Question about Philips Televison & Video
My phillips 50'' plasma tv is making a clicking noise like it is turning on but does not come on and continues to make the clicking noise. Any comments on what the problem could be?
    Problem Solver:
  • 11 Answers
Sounds like its the CCFL trying to come back on, either that or like on my sony Bravia when it selects input sources it makes a clicking sound as well.
1) is got a bad CCFL
2) it has a bad psu
3) if its under warranty take it back
Posted on Sep 04, 2009
Phillips plasma blinks 6 times
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Feb 20, 2011 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I have a 50" Phillips
Sounds like there is a couple bad caps in the power supply. Check the power supply to see if there is any bubbled caps. Replace with a higher voltage if necessary.
Dec 04, 2010 | Philips 50PFP5332D 50 in. Plasma...
50 inch plasma phillips won't turn on repeated clicking noise
This is likely the relay that connects the AC to the main power supply although in a plasma TV it could indicate a failure of the high voltage power supply for the display itself.
Turning on most sets causes a small power supply for the infrared remote receiver to connect the main power supply to AC. If the power supply itself is defective, the relay interrupts or if the supply is still healthy, it may disconnect the AC again to prevent damage to the main supply and possibly a fire.
Since there are two primary sources for this problem and no good way to separate them as the faulty part, you will need a tech to be on site to determine exactly which failure has occurred.
Sep 06, 2010 | Philips 50PFP5332D 50 in. Plasma...
Tv turns on but no display
Probably ur capacitor would have been gone ... try to replace it ...
Similar kind of problem:
http://www.earthinfo.org/samsung-tv-makes-a-strange-clicking-sound/
Jan 03, 2010 | Philips 50PFP5332D 50 in. Plasma...
Plasma will not turn on
i plug it back in and let it do its clicking and with in 2 min tv was working agian
Aug 01, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Tv turns it self off after only 2-3 seconds and makes crack noise
Since the set is less than 1 year old, it should still be under warranty. Request warranty service.
The noise you are hearing is probably arcing inside the set on the power supply board. Continuing to attempt to turn on the set will only make things worse. Please request warranty service as this is unusual for a TV that new.
Dan
Jan 16, 2009 | LG 50PB4D 50 in. Plasma HDTV
Power light for tv turns on but no picture and no sound comes on tv i have a 50 inch phillips plasma
Check your cables and TV input settings.  Can you get to the on screen menu?  Does anything appear on the screen when the tv is on?
Dec 06, 2008 | Televison & Video
Menu keeps showing on my TV
Your tv needs a software upgrade. This is usually done by a qulified service technician.
Nov 26, 2008 | Philips 50FD9955 50 in. HDTV-Ready Plasma...
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
483 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
