Question about Lexmark X3470 All-In-One InkJet Printer
My Lexmark X3430 pops up an error message "Cover Open" and it is closed???
There is a problem with the pinterhead please help its a lexmark pro705
A firmware update for the Lexmark Prevail Pro705 will help fix the printhead issue you are experiencing. Please follow the steps below on how to successfully update your printer:
  1. Open the printer cover and remove the printhead and tanks (if installed). Note: Carrier will come to the center automatically with this error message as the cover is opened. Remove the ink tanks > open the printhead latch and remove the printhead > close the printhead latch, close the printer cover and confirm the error message goes away from the operator panel.
  2. Proceed with the firmware update. Please visit the Lexmark website to download and install the Lexmark Pro700 Series Firmware Update.
After successfully updating your printer, open the printer cover > re-insert the printhead > close the printer. If no printhead error comes up, continue with normal installation steps for cartridges. If error comes up again, please contact Lexmark Technical Support Center for further assistance.
Dec 11, 2011 | Lexmark X5650 All-in-One InkJet Printer
Printhead is not supported by the all in one
A firmware update for the Lexmark Prospect Pro205 will help fix the printhead issue you are experiencing. Please follow the steps below on how to successfully update your printer:
  2. Proceed with the firmware update. Please visit the Lexmark website to download and install the Lexmark Pro200 Series Firmware Update.
After successfully updating your printer, open the printer cover > re-insert the printhead > close the printer cover. If no printhead error comes up, continue with normal installation steps for cartridges. If error comes up again, please contact Lexmark Technical Support Center for further assistance.
Oct 06, 2011 | Lexmark Prospect Pro205 Wireless...
"there is a problem with the printhead"
Sounds like you need a new one. The best place to buy is amazon (because of reviews and price). take a look Lexmark Printhead cheers
Show error2200
1.Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2.
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved. Source(s): http://support.lexmark.com/index?page=co…
Apr 23, 2010 | Lexmark P4350 All-In-One InkJet Printer
I get the error 2200 message everytime I try to send a fax
Hello there:
this is a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message2.gif.
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.
StepAction1
No: Attempt a test scan. If the error message does not reappear, the error is resolved.2
Power off the AIO and remove the power supply from the back of theunit. Open the scanner cover. Check the scanner glass for cracks andthe scanner casing for cracks. Close the scanner lid. Open the topcover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
No: Continue to step 3.3
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Insert the colorcartridge, close the top cover, reinsert the power supply, and power onthe AIO.
Yes: Repeat step 3 with another color cartridge. If the printer2.gif fails again, continue to step 4.
No: Repeat step 3and install the black/photo cartridge. If both cartridges areinstalled, attempt a test scan. If the error message does not reappear,the error is resolved.4
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Remove the color cartridgeand insert the black/photo cartridge. Then close the top cover,reinsert the power supply, and power the AIO on.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark.If the error message does not appear with both cartridges installed,attempt a test scan. If the error message does not reappear, the erroris resolved.
Nov 10, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printer will not print or shut down
reset memory; unplug; plug back in while HOLDING DOWN STOP KEY. This resets/clears memory
tape down the little black plastic lever (usually on left side) so it can't pop back up which causes it to invoke error message "cover open" and "cover closed" who needs a machine to tell a cover is open?
Mar 31, 2009 | Lexmark X3470 All-In-One InkJet Printer
Need to fix urgently lexmark x3470 cover open error. in images if possible.
open operator panel (top piece with electronic display) lift up cartridge cover (the one you lift to change cartridges) there is a small black plastic lever which you can manually move up and down with your finger (usually on left side). take a piece of tape and TAPE IT DOWN so that it can not pop up again (popping up is what triggers the error message (cover open) even when it is closed.
after you tape it down you will never see this error message again, even with the cover up.
who needs a machine to tell you a cover is open? we can SEE this with the human eye.
it is a useless feature. also, check device manager (com ports) to make sure there are no yellow explanation marks (port error) or no printer will work on it. you may have to make a change in bios to assign the port manually to make sure there are no conflicts with the port. nancynerd
Jan 02, 2009 | Lexmark X3470 All-In-One InkJet Printer
Error 2200 lexmark 6250.
hey ,
Follow the steps :-
Step Action
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved...
Nov 15, 2008 | Lexmark X7170 All-In-One InkJet Printer
Error 2200
Step Action
1 Power off the printer and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the printer on.
2 Power off the printer and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the printer on.
3 Power off the printer and remove the power supply from the back of the unit. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the printer.
4 Power off the printer and remove the power supply from the back of the unit. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the printer on.
Sep 16, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark x3430 printer
X3430 lexmark wont let me scan any of my pictures.
it says it's to busy.
Nov 27, 2007 | Computers & Internet
Lexmark X3470 All-In-One InkJet Printer Logo
195 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
