Question about HP DesignJet 2800cp InkJet Printer
Getting an error 010031 00000001 after changing the belt on my HP DesignJet 2800CP. WOrked fine before.
Error 86:01
did you perform a scan axis calibration after changing all these parts? If not then you should do that before doing anything else.
Sep 01, 2014 | HP Designjet Z6100 InkJet Printer
I have a designjet 800ps 42" and send me the 79:04 error code, after this happen i change the belt and all the printheads, but it still send me the same error, it said Error Code:79:04 ...
Who told you to change the belt? 79:04 is a Firmware error.
Switch the Printer Off and wait a few minutes. Switch the Printer On again and check if the Error Code has disappeared. If the Error Code reappears, check for a new Firmware release. If the new Firmware release does not solve the problem, or if new Firmware release was not available, then contact the HP Response Center supplying the following information: - Model and Serial Number of the Printer. - Firmware release of the Printer
- The complete Error Code information, including the linefeed where the error occurred
Aug 19, 2011 | HP DesignJet 500ps (42 in.) InkJet Printer
On my HP 1050C Designjet I am getting the error 'Check printhead path Type 2. Then it says to switch off.
Hello. The "Check Print Head Path" error is usually a worn out carriage belt on printers more than 5 years old. Open the top cover and examine the area under the belt and look for debris that looks like pencil erasure crumbs. Other possible problems could be the tube system catching on something as the carriage moves, the encoder strip being very dirty or extreme friction between the carriage bushings and the rails they move on. If the belt needs to be replaced, a replacement kit can be purchased at: http://www.lpscomputer.com/c-790-hp-designjet-belt-replacement-kits.aspx
Hope this helps.
Bob
Jan 26, 2011 | HP DesignJet 1050c plus InkJet Printer
Printing is getting jammed in the left corned, then cancells.
Try removing the screws from the back door on the Ink Supply Station (sometimes they catch on the carriage - the printer does not need the screws) Look under the carriage belt to see if there are rubber bits. The belt may be disintegrating and need replacing. Parts available here: http://www.lpscomputer.com/c-736-designjet-1050c-belt.aspx
Jan 30, 2010 | HP DesignJet 500ps (42 in.) InkJet Printer
Problem with Printhead Path
Something (not sure what) is obstructing the movement of the carriage assembly. Turn off the power and remove the cleaners. Push the carriage assembly out and pull/push the belt to move the carriage assembly until you find the bind. If you've recently changed the belt or carriage assembly, make sure you properly adjusted the carriage height.
Jun 05, 2009 | HP DesignJet 1050c plus InkJet Printer
DesignJet 450C (E-size)
I replaced that belt about a year ago...it took a long time but seemed to go fine. I have a manual "carriage belt installation instructions" its 12 pages long. check out HP website and if you cant find it online, I could scan it for you.
Mike
mjlehto@charter.net
Mar 29, 2009 | HP DesignJet 450c InkJet Printer
Vista compatabillity
Drivers are available from WinLine.com for $200.00.
Feb 21, 2009 | HP DesignJet 2800cp InkJet Printer
HP DesignJet 2800cp InkJet Printer Logo
Seeker5211
Seeker5211
