Question about Campbell Hausfeld PW2102 Gas Pressure Washer
Type of oil for pressure washer pump.
What type of oil should I be putting in my pump of my Campbell Hausfield pressure washer?
    President:
  • 583 Answers
Any anti foaming oil ,you can use multi grade but it goes milky with minute air bubbles and gives the appearance of getting water in.most manufacturers recommend anti-foaming oil
Posted on Sep 05, 2009
  • 1,631 Answers
Anti foaming = NON Detergent 30 weight blend SAE
Posted on May 21, 2015
Campbell Hausfield Electric Pressure Washer 1350 handle leaks
You are probably missing the washer or O-ring. Loosen and separate then check. It may also be a broken O-ring.
Oct 17, 2014 | Campbell Hausfeld PW135000AV 1350 PSI...
I cannot remember the type of gas or the fuel mixture (gas to oil ratio if required) for my pw2050 2000psi pressure washer,last used 2006 cannot locate the manual,
Pump regular gas and no oil mix. Your engine has a dipstick which means its a four stroke engine.
The oil goes inside the motor. For summer use I recommend 30 weight non-detergent oil.
Change it out once a season *(Beginning would be preferred). Drain the gas out at the end of the season.
Hope this helps!
Feb 23, 2011 | Campbell Hausfeld PW2102 Gas Pressure...
What type of oil is needed in my Durabuilt air compressor-6 gallon tank? I need to replace some oil. Thanx. Send response to "gfrommell@wi.rr.com." Thanx.
Howdy. It's actually called Compressor Oil and is available at nearly all hardware stores and tool rental agencies. There are several brands and they are all comparable. I use Senco, but Campbell Hausfield is also good. Farmerbear at FixYa.com
Oct 23, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Hausfield Campbell pressure washer 2300 psi .Water not flowing through hose to gun
hi try statring the machine with no hose on, if ok add the hose to the machine without the gun and lance. then try the gun on its own WITHOUT THE NOZZEL in the lance. just elimate things regards
Jan 23, 2010 | Campbell Hausfeld PW2575 Pressure Washer
Wont come on when switch is pushed to on
looked up Campbell Hausfield service on internet. found dealer within 1 mile of home.
Sep 11, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Do you have to use oil in the pump and if so type,how often.
water pumps doesn't require oil in the pump; but your engine does require. if the water pump is of "self priming" type, fill the pump casing with water before starting the machine to avoid damage to the water seals.
May 22, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
I have a Campbell Hausfield wheelbarrow type compressor model #vt617206aj that will not stop making air, just builds and builds until emergency relief vave opens. please help
It sounds to me that you have a defective regulator valve assembly.
This is not a trivial problem. It should be repaired and NOT used until it is repaired.
The emergency relief valve is there for a reason --- to prevent an explosion of the pressure vessel if the regulator does not shut it off.
This is not a do-it-yourself type of repair. A machine shop, or even a welding shop could probably do this repair for you.
If the compressor is an older one or a low value compressor, deep six it and get a new one.
May 17, 2009 | Campbell Hausfeld Adjustable Pressure...
I have NorthStar 2000 psi pressure washer with a
1999 campbell hausfield 1800 psi--2.2gpm. weak pressure at the nozzle. water sprays out, but with the pressure of a garden hose.
Mar 20, 2009 | Garden
No air pressure past 60PSI on a 125PSI Campbell Hausfield WL61110
Your comperssor is oilless type and suffers from short cylinder / piston life. When the compressor no longer reaches cycle pressure the cylinder / piston should be replaced. These parts are available at www.chpower.com I believe that the part number is wl210300aj. Not expensive, enjoy.
Dec 13, 2008 | Campbell Hausfeld 26 - Gallon Air...
Campbell hausfield power washer Model #pw175500le
Hi
First priming hte engine(put some gas in the plug hole)and start the engine for few times until the engine runs constantly.If not there is a fuel delivery problem.Check the air and fuel filters,the fuel line,the muffler and screen inside.Disassembly the carb,check and very carefully clean it with compresed air.
best regards savumihai71
Nov 02, 2008 | Campbell Hausfeld Garden
Campbell Hausfeld PW2102 Gas Pressure Washer Logo
1,297 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
