Question about Gateway Media Center 610XL (610XLMDIA) PC Desktop
The power won't go on the gateway 03 dt009 01s all in one
  • Tony Sheppard
    Tony Sheppard May 11, 2010
    Check your power supply output. Should be 12volts .
  • Chad Preslar May 11, 2010
    what do you mean the power wont go on? is it plugged in? are the cables attached correctly? if its under warranty take it back
I need to connect the switch leads for power,reset, and HDD LED activity to my front panel LED to the corresponding connectors on the motherboard for the Gateway DX4300-03.
PinSignal NameIn/OutDescriptionPinSignal NameIn/OutDescription1HD_PWROutHard disk LED pullup (5 V, 15 mA max)2HD_BLNK_GRN+BLNKOutFront panel green LED3HD Active#OutHard disk active LED4HD_BLNK_YLW_BLNKOutFront panel yellow LED5GND Ground6SW_ON#InFront panel On/Off button7FP_RESET#InFront panel Reset button8GND Ground9+5 VOut 10FPSLP#InFront panel Sleep button11IRRXInIrDA serial input12GND Ground13GND Ground14Key Not connected15IRTXOutIrDA serial output16+5 VOutIR power
Nov 29, 2011 | Gateway DX4300-03 Desktop PC
The power button on my Gateway DX4720-03 is slowly flashing blue
integrated video card on Mother board heated up. Will need to replace all motherboard. $90 bucks to replace if you find it.
May 25, 2011 | Gateway DX4720-03 PC Desktop
My gateway dx4300-03 starts up fine and then about 5 minutes into working the monitor goes blank and the computer seems to go into sleep mode and won't restart until I unplug from the back and re plug in. ...
By Cyclontech!
Hi, The solution to fix the problem is by changing your power supply. Just make sure that you replace it with a 500W or higher and not with the same 300W which does not have enough power for this system, plus it is defective. I have changed the power supply to 4 diferent gateway PCs same model dx4300. And all 4 are working perfect. And run a check disk on CMD to fix the disk errors that were created every time you unplugged it and turned it on again.
Oct 28, 2010 | Gateway DX4300-03 Desktop PC
I have a Gateway DX-4720-03 when I press the "ON" button it lights up briefly then goes out and computer will not boot. Fans do not come on. nothing happens. (If I press button again immediately nothing...
I would actually lean a little more towards the power supply being the problem. You can either have someone locally test it for you, or you can buy a power supply tester to check it out.
Aug 26, 2010 | Gateway DX4720-03 PC Desktop
I need a motherboard for this model. Gateway dx4720-03
The Gateway DX4720-03 Desktop PC, uses an MSI ms-7399 motherboard, made specifically by MSI for Gateway.
I just did a quick search and saw this mobo available for $75 US on Ebay. (Gateway DX4720, ms-7399)
This is not an advertisement for Ebay, nor the seller.
Feb 03, 2010 | Gateway DX4720-03 PC Desktop
Slow flashing blue power lite. Monitor shows no
First when you power up the computer press F8 key then enter in enable vga mode.
If you are able to enter then go to start menu->control panel->display property ->settings.
Change screen resolution to 1024*768 then apply and ok.
But if you are not able to see safe mode and other menu.
Then open cpu cabinet .
Refix RAM memory.
Pull cmos cell from motherboard for 10 minutes.
Reattach all connection harddrive.
Open processor fan and processor remove dust from all parts.
Make sure motherboard is not ground with cabinet.
Remove PCI cards if any.
After all above still same then change RAM then try.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 19, 2009 | Gateway DX4640-UBC01A PC Desktop
Two month old Gateway DX4300-03 randomly shuts down when on the internet.
I have the same pc my power supply went bad after 2 weeks.Pack up the pc and return it ASAP I have nothing but problems with mine.Gateway use to make good pcs, those days are gone,mine was a gift and I had to keep it.
Nov 19, 2009 | Gateway DX4300-03 Desktop PC
Gateway Media Center 610XL (610XLMDIA) PC Desktop Logo
862 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
