Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Color washed out
The color has been consistently getting worse on the tv. I am sure that it needs to be cleaned but am unsure how to open the tv. Help!
  • 178 Answers
If the tv has a blue haze and the picture is turning greenish-redish, the problem is that the coolant in the crt's are cloudy due to bacterial growth. The fluid needs changed in the Blue and possibly Green tubes, the red tube usaly does not need the fluid change because the bacteria that seems to inabit the tubes dont seem to like the red light.
To do this yourself is involved and will expose you to electric shock dangers. If you want to tackle this yourself Post back and i can give you explisit instructions.
This service by a Technican could cost around $300.00 to preform, this cost can vary depending on the shop.
Posted on Sep 05, 2009
I cleaned out my Samsung hl-s6187w and put everything back together and now it doesn't turn on. It makes a beeping noise like fast morse code and keeps cycling the power trying to turn on. The ballast gets...
Tv projection lamp inside the tv less than 2 years or so?Yes than the tv projection Lamp is good.You have this tv like 3 or 4 years already?The tv colors wheel even have been replace at leat once?No the tv probally require replacing the colors wheel these tv have to replaced the colors wheel every now and than.
Apr 14, 2011 | Samsung HL-S6187W 61 in. HDTV
Toshiba 20hlv15 image turns bright colors and will sometimes disappear.
I will check what toshiba says about this problem, but in the meantime, make sure your tv is not overheating, make sure all airvents are open, you said you took it apart so I supose you cleaned all the dust and so on.
Il get back to you.
Mar 30, 2008 | Toshiba 20HLV15 TV
We have a Phillips rear projection tv, about 9 years old. The color has been getting progressively worse over time. Dark scenes are almost impossible to see. It almost seems that only blue and red are...
Tv have halo pictures and dulls colors?Yes,the tv have bad Coolant chemicals on those colors guns R,G,B CRTS tv Tubes.Must replaced those CRTS Coolant chemicals on those CRTS tv tubes.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a Coolant kit to replaced those CRTS tv Tubes coolant chemicals.
Nov 13, 2010 | Philips 55PW9363 55" Rear Projection...
Problem viewing vcr will not display video all cables are new and tight. Device is two years old and problem is getting worse, or more consistent.
assuming that you can see some sort of output from the video on the tv be it lines or flashes it would indicate dirty or worn heads you could try a video head cleaner if you can get one nowadays if you open up the vcr
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
the heads are minute dark specs about half the width of a match and about 6-8 mm long never rub up and down alway clean in the direction of the drum tjis can be done using you finger and some spirit simply stroke you spitited finger or each head there could be 2, 3 or 4 heads clean them all if ain any doubt take it to a professional
Jan 17, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Fluff on left on clothes
the lint filter is your problem needs to be cleaned out, the agitator which is the thing in th middle of the machine houses the lint filter the top should just pull off
Jun 07, 2009 | Whirlpool Washing Machines
Philips 50" rear projection- Washed out picture.
You need to change the CRT Fluid. This is a common problem on the  older projection TV sets.
You can get the fluid and instructions on how to change it from www.TvRepairKits.com.
Dec 19, 2008 | Philips 9P5034C 50" Rear Projection...
Colour management
Check the printer driver. I had the same problems - b+w with green tints, colors not rigt.  I'm using a Mac, but noticed that under the Color Matching options of the printer driver the default is "vendor matching" - switch to "ColorSync" and see if that works for you. Did for me.....
Good luck
SteveP in Italy
Oct 18, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Phillips Magnavox 60 inch Projection Tv
I have a white glow around all the white letters and just all the white colors in general. What do I do ?
Sep 24, 2007 | Philips Magnavox 9P6034C 60" Rear...
Plasma TV problem - My Plasma tv is having a serious problem. Suddenly the Red color is no longer Red but Orange. The picture looks much worse now. I know it may sound like the set was getting old but I...
Try checking the cable making sure they are tightly plugged in. My dads Plasma screen started showing orange / brown colors in place of primary red... he had been moving things around and didnt realize the wires were loosened in the process. This made him realize.... GET an HDMI and get rid of all the other cables......
May 07, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
