Ps3 hdmi format not supported
I have a philips 32'' (32pfl5403b/10) hdtv that won't display hdmi or av from ps3. tried it on hdmi and keep getting FORMAT NOT SUPPORTED, a/v NO SIGNAL. i e-mailed philips and they said the problem was the ps3. i have reset both ps3 and tv to factory settings and still nothing works, tried it on a samsung hdtv and it works perfect,my pc and 360 work on the philips with no problems even after updating ps3 to firmware 3.0 it still does not work. i also tried new hdmi cables (1.3b).
  • 8,457 Answers
Tries something else with a HMDI with the Phillip Tv.Like DVD player With HDMI see if it work with the TV.Narrow it down might have to use all the HMDIs inputs use.See if it all works.
Might just have one or two HMDIs shorted out put.
Posted on Sep 04, 2009
Had the same problem setting up my ps3 with a 32" Vizio. What solved it was when i reversed ends of the HDMI cable
Posted on Nov 06, 2009
Samsung 2007 27" TX-T3092WH will not support HDMI or cannot see PS3?
HI,
Do one thing While PS3 is in standby mode press and hold the power button on the frond panel of PS3 for 30 seconds (factory reset). After doing this you will get video from its composite video.
Also check the hdmi If you didnt get the video through HDMI then,
PS3 out puts Full HD 1080P video through its HDMI out put. IF your tv doesn't support Full HD then it will display format not supported or Software not support.
If you want to get video through HDMI then do the following.
Connect the PS3 to any Full HD tv (friends or relatives) and go to its menu ,select HDMI settings. then down scale the video from 1080p to 1080i.
After that connect the PS3 to your tv you will surely get the video.
Ajin
Jun 16, 2012 | Samsung TX-T3092WH TV
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    I have a HDMI problem with my PS3. I have it
    You will need to turn on the PS3 and hook it up with rca so you can access the console menus. Turn it on and get to the main dashboard. 1. Go to Settings -> Display Settings (not video) 2. Select [ Video Output Settings ] 3. Select HDMI 4. Select Resolution 5. Select Screen Size 6. Save the settings 7. Reboot the console. This should resolve the problem. We've seen PS3 consoles that would not reset by performing a hard reset. We were able to resolve this issue through the settings menu though. Let me know if it is still giving you issues.Hank GATpro Repairs
    May 14, 2010 | Sony Playstation 3 (PS3) Console
    Try entering Recovery Mode and choose "Restore Default Settings".
    If that doesn't help, you may have an HDMI port failure - which will require returning the unit to Sony or sending it to a third-party PS3 repair shop.
    Mar 25, 2010 | Sony Playstation 3 (PS3) Console
    PAL PS3 NTSC HDTV, HDMI Cables don't work, WHY?
    I have the same problem. I get the "Mode Not Supported" message on my Samsung pn50b860 when I try to run the PS3 through the HDMI. Any solutions/suggestions yet?
    Jan 06, 2010 | Sony Playstation 3 (PS3) Console
    Trying to hook up HDMI to PS3 and the TV keeps saying not a supported format
    Try using another AV cable (like a normal composite cable) and try going through your PS3 setup. It may be that it is trying to go to 1080p or something because it is the HDMI, which wouldn't work on yours I bet. See if you can disable the higher resolutions and try the HDMI again to see if you can get the 720p to work. Hope this helps!
    Oct 21, 2009 | Sylvania LC195SL9 19 in. LCD TV
    Ps3 not conecting on 2 samsung tvs
    Your ps3 could be in component mode. You will have to hook it back up on component mode, and go to the ps3 menu and change the setting to hdmi.
    Aug 11, 2009 | JVC LT-37X776 37 in. LCD HDTV
    I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
    Adjust the system's video output settings. Select the best output settings for the TV in use.
    1. Check the resolution supported by your TV.
    Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
    2. Select (Display Settings) under (Settings) in the home menu.
    3. Select [Video Output Settings].
    4. Select the connector type on your TV.
    Resolution (video mode) varies depending on the type of connector used.
    Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1
    HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p
    Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i
    Composite / S Video *3 480i 576i
    AV MULTI / SCART *4 480p / 480i 576p / 576i
    *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
    *2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
    D5: 1080p / 720p / 1080i / 480p / 480i
    D4: 1080i / 720p / 480p / 480i
    D3: 1080i / 480p / 480i
    D2: 480p / 480i
    D1: 480i
    *3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
    *4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
    5. Change video output settings.
    Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
    6. Set the resolution.
    Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
    * The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
    If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
    If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
    7. Set the TV type.
    Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
    8. Check your settings.
    Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
    9. Save your settings.
    The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
    Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
    HDMI Input only reads Digital TV and not PS3 or AV Receiver
    Well, I won't take the credit of others. Many people have the same problem as you do.
    In the search box on the top of this page, put in " PS3 HDMI ". The one that has the 10 solutions so far has the best answers for you.
    Good Luck
    Feb 16, 2009 | Philips 52 In. LCD HDTV
    I'm getting an invalid format on my hdmi inputs when i hook up my ps3. It's wierd because it works on my viszo, but not on my new westinghouse or my samsung.
    If you accidentally set your PS 3 for 1080p resolution, when the TV can only support 720p, you get a black screen. The Westinghouse TV I used displayed a message that said "invalid format." To reset the PS 3 to the standard AV format, you shut the PS 3 off. Then you hold the PS 3’s power button down for about 10 seconds. It will reset to standard video
    Dec 27, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
    Televison & Video Logo
    4,188 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
