Question about Sub-Zero Bottom Freezer Refrigerator
Ice forming on the inside back wall of the refrigerator.
  • 32 Answers
That is caused buy air condensing in the freezer check the seal around the door to make sure it is sealing properly.
Posted on Sep 05, 2009
Samsung refrigerator is freezing up on back panel of refrigerator . Will defrosting the whole unit do any good? The unit is 2 years old
well yes and no , defrosting it will temporally make it work , but main problem is there isn't proper air flow over evaporator coils id clean them with soap and water while defrosting out unit , if low airflow is allowed to continue then refrigerant gas will build to high press and escape and render unit a total replacement
Sep 29, 2016 | Samsung RB215ACBP 20.0 cu. ft. Bottom...
Why is ice forming in freezer
Ice layer inside freezer box floor - Defrost drain line clogged.
Frost or ice on freezer box top - Room air leaking into the fridge from door seals.
Frost on the Freezer box back wall means unit is not defrosting properly.
Sep 04, 2014 | Whirlpool Refrigerators
How to fix ice build up in freezer
Did you examine the drain behind the rear panel (location #11) and below the evaporator coil in photo HERE and location #20 HERE You will need to tell me how much frost there is on the evaporator coil (location 22) I want you to test the=> 12729129 Defrost Heater Assembly. Check the door seals around both doors. Are the door seals good? I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 11, 2014 | Maytag Refrigerators
Why ice is forming in some items kept inside at the back of the refrigerator including the vegetable tray.
Ice at the back of refrigerator section is usually due to a fan there that has become stuck, little fan like 2 1/2" or so, the fan circulates cold from the freezer into the refrigerator. If that cold air is not moved through than it will form ice there from moisture in the air of the refrigerator section. I have had that problem a couple times, could be from something pushed against back wall and got n the way of fan blades causing fan to stop.
Apr 18, 2012 | Samsung Refrigerators
Ice is forming on bottom and back wall of freezer can any one help with this
there are two types of freezer, one is upright freezer (same as refrigerator on outside look but inside all the layers are same as the freezer of an ordinaryrefrigerator) the other one is the chest type freezer(basically it looks like a chest cabinet),now about the forming of ice at the bottom and back wall, well should be all side of the freezer should have ice on it,
Just one question to ask? Did you used any sharp object in removing ice(ex. knife, ice pick , etc,)
If you do then there are a possibility that you do some hole on the tubes where the Freon Gas (chemical refrigerant) are passing thru, then in that case you might have leakage. Well that means you really need to call a technician to do the job, because you'll gonna need to fix the hole and re-charge a freon gas.(having not enough refrigerant on the system, your refrigerator might not able to produce ice completly.
The other possible reason is that your motor compressor might be damaged(possible reason: Lost compression) it has something to do with pump compression inside the motor (only technician can solve this problem)
Oct 31, 2009 | Refrigerators
Ice forming in the bottom of the freezer
Unclogh the drain hole inside the freezer in the bottom of the bakc wall pouring hot water until the ice melted and keep pouring until goes through.Repet this every 3 or 4 months to keep it clear.
Jul 22, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Ice is forming inside the refrigerator
You have a freon leak in you evapator. Call an authorized Sub Zero service company it will be coverd by you sealed system warranty..
Oct 12, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Ice build up
Check that the door is closing properly otherwise the freezer will be working overtime to cool and ice will form. If the door seal is good, it is possible that the thermostat needs to be checked.
Oct 02, 2008 | Refrigerators
The back part of the refridgerator inside where the cold air comes out is leaking water and the back inside wall is wet?
You should fine a drain line just below the freezer level in the back. The drain line is more than likely plugged. Check the loop seal down by the drain pan under the back of the refrigerator. It may be restricted at that point. It may require a complete defrost of the freezer to clear the ice formed in the drain from a back-up.
May 28, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Sub-Zero Bottom Freezer Refrigerator Logo
149 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
