West Marine Moorea Waterproof Binoculars Logo
Michael Bailey Posted on Dec 08, 2007
West marine binoculars
I was given these binoculars and there is a button on top, I didn't know what it was , and your website explained that it is a range finder.
Well to the problem, I pushed the button and nothing happened, I checked the battery, dead. I replaced it and still nothing. I think the button is stuck or broken, how do I access the button without tearing the rubber armor?And if the button is broken where can I get one and all the usual questions.
Thanking you in advance oh great and wise binoc gurus.
Michael Bailey
A
Anonymous
The white button lets light in so you can see the cumpass try looking at the cumpas and putting your finger on the white button. the cumpas will get dark, it must have a fiber optic line run down to it
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 26, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
351
Points
I have these...apparently the white button has no function, however the small button on the right, lights a red light you can only see at night, to read the compass.
Need to reupholster acouple of west marine deck chairs
Same here. The stainless steel is fine. The cushions are shot.
1helpful
Cleaned glass with glass cleaning cloth and coating coming off
The coatings cannot be replaced once damaged unless new lenses are fitted. Strictly speaking, they can, but it will cost far more than buying new lenses.
Without the coatings your binoculars will work just fine but under some lighting conditions you may notice a lack of image contrast and perhaps some lens flare. Under other lighting conditions a total lack of lens coatings can actually improve the image as more light can pass through the optics to your eyes. It's not a fault which usually merits replacing the binoculars.
Just use the cleaning cloth sparingly in future on any coated lenses: dust should just be blown off but small amounts make no practical difference and careful handling should prevent finger marks on the glass surfaces. Salt spray and errant finger marks should be removed using a lightly dampened lens cloth: de-ionised water with about 5% alcohol is ideal.
I have a pair of glasses with a compass in the middle
These binoculars work on the Galilean principle in that they are just lenses. No prisms. These folding types were made as opera glasses. The addition of the compass is a gimmick added and such units were sold as cheap touring or travel binoculars. These types were popular in tourist locations. France at one point had a significant optical industry mainly producing opera and Galilean field glasses with the exception of Huet and Krauss who made prism binoculars.
An interesting but cheap collectable.
2answers
No Manual--Don't know what top buttons do Minolta AF 10
Hi, Do you still need help? I can email the instructions. Tony
Who made these marine binoculars?
Without seeing a picture it is difficult but there is hope. Most binoculars branded by companies other than the big three come from China. Namely the Kunming United Optics Corporation. Just type in United optics China into google. Have a look at the BC 6 in the compact binoculars section they may look like your ones. Not many 8x26 units are nitrogen filled so I'm guessing on this one. They have a support section and may be able to help.
1helpful
Steiner Commander Compass not working - possibly low of fluid?
Check this post for lens covers.
http://www.bluewaterweb.com/MarineHardware/Hardware.asp?
12helpful
How to use the reticle in my Fujinon Mariner Binoculars?
How to use the reticle:
The vertical scale (reticle) visible through the left half of the binocular, above the compass display, allows you to calculate distance to an object if you know its height, or to calculate the height of an object if you know its distance from you.
Each mark on the vertical scale has a value of 5 MIL (1Mil is equivalent to an angel that can determined an object one meter in height at a distance of 1000 meters). Therefore, if a navigation chart gives the height of an object, by sighting on it and counting the number of MILS, you can determine how far away it is.
To Measuer distance when height is known:
Object Height(m)/Scale Reading x 1000m=Distance in Meters
To Measure height when distance is known:
Distance(m)xScale Reading/1000=Object height in meters
Fujinon-Mariner WPC-XL Lens Cap replacement
You can order a replacement set at: http://www.bakermarineusa.com/index.php?id=17&cat=38&prod=137
Top West Marine Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a West Marine Optic Expert? Answer questions, earn points and help others
