Question about GE Microwave Ovens
Hi I have a GE JVM1533WD 002 spacemaker microwave oven. It will not power on. I have found voltage coming into unit and replaced fuse. On the magnetron I see 120V in but not back out. It's a black connector, not the magnetron itself, could that be all it is? Like I said it's a power connector then a black housing and then goes back out to wire linked to fuse.
    Problem Solver:
  • 11 Answers
It was the upper thermostat. I switched with a identical one below to get results, Magnetron seems to be burnt out as well.
Posted on Sep 12, 2009
Should I replace the Hv capacitor if the fuse didn't work?
Any part on the line voltage or hi voltage will blow the fuse if shorted, Does the fuse blow as soon as you try to power up the microwave ?
May 29, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker (LVM1750) Microwave Oven
If the source voltage, the fuse inside the unit are good someone has to follow the voltage in to see where it stops.
Dec 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the fuse for ge spacemaker jvm1320wb-002...the unit is totally dead...nothing works
It is time to replace the microwave oven, if the fuse is open you more than likely have a more serious problem that will be costly, companies only go back a few years when it comes to supply parts
Jun 16, 2012 | GE Microwave Ovens
GE Spacemaker microwave Model #JVM1650WB 002 is not heating anymore. All other functions are OK. How can I repair?
remove the cover; you will see a large white ceramic cylinder fuse in clips, on top; replace it: radio shack sells the part.
Jul 22, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Can you tell me where the fuse is for model number JVM1650
under the outer cover inside the unit in a fuse holder,make sure to discharge the hi-voltage capacitor before replacing or touching the fuse,being its the fuse it very well could be the hi-voltage cap that caused the fuse to blow
May 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Jvm1533wd spacemaker wont heat up and has a loud humming noise
I have found that in nearly all cases, it can either be the high voltage fuse or the magnatron assy. The high voltage fuse can be found normally enclosed running from the high voltage capacitor to the transformer. Always make sure you read up on discharging high voltage capcitor , for it can store a dangerous amount of voltage and if not discharged can cause serious injury or death. Good luck.
Sep 26, 2009 | Microwave Ovens
I have a J HP60G 002 GE Microwave (older)keeps
If it blows the line fuse instantly when you push start.... it is either a shorted HV capacitor or shorted monitor switch.... most likely.
Sep 13, 2009 | Microwave Ovens
The microwave does not heat..after reading everything about the magnetron my one question is this an easy job that an ammature can tackle or do I really need to call in a service man?
I'm having the same problem with my microwave -- GE JVM1533WD 002.
The inside light, cooling fan and turntable are all working but it is no longer heating food when the Start button is hit.
The unit is noticeably louder than normal, too.
Any suggestions? Thanks in advance for your help.
Jun 09, 2009 | GE JE1660 Microwave Oven
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Bulb replacment for GE Microwave Model JE1540wv002
There should be a very helpful "mini-manual" hidden inside the unit behind the control panel. It has wiring, schematics, and troubleshooting info.
Yours will be found as JE1540WV02 (instead of 002) here: http://www.tinyurl.com/gv383
Nov 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
299 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
