Question about Whirlpool Duet GHW9150P Front Load Washer
Brown streaks I have the same problem. My daughter kept saying I was putting something in either the washer or dryer to make it happen. I don't know how to fix this. Any resolution from Maytag? This is too many people with same problem.
  • 415 Answers
On the front load washer what happens is once the load is done the door gets closed then this allow mold to stain the rubber baffle 1-10 ratio of bleach and water 90% water then spray and wipe all the folds of the rubber boot once you get it clean the staining left on the boot is only a visual issue but a good cleaning is in order this occurs when well mostly use cold water to wash.;......... after you wash is done allow the door to gap open to allow to cool down properly.
Posted on Sep 04, 2009
    President:
  • 1,776 Answers
Remove the water supply hoses and check the small screens inside the ports on the water inlet valve. Make sure they are clear of rust and debris. A common problem is the screens getting rusty and putting the iron oxide into the wash water causing brown stains or streaks to get on clothing and sometimes leaving a brown ring around the tub. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Brown streaks on laundry. possible loose drum?
It may be correct. This may also be caused by oil leaking from the washer machine. Perhaps the heat is burning the clothes leaving the streaks.
The common cause of this issue are oil leaks.
Dec 27, 2010 | Frigidaire FGQ332ES Gas Dryer
Brown streaks on my clothes after washing them
O.K. Here it is, I solved it. After calling whirlpool who was of no help at all, reading all links about the Duet washer and/or the Duet dryer, I finally solved the problem myself. I too, thought it was the washer but, upon close inspection, found the felt on the dryer had worn out in one spot. The thin brown lines always showed up on whites and more so on anything very thin. I took the dryer apart and found a small burn line on the drum (brown and thin). I replaced the felt ($60) and used Simple Green to clean off the brown. Works perfect, no more thin brown lines. If you can't take the dryer apart, I called for repair and found the price with parts to average $250.
I was ready to sell the darn thing after it ruined about $300 worth of clothes. All in all, it's been three weeks and still working fine.
May 19, 2010 | Washing Machines
Whirlpool duet dryer mod gew922507pw1 lleaving brown streak on cothes
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer/Dryer get brown streaks on clothing
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Brown streaks on clothes
do you have the matching dryer on the earlier models they didn't use a seal on the drum and once the paint rubbed off they left brown rusty looking marks on the clothes
Jun 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Brown streaks on white clothing in front loading washing machine
more than likly it is coming from the dryer. get a paper towel or a towel and run it between the inside of the drum and the front where they come together. stick it through the slot and run around the drum. do the front then do the back see if you see the same streaks. and let me know thanks
Jun 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Brown streaks on clothes from dryer
is it possible that something was left in a pocket that ended up in the dryer check inside the dryer for any ink gum or stains inside the drum because there is no way the dryer left these stains other than from something you accidentally put inside
Feb 16, 2018 | Maytag Dryers
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Check an earlier post of mine. This problem was killing me and Whirlpool was of no help at all. They claimed to never have heard of these thin brown streaks. Well, it was the dryer and as proof, I found where the thin brown lines were coming from. The felt had worn out in one spot allowing thin, whites and other thin items to slide in between the drum and the backing, resulting in the transfer of a thin brown line randomly on my clothes. Replace the felt (rollers and bearings if necessary) and with the drum apart, clean off the burnt brown streak of the backing with Simple Green. No more problems.
Aug 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
439 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
