Question about Whirlpool Dryers
The dryer runs and drys clothes but there are times when it won't shut off -- timer seems to hang up--sometimes and works others
  • 415 Answers
Your timer sound like it stalling and replacement would be in order if if its in good shape buy one
Posted on Sep 04, 2009
Maytag ldg26cs gas commercial dryer never shuts off, runs normally and drys clothes but never stops or goes into cooldown mode.
Sounds like timer is stuck in one place and not counting down, can it be done manually? If so replace timer.
Dec 15, 2013 | Maytag MDG7600AW Gas Dryer
I have a whirlpool electric dryer and the automatic sensor mode is not working. In the automatic sensor mode it drys the clothes but will run forever. The timed mode works by drying the clothes and...
I wonder if maybe your wire is attached to the sensors? If it vibrated off the connection that could be the problem. Here is a video I made which shows how to connect the wire:
Oct 16, 2013 | Dryers
Dryer heats and drys but shuts off intermitantly..sometimes can be started right up, other times turning dial does nothing.. is it the timer dial?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 17, 2011 | Amana ALE643RB Electric Dryer
GE Dryer timer doesn't work
Replace the timer . If model number given , could give the part number .
Aug 09, 2009 | Kenmore 800 6983 Electric Dryer
Dryer will not turn off
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 20, 2009 | Dryers
Gas dryer wont trun off after drying
May 08, 2009 | Dryers
Machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
First try cleaning the moisture sensors with rubbing alcohol, these are two silver colored strips located inside the drier just below the lint cleanout
Oct 31, 2008 | Whirlpool GEW9250 Electric Dryer
GE dryer willl not stop, drys OK
I does sound like the timer has went out on your dryer, but there could be other problems as well.  Sometimes exccesive lint build-up can cause a heat transfer issue with the thermostats.  On GE models, anything o stop or delay heat transfer could cause the timer to stop working.  If im not mistaken, this is a gas dryer correct?  It could be a number of things that could stop the forward motion of the timer, primarily a stuck or inoperative thermostat, a defective flame sensor (highly doubtful if it dries), or a wiring problem.  Be sure to check out all your wiring, then if you wanted to, try and replace the thermostats.  Just dont want to see you waste a lot of money if it was a bad timer.
Oct 30, 2007 | Dryers
Open Questions:
Dryers Logo
42 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
