Question about LG Prada KE850 Cellular Phone
How do i lock the keypad when making a call to enable me to press options when connected. ie. the keypad disappears after dialing and when connected if i am told to press whatever option i cannot do it
Shlage keypad dead bolt unlocks when you press the
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Aug 31, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
Door will unlock without entering code
"Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial? "
Feb 15, 2012 | Schlage BE365-PLY BE365PLY626 Satin...
Can't push one button to lock anymore
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the "dial". When disabled, you have to enter the user code, then turn the dial. So either way, you still have to turn the dial.
To enable/disable this feature, enter your Programming Code --press Schlage button--press 7
"How can I program my electronic keypad lock when the instructions with the Programming Code have been lost?"
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
Complete installation & programming instructions can be found here:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Good luck-and please provide feedback if this helps!
Aug 12, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Scroll down and find them under the heading Electronic Security-Keypad Deadbolt BE365
Aug 11, 2011 | Schlage BE365-CAM BE365CAM505 Lifetime...
Hi does this lock auto lock like the one with a handel does?
To enable/disable this feature, enter your Programming Code--press the Schlage butt0n--Press 7.
Nov 23, 2010 | Schlage BE365-CAM BE365CAM505 Lifetime...
After installing my lock, i don't have to enter my User code to get the thumbturn to move....my lock never appears to lock
This link will take you to the page for programming information:
Then scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt 365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
Good luck--and please provide feedback if this helps!
Nov 15, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
How do I lock my keypad? Should the wireless be on wheneever I make a call and what does that mean?
hi,
The simplest way to lock keypad in most of the blackberries is, to hit "alt+enter".
(or)
you can press "k" quickly to lock the keypad. But you should disable the option of "Dial from Home screen" for this.
thanks, have a nice day.
Feb 13, 2010 | RIM BlackBerry 8700
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Envy 2 dials phone numbers accidentally- need to set key guard
On the front keypad, press the ok button until you have the option to select contact list. Scroll down that list until you see keyguard settings. Press ok to enter keyguard settings and then go to option 2 - unlock options. Select two step unlock. This will force the user to press "ok" and then "clr" in order to dial out. This has resolved the problem for me...Good luck.
Dec 03, 2008 | LG enV VX9900 Cellular Phone
LG Prada KE850 Cellular Phone Logo
57 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
