Question about Dell Inspiron 1525 Notebook
Ran a pre boot system assesment n hard drive DST failed error code 2000-0142? what does it mean?
Your HDD has a bad sector and it is damaged. Replace your HDD with a new one.
And you have important data on your HDD, you can buy just a external HDD connecter and plug it to your damaged HDD it will work it will operate normally. Now you can copy your data easily.
Posted on Sep 08, 2009
    Scholar:
  • 118 Answers
Dst short test fail error code 1000-0146
DST stands for Drive Self Test, if it fails the test it means your drive is failing or has failed. replace hard drive
Jun 02, 2014 | Dell Latitude 100L Notebook
Error code 0142 message error code 2000-0142
My computer did boot up to the desktop, but was completely unresponsive from there when trying to open anything. I ran a system diagnostics and got this error with the status byte of 70. I rebooted into Safe Mode and was then able to open files. I backed up my stuff to a flash drive and then ran Error-Checking in the HD Properties which runs the CHKDSK function the next time the computer is rebooted. That found 2 bad file clusters and repaired them. One was a file called Windows.edb, which does the hard drive search indexing for Windows and was most likely my problem with the lockups. The other was a Napinsp.dll file. After these were fixed and the computer was rebooted, everything worked normally.
This HD is only 9 months old, but if this happens again, I'll replace it again.
Apr 21, 2012 | Dell Inspiron 6400 Notebook
I have a dell studio that says A disc read error when you turn it on , shop told me hard drive gone ,, i am running a pre boot ssytem assesment from pressing f12 and the test say DST short test pass does...
TRY F8 ON BOOT UP TAPP REALLEY FAST IF U CATCH IT INTIME GO TO OPTION LAST KNOWN GOOD CONFIG .....ONCE IT DONE LET IT DO ITS THING IF IT BOOTS LET IT ..THEN ON FULL BOOT LEAVE MIN OR 2 THEN RESTART UR SYSTEM .....SEE IF ANY DIFFRENT
Jan 09, 2011 | Computers & Internet
Sudden Blue screen display on my Dell Inspiron 1545 with MS XP OS-Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus...
Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
Nov 03, 2010 | Computers & Internet
My Dell Inspiron 6000 won't boot up. It keeps
Hi:
The DST error code 1000-1046 is definitely a failing hard drive. ..I am not sure why your laptop is not recognizing a CD in the drive, but you should go into your BIOS settings, and in boot sequence, make sure that the CD drive is the first boot device. If you can't boot from a CD, you are not going to get very far with installing a new hard drive...
May 02, 2010 | Dell Inspiron 6000 Notebook
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
DST log contains previous errors.DST short test failed
Error Code: 0146
MSG Code: 2000-0146
MSG: 1:DST Log contains previous errors
Dec 22, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 1521 Error Code 2000-0146
It means "DST Log contains previous error(s)."
Dell Support says “If the diagnostic test reports one of the above errors, refer to Dell Troubleshooting Wizard: "Hard Drive Fails the Diagnostics" Wizard ID: 324398”
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?journalid=79E54961218510CBE040AE0AB5E158B6&treeid=324398
Dec 05, 2009 | Dell Inspiron 1521 Notebook
Dell latitude d600
Greetings AROD718,
This error message is telling you that your hard-drive is nearing OR has already failed.
I would contact a buddy or go somewhere local to get Data recovery ASAP or if that is not important to you start shopping for a new hard-drive.
Hard drives are not very expensive and are simple to install, if you need further assistance please reply back!
Good luck,
Shawn
Oct 31, 2008 | Dell Latitude D600 Notebook
Error code 0146 , can you help me ?
ALWAYS CHECK THE WARRANTY BEFORE DOING IT YOURSELF
If this is a Dell computer , it indicates a hard drive failure. if so here is the solution:
Look at the bios and see if the hard drive is detected.
To get to the BIOS, when you turn on the system, you will be confronted with a black screen with the dell symbol in the middle, if you look at the top left of the screen, you should see something like
Press F2 for boot options
Press F12 for setup
Keep tapping the F2 or F12 key for boot options. this will take you into the BIOS.
Check also that it says enabled
Next see if you can boot the dell diagnostics partition. {F12}, then select diagnostics, once you have the diagnostics available run the memory tests and the hard drive test.
you should get a report when it finishes looking something like this:
DST Short Test: Failed
Msg: Unit 2 : DST LOC Contains previous error(s)
READ TEST:
0F00: 0244
MSG Block: 57301297
VERIFY TEST:
0F00:1A44
MSG Block: 57301297
if there are more than two errors ide suggest a new hard drive. BUT TO SAVE YOUR DATA BEFORE ------>Do you have anything important? if you do, you will need to do a repair install of XP and get your files before the hard drive fails completely. Use the service tag to obtain full specs of the computer at dells website. This hard drive has previous errors, and has generated new ones. It looks like it is getting ready to fail. You may be able to use a xp disk to perform an operating system repair, the dell operating system CD will do this also. Here is a link: http://www.michaelstevenstech.com/XPrepairinstall.htm If you follow the directions exactly, you will not lose any files. Please continue to post about this issue, and operate this computer as little as possible.
Oct 21, 2008 | Computers & Internet
Dell Inspiron 1525 Notebook Logo
695 people viewed this question
Alun Cox
