Question about Cell Phones
Flipped My screen is showing my infotmation upside down including my texts
How do I fix display show upside down. TCL LED TV Model: L24T2100
http://www.tomsguide.com/answers/id-1989729/picture-flipped-upside-fix.html
Feb 20, 2015 | Televison & Video
How i recover my infotmic tab
Depending on which version you have please see the following notes:
How To Factory Reset/Recover the systerm On Your Tablet PC(Flytouch 2/SuperPAD 2/Infotmic tablet 2)
1. Press "Power" and "Home" button at the same time, hands off until you see the words on the screen.
2. Select:"wipe data/factory reset" with the "volume" button, and then press "menu" button.
3. Select:"Yes -- delete all user data", and press "menu" button.
4. Wait until you see" Enter erase_cache Data wipe complete" .
5. Press "reset", calibrate it and set the language.
How To Factory Reset/Recover the system On Your Tablet PC(Flytouch 3/Flytouch 4/SuperPAD 3/Infotmic 3)
1. first press the "MENU" key, keep pressing the "MENU" key while you press the "POWER" key, remove your hands when you see "recovery" from the screen.
2. Wait a few seconds until it is done. And then the system will start..
Precautions
A power failure during the firmware writing operation may disable the tablet PC.
* Use a fully charged Battery or dedicated AC Adapter for the firmware update.
* Do not shut off the power during the firmware writing operation
Feb 04, 2015 | Tablets & eReaders
How can i get the screen back to normal
You have the TV upside-down. Flip the TV over.
Nov 17, 2014 | Televison & Video
How do I create mirror image letters?
I will assume you need to print part of page backwards or upside down.
This is pretty easy using a Text Box. A text box can have a border, be opaque or transparent, force the text to flow around it or not.
To create a text box, go to the Insert tab, click Text Box and then I like to choose "Draw Text Box." You can draw it in the general area you need it. It's ok to use one of the preset Text Boxes, too.
Type your text inside.
To flip the text around, double-click your text box to activate it, and then look for the Rotate button in the "Arrange" section on the Ribbon. You can flip it horizontally or vertically as many times as you need to make your text upside-down or a mirror image.
Then edit your box - border, color, text wrapping, position, etc.
Sep 19, 2014 | Microsoft Office Word 2007 Full Version...
On my LG vx8360 the inside display is upside down & mirrored. It just did that one day when I went to read a text. Went to Verizon they were compleatly useless
Hi,what causes upside down display on phones is when the cellphone your using has a flax problem.
A Flex is a thread like object that is located inside the phone. It is connecting both the upper side of the flips and the lower side of the flip phone...
The flex makes the cell phone screen to display...and when the flex is getting damaged, possible signs are upside down display.
To correct the upside down display, you will need to replace the flex inside the cell phone..
For assistance on how to replace the flex, you can go to an expert in phone repair for help..
Hope that helped..
Take care......
Feb 07, 2011 | LG VX8360 Cell Phone
The image is upside down and I can't find any setting that could allow me to flip it
You can normalise the screen by a keyboard short cut. Just press Ctrl+Alt+ (arrow key) to flip the window to normal settings.
Thank you for choosing Fixya.com
Sep 15, 2010 | Computers & Internet
UPSIDE DOWN SCREEN IN MY I880 NETEXL FLIP PHONE
take the battery out of your phone with the power on. then try to turn it back on and see what happens. if still a problem take it to a sprint store. they can replace it.
Mar 31, 2009 | Motorola Mobility i880 Cellular Phone
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Flipped\upside down screen on my compaq
http://forums.techguy.org/tech-tips-tricks/336002-windows-xp-flipping-screen-upside.html
Windows XP: Flipping the screen upside down and back again
Once, at University, someone had flipped the screens of all the public computers (running on Windows XP) of the English Department upside down. The wallpaper, desktop icons, fonts, mouse-cursor and even the start-up screen...everything was displayed or moved upside down. People could not check out their e-mails or surf or do anything.
To reverse the upside down screen mode, press ctrl, alt and the up arrow (arrows console) at the same time; the screen will probably go blank. Turn off the monitor, turn it on again and the display will be normal again. If you possess a sense of humour or are antisocial, press ctrl, alt and the down arrow simultaneously, turn off the monitor, turn it on again and everyone (excluding the culprit) will be desperate --> upside down! Works for Windows XP Home and Prof.
Mar 31, 2008 | Computers & Internet
Sony handycam dcr-sr40 lcd display
flip switch is not working or stucked, a loose wire connected to this switch is also possible. you may open the unit and check for it. a pro fix is better.
Nov 06, 2007 | Sony Handycam DCR-SR40 Camcorder
Cell Phones Logo
275 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
