock is beeping abnormally, please follow these steps:
  1. Take out batteries and unplug powerstrip.
  2. Let it sit for 1 minute, then put the batteries back in and wait another minute.
  3. If it does not beep, the keypad needs to be replaced (17733-1).
  4. If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
Contact Customer service from here:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
Jan 09, 2012 | Weiser Lock Powerbolt 1000 Lock
Began to beep in intervals. Changed batteries and it worked a couple of times then beeped twice then touchpad will not work, Five minutes later it beeped steadily for 10 seconds than stopped. Will not...
This is the relevant excerpt from the Powerbolt programming and troubleshooting instructions:
"To determine why your lock is beeping abnormally, please follow these steps:
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish)."
Since you've already gone through the battery change, try the battery remove-reinstall recommended above. If that doesn't work for you it suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page, where you will find the appropriate number of your location:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem. You will want confirm that you need the part before you go through the expense, and that it's worth it. You will need to know the "finish" of your lock. Try to talk them into warrantying the part, in spite of the age (one year warranty on electronics), as a matter of good customer relations. They will help you get the correct part on order.
Good luck--and please provide feedback if this helps!
Sep 22, 2011 | Weiser Lock Powerbolt 1000 Lock
Our Powerbolt 1000 started beeping this morning. I've tried replacing the batteries and disconnecting the power strip. The beeping continues. I am unable to reset the code. Are there any other...
Powerbolt is Beeping?
Take out batteries and unplug power strip.
The complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Since you've already gone through the battery change, etc.,this suggests that you need to replace the appropriate Powerboard for your lock.
So this is the link to Weiser Customer Support Page:
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense.
Also, they will be able to get the correct part on order for you.
Jul 16, 2011 | Weiser Lock Powerbolt 1000 Lock
Does the green light flash all the time on my powerbolt and when I open the door from the outside there is a beeping sound this has never happened before not untill I changed the batterys.
Since you've already gone through the battery change, this suggests that you need to replace the appropriate Powerboard for your lock.
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, they will be able to get the correct part on order for you.
Jul 03, 2011 | Weiser Lock Powerbolt 1000 Lock
After replacing the batteries on the Weiser powerbolt, the unit will work fine for several locks and unlocks. The lock will start beeping, and then the keyboard will go dead.I have tried changing batteries...
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, your lock may be new enough for you to talk them into warrantying it, and thirdly, they will be able to get the correct part on order for you.
I hoe this has been helpful. Good luck!
Jun 23, 2011 | Weiser Lock Powerbolt 1000 Lock
My lock works for awhile then stops. The beeps sound all the time, then stops locking & unlocking using the keypad. Then a day or two it works again.
Here's a link to the Powerbolt 1000 frequently Asked Questions page:
You will find this answer on that page:
Feb 10, 2011 | Weiser Lock Powerbolt 1000 Lock
Electronic keypad stops working after 5 or 6 uses. If I pull then replace a battery, it beeps once then works for another 5 or 6 times then stops. Pull the battery again and the same thing. Any ideas?
Weiser has a one year warranty for electronics problems and a lifetime warranty against mechanical and finish problems with their locks. Contact them from this link:
http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
Dec 13, 2010 | Weiser Lock Powerbolt 1000 Lock
I have had my Kwikset Powerbolt 1000 for about a year now and I think it just died! The deadbolt won't move. It will only move one out of every 25 times or so. I just replaced the batteries again. It makes...
Why is my Powerbolt beeping?
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Follow this link to find out how to remove the cover for your Powerbolt:
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
Sep 20, 2010 | Kwikset Powerbolt/Electronic Deadbolt-...
Intermittent beeping
US: 800-677-LOCK
-=dån=-
Dec 09, 2008 | Kwikset UltraMax Powerbolt 1000
Weiser Lock Powerbolt 1000 Lock Logo
516 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
