Have a 1 year old desktop computer running Windows XP Home SP3. Have had absolutely no problems with it until now. For no apparent reason, got the "blue screen of death". Tried fixes from the Microsoft website, online sources, and personal experience, to no avail. Tried to run XP installation disk in order to use recovery console to attempt repair. The reinstallation was progressing fine then froze, and the only way to restart the operation was to turn off the machine and restart. Tried this routine many times, all failed. Even replaced the hard drive with new, thinking older one had somehow become corrupted. Removed the suspect hard drive from case and replaced with new one. Ran the installation disk that came with the new hard drive and it would not boot up, even though BIOS settings had been changed to make the CDROM drive boot first. Ran XP disk again and installation was progressing smoothly, then froze again. The anti virus was up to date before any of this started. Also was prompted at several points to "restore to previous date" or something like that, which also lead nowhere. Also had opportunity to try things in safe mode, which also failed. My technical experience is intermediate. It seems that the more attempts to rectify the issues, more problems crop up. Cannot even get machine to run in safe mode now. There are 5 steps in the installation process: 1)Collecting information 2)Dynamic update3)Preparing information 4)Installing Windows 5) Finalizing installation. It is at point 4 that install freezes and/or blue screen appears and goes thru a restart again and again. I am furnishing ALL the information I can in order to hopefully lead to a repair.
    President:
  • 1,996 Answers
Many blue screens are hardware related: faulty ram modules, failing hard or optical drives, etc. If you are able to note the stop error code from the blue screen, it goes a long way toward identifying the cause.
See this article for help, ( and this one.) though it may be too late now.
Normally you can open the advanced startup options screen during boot (F8) and disable the automatic restart on system failure, so that the blue screen is readable, to get the required error code.
You could try removing all but the minimum ram from the system, unplugging data and power cables to all drives except the hard drive, and doing a quasi- bare bones boot. You might luck out. Or try the bare bones troubleshooting installation outlined here.
That's the best I can offer at the moment. Sorry I have to run...
Ask at this forum: http://www.aumha.net/
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 05, 2009
Cannot use my original restore disc as my computer is running on windows xp service pack 3
That is because SP3 is a newer system than plain old XP.
If you follow the menu's through it will invite you to overwrite the XP3.
Have fun as if you do and haven't got SP3 on disk there is no more support for XP!
Dec 17, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
Lost SP3 windows xp home edition version 2002 how do i get it back or do i need to I have automatic updates turned on when I look at programs beside it ,there no file size? also how do I fix error...
If you mean no file size showing up in "Add / Remove Programs"
thats because it's integrated / uninstallable but registered.
Error: 0x80070005, is that when you access "Microsoft Update"?
As for repairing SP3 Read more here:
http://windows.microsoft.com/en-us/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
and you probably have to go for option:
"Manually installing SP3 using the Microsoft Download Center or a CD"
Good Luck
Jul 18, 2010 | HP Compaq Presario SR1620NX...
Dimension 5100 and windows xp pro SP3 clean install
I was able to dig this up.
Reference: http://4sysops.com/archives/tip-how-to-install-and-uninstall-a-program-in-safe-mode/
Run Windows in safe mode.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\
Create a registry key REG_SZ key and call it MSIService and value data and call it Service, which is the windows installer. This will give you permission to uninstall windows service Pack 3 from add/remove programs while in safe mode.
May 09, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Well if you have it installed on the computer and cant get past the Windows logo. Put the SP3 disk in and do a repair. Make sure you hit -R and not the repair button after clicking continue. Well the directions for a repair will be on the screen. That is my thoughts on what you should do. If you have already done this, then I'm not sure where you should head to next. Hope this helps!!
Mar 17, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
HOW DO I BLOCK AN IP?...IM GETING HACKED, IT WONT STOP
The easiest means to block IP addresses in Windows XP is to use Internet Protocol Security (IPSec) filtering rules. The primary reason to block IP addresses is to protect your computer from network-based threats, such as computer worms, viruses and other malware. To block IP addresses in Windows XP, you will need to activate and configure IPSeccmd, the firewall that comes bundled with Windows XP. IPSeccmd does not come preinstalled with XP on your computer. It can be found on Disk 2 of your service pack upgrade or downloaded from Microsoft directly.
