Question about Altec Lansing ADA 885 Computer Speakers
Woofer works intermittently
When I shake it, it works then cuts out again. It's only the bass. I opened it up but found nothing loose. I love this set and have hea it since 1999. I really want to keep it. It rocks.
  • 733 Answers
Sorry but it's blown. Can't believe it lasted that logn, my speakers, no matter what brand tend to go out in about 2-3 yrs.
Posted on Sep 05, 2009
Cerwin vega al1000
Try to check voltage input. Because when we increases the bass or volume it takes more power to modulate.. this might solve your issue..
Mar 15, 2014 | Yamaha Audio Players & Recorders
Can I use my Logitech x-230 speakers without the sub-woofer? My sub-woofer got busted!! Any suggestions?Perfectly good speakers!
i had the same problem with same speaker system. the amp for this system is inside the bass speaker. if your amp is still working but your bass speaker is not you could cut the wires to that speaker making sure the cut wires do not short out. i was quoted more to repair them than it was to buy a new set. but i wont be buying logitech again as ive had two lots fail.
Jan 18, 2012 | Logitech X-230 Computer Speakers
A425 subwoofer, more bass? wires came off, no bass managment.
I wouldn't cross wires or leave one disconnected. Can you solder the wires back on the the control knob? Did you feel the subwoofer cone to see if it's working at all? I would guess the wire you didn't connect, is the subwoofer wire. Try putting it back to original cofiguration and solder the wires in place.
Jan 13, 2012 | Dell Powered Subwoofer Set A425 Computer...
My Onkyo sub-woofer sounds like something is loose in it or rolling around...the sound is similar to shaking a can of spray paint. When I plug it in to the system it sounds crackly. If i turn the volume...
sub woofers are very powerful bass , with incredible sounding technology. your problem might be with the woofer wall around the circle. open the box and take the woofer out.Check if there is any tare over the corners of the cloth. sometimes there might be a crazy noise because of a little opening in the cloth caused by small tare.. if so better change it with a new 1 and make sure that the new cloth has guaranty
damaged sub woofer eg. images?q=tbn:and9gcqv8lxhmuosnjkfywvef7uujnntmudkhhpl-pghy0i7xushrda- torn cloth- images?q=tbn:and9gctcogf_osbsmo3vmcu1vjnpozksylq4nojwpbojuo3w28zvb3honw
Thanks for rating good luck
Feb 08, 2011 | Onkyo SKW-200 Subwoofer
Woofer sound is very loose
If you mean low bass, then you can adjust with the bass controller to reduce the limit of the bass frequency. Check to see the woofer mountings are firm, the wires are intact and if possible reverse the connection and try again. If you are not happy try with another woofer or get your woofer checked with a system at your friends to confrim if the woofer itself could be the issue. If so chcek for the suspension of the woofer, rubbing of the voice coils or the spider being loose.You can repair the woofer by using a good glue to fix or to change the suspension . Hope you try. Good day
Aug 11, 2010 | Creative Labs Audio Players & Recorders
How do you adjust the bass levels on a Yamaha HTR6130 receiver? I can get the display to show Bass 0db, but what button changes the settings?
When you touch tone button on your front panel repeatedly, you will get two option for setting bass and trebble, when you select Bass immediatly press your updown Sound field Program Button.
Please note:for better sound if your using Small front speaker keep bass to 0db and select the low frequency through sub woofer and program manually LFE from only Sub woofer and addjust CUT off frequency of Subwoofer to 160 and incase if your bass is not clear put it into rev mode.
Oct 05, 2009 | Yamaha HTR-6130 Receiver
Woofer cuts out intermittently
Buy a soldering iron and go over all solder connections on the circuit board. Sounds like you have a cold or intermittent solder connection. Also make sure the problem isn't in the subwoofer cable. Don't be afraid to do a little soldering, and just make sure you don't create "bridges" between existing solder connection. Only heat the connections long enough to melt them and add a little solder, as excessive heat can destroy sensitive components. Before doing all this, remove and reinsert all related cables into their jacks several times, as these connections can become oxidized and make poor contact over time.
Dec 15, 2008 | Bose Acoustimass 15 System
Speakers cut off when bass goes up...
sounds like you hava a load problem.if your'e running your woofers at 1ohm,make shure your amp is 1ohm stable.....
Jul 03, 2008 | Car Audio & Video
Basslink intermittant
i posted similar prob. servo lights when power is being cut to speaker (over drive) and manual shows it for purpose of tuning gain. it should flicker at highest input only...mine is on always too. infinity wasnt much help since mine is out of warranty.
Nov 13, 2006 | Infinity BASSLINK Car Subwoofer
Altec Lansing ADA 885 Computer Speakers Logo
299 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
