Question about Orion 8209264 Slow Cooker
Need cooking grates - Orion 8209264 Slow Cooker
  • 2,200 Answers
Parts for these can be difficult to obtain - you may have some luck if you enquire at ACE hardware or Bass Pro as both of these chains are stockists of these products.
However, I would recommend that first you make contact with Orion directly by phoning them toll free at +1 (866) 891-3663 to explain your parts requirement as they are best positioned to advise.
They also have an email contact on their website at this link
http://orionoutdoors.com/contact/
Hope this helps. Please do rate this answer. Many Thanks.
Posted on Sep 04, 2009
  • Radio Code Pro
    Radio Code Pro Sep 05, 2009
    Hi
    I see that you only rated this solution as two thumbs. I can assure you if you cannot get this part directly from the manufacturer of these cookers via the details provided then I am not sure what else you can do.
    I would be greatful if you could either reconsider the rating you gave this free answer or otherwise provide more details as to what your exact expectation is with this question and I will be glad to try and help.
    Many Thanks.
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
Vegetables take hours to cook. Something wrong??
what do you have your setting on the crock pot for maybe you need a higher setting for them.
Mar 11, 2013 | Rival 38501 Smart Pot 5-Quart
I pushed the cook time button but it still says zero what do I do
Hit the on/off button, so that the cooker looks like it is off, then hit the cook time button up the the number of hours you need to cook. This slow cooker has three settings: LOW, HIGH and WARM..... When your corningware slow cooker is initially plugged into a wall outlet, the display will show "0". This display indicates the programmed number of hours for which ameal will cook. The slow cooker can be programed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears. If 1,2,3,4,5, or 6 hours are selected, then the slow cooker will operate on the high setting. If 7,8,9, or 10 hours are selected then the slow cooker will operate on the low setting. To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the warm setting.
May 11, 2010
Nov 19, 2012 | CorningWare SC60 Slow Cooker
Tried to make lamb shanks with a cook time of 6 hours on high and 6 hours on low. All the liquid evapored and everything burned. Pot lid was bouncing up by steam during cooking. What's wrong
It seem you may have cooked it too long... also one MUST keep an eye on the liquid level at least a few times during the cook. If you need this long a period it is suggested that you not use HIGH for all that time, try High for like 3 hours and the rest at simmer.
Feb 17, 2010 | Rival 38601 Smart Pot 6-Quart
How long to cook in a Tower compact slo cooker (old model)
As to the the slow cooker recipes...Try going to www.goodbks.com and search for "Fix-It and Forget-It" cookbook for starters.
As to then 4 or 8 hour timing I'm assuming you don't have an owners manual for it. I would start out treating it as a 4-hour timer and adjusting the times for various dishes aas you learn the cookers "personality"
Hope I helped a little!
Nov 12, 2009 | Crock Pots & Slow Cookers
Do you need to increase cook time when doubling a vegetarian chili recipe in a slow cooker
yes you do need to increase the cooking time if you put twice as much in the pot, it take a lot longer to cook it all, the problem is,, just how much longer will it take? and thats by trial as nobody can realy tell that
Nov 08, 2009 | West Bend 84716 6-Quart
My CEPC800 developed a blister on the cooking insert.
hello. you can get a replacement from:
Applica Consumer Products
1-800-231-9786
Aug 05, 2009 | Crock Pots & Slow Cookers
Need directions for presidents choice slow cooker
Heat intensity is warm, 1, 2, 3 (highest)
How to operate: Plug in. Set timer to amount of hours to cook. Press the SELECT button to scroll thru 4 settings - "warm", "1" (Low), "2" (Medium)", "3" (High). Once the desired cooking temp selected, press the "round circle" power button to begin cooking. The time display will now start to count down to "0:00" When the cooking time has been reached, the slow cooker will automatically go into "warm" mode for a maximum of 6 hours, then automatically turn off. NOTE: Not recommended using the WARM setting for more than 4 hours at a time. NOTE2: To stop the cooking process at any time, press the "round circle" power button. The unit will default to "0:00" time but the indicator light in the "3" high position will remain on.
Apr 11, 2009 | Crock Pots & Slow Cookers
I need a manual for a west bend 3qt 84114 slow cooker
what do you need to know, they are so basic that I don't even think they have a manual. Very strate forward . Check out some cook books, or a crock pot cook book, that will solve you needs, and teach you to cook at the same time. Happy cooking.
Orion 8209264 Slow Cooker Logo
79 people viewed this question
Top Orion Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you an Orion Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