  1. Install IPSeccmd from your Window's XP Service Pack 2 installation disk.
  2. Step 2 Open the Command Prompt on your computer by selecting "Start > Run" from the primary file menu and type the word "cmd" in the blank text field that appears.
  3. Step 3 Enter the following command at the DOS command prompt to block a specific communication type (UDP or TCP) and port number on your computer:
    "IPSeccmd.exe -f [*=0:PortNumber:Protocol]
  4. Step 4 Open the user interface for IPSeccmd on your desktop, and select the "General" tab under the "Policy" section. Choose the "IP Block" option and enter the specific IP address of the host(s) that you desire to block. Exit the application when complete.
Jul 07, 2009 | Microsoft Windows XP Home SP3 for PC
Unable to Expand a Folder from my XP CD that I NEED!
Have you tried to copy the compressed folder from the disc to your computer desktop and open it there? Give that a try and see if it works.... I have had this happen to a couple customers at work and I just copied the folder from the disc onto the desktop, opened it there and re-installed it. Or you could also try a repair install of the OS but it does carry the possibility of losing your data and programs.
Jul 03, 2009 | Microsoft Windows XP Home SP3 Full Version...
Hello there, please help with my problem.i
yes ofcourse you can download it from www.isohunt.com.
search there for windows xp sp3 and download it using vuze(you have to download it from the same site before downloading iso image of windows xp sp3)
cheers
Jul 01, 2009 | Lenovo ThinkCentre® A51 PC Desktop
Is there a fix for Windows XP Home SP3 crash? my computer crashes all the time, i can format but i thought that there may be a fix because this is a known issue and many people have the same problem. If...
To make it short, you can try un-installing SP3, but the reason you computer is crashing is due to a program that is having incompatibility issues. That doesn't meant that your programs can run on SP3, it mean your programs and maybe even your drivers were install when you had SP2 and they didn't like the service pack update. You can definitely try to find which programs or driver are causing the problems but I recommend. Do a full format(non quick) and then a fresh install of windows and then update windows, and also try to download the latest drivers from the manufactures website and then install your programs.
**So yes I recommend an operating system re-install.
May 14, 2009 | Microsoft Windows XP Home Edition
Windows XP pc running very slowly
To make your system run faster there are few things you can try.
1. clean out as much things from starting during system startup.
2. check your user profile, reduce your profile as much as possible. create a folder on the root of the C-drive and move as much stuffs off your desktop and mydocument.
3. Make sure you have enough disk space.
4. you can try to increase the virtural memory a little more.
5. last thing is get more memory.
Mar 31, 2009 | Dell Dimension 4600 PC Desktop
SP3 nightmare install
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07159&lc=en&dlc=en&cc=us&product=1127351&rule=24868&lang=en#
This should help you also
On March 6, 2008 Microsoft released Service Pack 3 (SP3) for Windows XP. Service Pack 3 contains all of the important Windows updates from previous service packs as well as additional updates that were released after Service Pack 2. To install Windows XP Service Pack 3 from the Internet on a home desktop computer use the Windows Update feature. CAUTION: If you have an HP Pavilion, HP Media Center or Compaq Presario desktop computer that has an AMD processor, your PC might encounter a startup problem after installing SP3 (or SP3 will not download from Windows Update). Before attempting to install SP3, install sp37394 - Microsoft Windows XP SP3 Upgrade Utility for systems with AMD processors . For more information, the following support articles from the Microsoft Web site can help: 322389 - How to obtain the latest Windows XP service pack (in English) 936929 - Release notes for Windows XP Service Pack 3 (in English) NOTE: One or more of the links above will take you outside the Hewlett-Packard Web site. HP does not control and is not responsible for information outside of the HP Web site.
Jan 25, 2009 | HP Compaq Presario SR1620NX...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
