Question about Acer ScanWit 2720S Film Scanner
Accidently broke Fluorescent Lamp in scanner whilst cleaning
I am gutted because I have had it for a few years know and it has probably only had 10 hrs of total use. The model is Hewlett packard 5300c 7690c. The lamp is a thin Cold Cathode Fluorescent Lamp measuring 25cm/250mm x 2.6mm approx I have contacted Hp uk and they said that it is non replaceable and would have to replace the flatbed itself which is ridicolous. I am an electrical engineer and cannot understand why you have to buy a new scanner everytime the lamp breaks or deteriorates after hours of use. That sounds like a money making scheme to me.
Please can anyone help me or does anybody know where I could get one of these lamps with the four pin socket that plugs into the driver board. I have found this site http://www.jkllamps.com/index.cfm?action=fam&tid=2&fID=31 with a similar size lamp but have no idea as to matching the rest of the specs of the HP lamp. Thanks in advance
  • Acer Master
  • 32,281 Answers
LCD Parts supply CCFL lamps for LCD screens, maybe they have one that suits the HP. Check them out Use this link to their WEB site :-
www.lcdparts.net
Posted on Sep 04, 2009
Testimonial: "Thanks Geekman. I looked at this site you mentioned and only one fits the bill but is thinner. It needs to match specs. I will email them. Thanks"
WHEN I MAKE COPY IT IS ALWAYS VERY LIGHT.
First you need to carefully clean the copier optics: Open document glass, use clean, dry and soft cloth to wipe the small mirrors on the scanner. Clean also the fluorescent lamp carefully not to break it. Wipe the document glass both inner and outer sides then securely screw it back. Remove the drum unit and wipe clean the underneath mirror on the laser unit then test the copy quality.
Oct 31, 2013 | Sharp AR-5520N
Tip
Scanner Tips 1" Do's "
<span>&bull; Always unplug your scanner before cleaning it. </span><br /> <span>&bull; Place your scanner away from heating vents or windows, or other locations where moisture might affect its functioning. </span><br /> <span>&bull; Always keep the scanner on a level surface so that it has a good grip, otherwise the mechanism carrying the CCD and fluorescent lamp may get damaged over time. </span>
on Dec 28, 2010 | Office Equipment & Supplies
The Xerox 8830 scanner fluorescent why does not shine?
In case Xerox 8830 scanner fluorescent does not shine the simpliest way try replace one or put this lamp on another working device and check if it work
May 09, 2012 | Office Equipment & Supplies
How do I replace fluorescent lamp. Scanner not working.
You cannot actually change the lamp for the scanner. Better get a new one instead.
Have a nice day!
Oct 26, 2011 | Epson Stylus CX3200 All-In-One InkJet...
Arm237 f5-02 light goes out after 1 second but should stay on -- lamp ok, cable ok, broke after cleaning optics
It is possible that while the optics were getting cleaned the cable connected to the lamp unit got pulled out enough that it looks like it is connected but isn't connected enough, or the lamp was accidently touched by the person cleaning the lamp and now its bad. I would check the cable that connects to the lamo unit and the CCD first.
Sep 28, 2011 | Sharp AR-M237 Copier
Fluorescent lamp fused
In my experience, when the lamp goes out, it's time for a new scanner. if you are willing to try and fix it though, maybe try Ebay or the manufacturer's website. You'll likely spend less time just replacing it though.
Good Luck!
Feb 20, 2008 | Visioneer PrimaScan Colorado 2400u Flatbed...
Lamp replacement
Just replace the lamp! It's just a fluorescent light you can get anywhere. You don't need a new scanner, if I had to replace the scanner every time the lamp died I be in the poor house!
Sep 17, 2007 | Agfa DuoScan Flatbed Scanner
Mikrotek ScanMaker 9800X
These days it is a service by replacenent item Buy the next scanner
Jun 04, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
What are the white balance modes available with the camera?
The following White balance settings are available for the A2: AUTO, Preset (Daylight, Tungsten, Fluorescent, Shade, Cloudy, Flash and Custom1 to 3) The following slight adjustment is possible: * At setting Daylight, Tungsten, Shade, Cloudy and Flash: +3 to -3 (one unit is approximately equal to a 10 mired shift.) *At fluorescent lamp setting: equivalent to 7 fluorescent lamp(3 -wavelength colored fluorescent bulb, 3-wavelength white fluorescent lamp, 3-wavelength neutral white fluorescent lamp, 3-wavelength daylight fluorescent lamp, white fluorescent, neutral white fluorescent, daylight fluorescent lamp)
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
The following White balance settings are available for the A1: AUTO, Preset (Daylight, Tungsten, Fluorescent, Shade, Cloudy, Flash and Custom1 to 3) The following slight adjustment is possible: * At setting Daylight, Tungsten, Shade, Cloudy and Flash: +3 to -3 (one unit is approximately equal to a 10 mired shift.) *At fluorescent lamp setting: equivalent to 7 fluorescent lamp(3 -wavelength colored fluorescent bulb, 3 wavelength white fluorescent lamp, 3 -wavelength neutral white fluorescent lamp, 3-wavelength daylight fluorescent lamp, white fluorescent, neutral white fluorescent, daylight fluorescent lamp)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Acer ScanWit 2720S Film Scanner Logo
299 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
