Question about Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television
Sony kf42we610 lamp & lamp power supply replaced 5 blinks keep occuring Set will not start
Lamp supply is out
Posted on Mar 04, 2010
Sony Kdf-e50a10 keeps shutting off and on.......Power/standby blinks during this time.....No Lamp Light
The blinking light is typical of a failed lamp and they last commonly between 2-5 years tops in these sets. You should replace the lamp. The link below is to the lamp for your set.
Replacement Lamp: Sony KDF E50A10 KDFE50A10 Lamp with Housing XL2400
Jan 24, 2014 | Sony Televison & Video
Sony KF 42WE610 blinking red (non-lamp light) won't turn on
That code represents a power supply board failure. probably a solder break or, circuitry separation.
Feb 13, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
I have a Sony Wega 55 inch for about 6 years. I have replaced the bulb twice before. I just got another bulb in the unit. It now works for awhile. It occasionally is shutting down with the 5 blink code. I...
5 blinks, pause, 5 blinks, etc. means "Lamp driver error" and the probable cause listed is "Lamp driver defect".This is the starting point for a qualified service technician.Even so, the actual problem may be the lamp. Did you install a genuine Sony lamp assembly? These sets are bad for the lamp driver and optical block, which Sony has extended a warranty on these sets due to the mass problems that they have had with them. If you haven't contacted them yet please do so and talk to them about a warranty on your set. Sony tells me that while they extended the warranty through 3/2011, so please hurry on this.
The parts you need run between $225.00 and $315.00 depending on what boards you need. IF Sony won't honor the warranty or at least work with you, you may consider a new set, these will only get more costly to keep repairing. I Believe in Sony, its not all their fault, there were a lot of bad electrical supplies sold to the electronics industry a few years ago and they simply don't last.
Mar 12, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture
I disagree with given info, this tv has no horizontal output transistor because it is dlp tv.
3 red light blink means lamp cover is not placed back properly after lamp replacement/ lamp checking. Make sure lamp cover is fixed back in its place securely and tight.
Jul 16, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
Red light 5 blinks
your set needs attention by the authorised service - probably the Vertical scan, horizontal scan or the flyback transformer driver circuits have failed.
Jul 12, 2009 | Sony KDS-R50XBR1 50" HDTV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Sony Wega KDF-55E2000 won't turn on
A 5 blink code is a lamp power supply problem, but I would try a new lamp. I'd say about 90% of the time that fixes the problem.Get an ORIGINAL Sony lamp as the aftermarket replacements are ****. If you replace the lamp and still have the problem, you will need to have the lamp power supply/lamp ballast replaced
Oct 19, 2008 | Sony Grand WEGA KDF55E2000 55" Projection...
Standby light flashes 5 times
That was for a different model sony have different codes for different Chassis if your model is KF42WE610 an error code of 5 blinks is a lamp error.
Lamp driver error 5 times - Lamp driver is faulty. No sound or picture will be the symptom. Replace lamp driver.
May 23, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television Logo
222 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
