Question about Amana NDG5800 Gas Dryer
My amana gas dryer is not heating - Amana NDG5800 Gas Dryer
  • 3,230 Answers
Well if your dryer tumbles, but there is no heat then you may please check out the following -
1. First of all you can check out for proper air flow - Check the vent for proper air flow by placing your hand over the exterior vent while the dryer is running. You should feel a strong flow of air. If not then check the lint trap. It is located either on top of the dryer or possibly just inside the door. Remove any lint that has built up in the lint trap. Cleaning the lint trap should be done regularly, even as often as after every load. Do not operate the dryer without a lint trap in place.
2. Secondly you can check out the Ignitor - gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
Post comments for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Posted on Sep 10, 2010
  • 70 Answers
SOURCE: no heat, dryer exhaust vent cleaned, still no heat, gas line is on
I think you have a gas dryer, and a bad ignitor.
Posted on Apr 23, 2009
  • 14 Answers
SOURCE: no heat-gas dryer--Amana
There is a flame sensor on the side of the flame housing. Jump the 2 wires out and see if the ignitor glows then. If so you need a flame sensor.
Posted on Jul 25, 2008
aborcass
  • 2651 Answers
SOURCE: Amana ALG443RAW Gas Dryer will not heat up.
you can remove the lower acess panel (2) 5/16 screws along bottom. youll get a good view of workings there. turn on dryer (make sure a heat cycle is selected. you should see the ignitor light with in a few secs. if not unplug the ignitor(small white connector maybe 6inhes back from ignitor itself) and with a meter ck for 110v in that connection when unit is turned on, if you do have 110volts , you hav abad ignitor. ifyou dont get 110 volts you need to check the thermostat(s) located on top of the heater box right above the ignitor, if no continuity you need a new thermo.
Posted on Mar 12, 2008
  • 91 Answers
SOURCE: amana alg643rb gas won't stay on
repl/ coils when bad does the same thing that it going on w/ your dryer
Posted on Jan 04, 2009
  • 84 Answers
SOURCE: my amana gas dryer (model # lg8519w2)has an
first check you exhuast. If you have access to the vent outsid where the vent termintes the check and see if there is no lint build up or make sure nothing is block the air flow to the outside(storage caontainers or anything that will block the airflow from the dryer to the outside)..if no blockage or lint build up, then i would change you gas coil vales. they are located on you gas valve. they are 2 black looking things. But make sure when if you change them,one of them has a metal sleeve that goes on the shaft...make sure you know whick one it came from and slide it back on there..sometime when you take the old oned out, itll come off with the coil. Just take it out and slid it onto the gas valve. Like i said tho, make sure you know whick one it came off from...but yeah, try changing you gas valve coil....if its an amana dryer then there should be that bottom panel to take off and the gas valve should be right there..hope this helps
Posted on Jul 27, 2009
I have AMANA NGD 5500TQ0 DRYER AND FIRES WON'T LIT
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 18, 2011 | Amana NGD5500TQ Gas Dryer
Amana dryer not heating up
heatman101
Nov 26, 2010 | Amana NDG7800AW Gas Dryer
My Amana NDG7800AW Gas Dryer won't heat up. The dryer is about 5 years old and we have no problems with it until now. Any suggestions?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 10, 2010 | Amana NDG7800AW Gas Dryer
Amana Dryer NDG5805AW heats for a couple seconds after starting then no heat HELP
heatman101
Sep 08, 2010 | Amana NDG5805AW Gas Dryer
My heating element in my Amana dryer will heat up for a few seconds, but then goes back out. What should I do?
heatman101
Sep 07, 2010 | Amana NDG5800 Gas Dryer
Igniter on Amana gas dryer ,,Not heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
wwtt
Sep 04, 2010 | Amana ALG643RB Gas Dryer
My amana gas dryer quit drying
heatman101
Aug 08, 2010 | Amana ALG643RB Gas Dryer
Amana LG4409L Gas Dryer: Ignotor comes on when
The igniter or gas valve could be defective.
Nov 18, 2017 | Amana Dryers
Amana gas dryer only heats first 20 minutes
Check your ducts that the heat blows out through. make sure there is no plug up in the dryer or in the ductwork.
You may have a problem with the termosensor or the high temp cut out safety switch/sensor. This sensor would be somewhere in the exhaust of the dryer.
Feb 04, 2008 | Amana ALG331RAW Gas Dryer
Amana NDG5800 Gas Dryer Logo
809 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
