Question about Frigidaire 24" Built-in Single Electric Wall Oven - Black (Special Order)
Frgidaire Wall Oven Door Hinge screws loose; won't tighten
I have a Frigidaire Electric Wall Oven (new in 2003) on which two of the three screws in the lower door hinge (side swing door) are loose. However, when tightened, they continue to spin, indicating that something on the other side of the oven front that they go into, is not holding (nut or threaded hole?).
I can easily take the door off, but don't see (easily) how to determine what the problem is on the "other side" of the front. Result is that the door doesn't swing quite level to open/close.
3 Suggested Answers
SOURCE: Frigidaire wall oven FSC88W-5 The door is open
i have a feb386wech frigidaire wall oven that the left door latch came out and will not latch an stay in place
Posted on Aug 11, 2009
  • 1531 Answers
SOURCE: Wall oven door hinge springs
YOu will have to replace the door hinges.The part number you will need is 318024714 should run about thirty dollars for the set.
Posted on Dec 14, 2010
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
Putting door back on but hinge wont release to put back on
Hi Susan, this is AP! Thank you for your post.
I understand you are having trouble putting the door back on your Frigidaire wall oven. Without knowing exactly how you removed the door I cannot say with certainty how to reattach the door. However, when removing the door did you pull up the lock located on both hinge supports and engage it in the hinge lever hooks? You might have had to apply a little downward pressure on the door to pull the locks fully over the hinge lever hooks. Then grab the door by the sides and pull the bottom of the door up and toward you to disengage the hinge supports. If so, then to reattached the door grab the door by the sides; place the hinge supports in the hinge slots. Open the door to the fully opened position. Disengage the lock from the hinge lever hooks on both sides. Make sure the hinge supports are fully engaged before unlocking the hinge levers. Then close the oven door. There are instructions with images to remove and replace the oven door in the owner's manual. I hope this information proves helpful for you.
Mar 14, 2014 | Frigidaire FEB30S6D Electric Single Oven
I have the SC272TB Double Oven. The top oven is fine but the lower one will not stay closed. Whether baking or not, the door seems to pop open just enough to turn the light on. We walk by and press the...
Welcome to FixYa.
Yes this has been a fairly common issue with the Thermador wall ovens as well as their freestanding ranges.
Typically the remedy will be replacing the hinges, but there is a "fix" you can attempt in the interim. At least in hope of keeping the oven light from being on all the time, hence damaging the control board which houses the oven lights transformer.
The issue with those Thermador wall oven and freestanding range doors ( especially on the freestanding "professional" line ) is the weight of the door is so great, the hinge will actually move slightly over time, other times the entire hinge will need to be replaced.
This is what I'd recommend ( also official Thermador remedy, rest assured as I am a authorized factory trained Thermador service provider ) before pronouncing the hinges need replacing though.
**This does require a somewhat involved repair, so if you don't feel completely comfortable or have any reservation to trying this, please call in an local authorized Thermador ( B/S/H/ ) service provider.**
Recommendation: Adjust the door box hinge per instructions below.
1. Pull the oven away from the wall about 12".
2. Remove the hinge box cover plates.
3. Remove the vertical side trim piece. It covers one of the screws that must be loosened.
4. Loosen the 4 screws that secure the hinge box.
5. Place a rolled up dishtowel at the bottom of the door and close the door and apply light pressure to the door while re-tightening the four screws.
See fig below
6. Re-install the hinge box covers & side trims.
7. Re-install and secure the oven.
That should do it, ( or as stated, improve the situation ) if the hinges are too far gone they will need to be replaced unfortunately.
Let me know if you require further assistance or if indeed this solved your problem.
Thank you for choosing FixYa today and good luck going forward.
Regards,
Macmarkus :)
Jan 26, 2011 | Thermador C302U Electric Double Oven
Is there any way to tighten this door up ,the one i have comes down just a little and the light comes on
Hello, Welcome to FixYa. Yes this has been a fairly common issue with the Thermador wall ovens as well as their freestanding ranges. Typically the remedy will be replacing the hinges, but there is a "fix" you can attempt in the interim. At least in hope of keeping the oven light from being on all the time, hence damaging the control board which houses the oven lights transformer.
See fig below
Regards,
Macmarkus :)
Jan 06, 2011 | Thermador SEC271BS Stainless Steel Single...
Last year, my 8 year old Whirlpool oven door would not stay closed all the way. I ordered new hinges, replaced them and it was great for 11 months. Still under warranty, I replaced them a second time......
Are you replacing the hinge guides as well? The hinge is usually only one half of the problem. When you remove the door, look into where the upper long arm of the hinge resided. You will see a little runner wheel. Touch it with a thin screw driver and see if the wheel feels loose. I'll bet at least one of them is!
Jun 25, 2009 | Frigidaire 24" Single Gas Wall Oven with...
Bosch Oven Door Problem - doesn't close at top
On our oven (Bosch Evolution 700 Series HGS7152UC), the problem was getting worse and worse. I found it is was worsening simply because the hinges had started to come loose. I removed the door as suggested above, and although there are no adjustment screws on this model I tightened the now-loose hinge mounting screws. For each hinge there are three screws altogether: two (phillips heads) on the bottom of the door and one (torx head) on the inside wall of the door. After tightening those screws it is a lot better, only leaks as much heat as it did when it was new which is tolerable. Still a bad design.
Mar 02, 2009 | Bosch HBL 742 / HBL 746 Electric Single...
Loose Oven door handle
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Nov 14, 2007 | Bosch HBL 742 / HBL 746 Electric Single...
Electrolux Oven EOG9330
Hope this helps (technique used on EOG9330XN):
1) With the door open, on each hinge, there is a top cover which lies flush with the hinge. Simply swing this cover up and back towards you. This unlocks the hinge. Undo both and carefully close the door, holding it at the bottom. The door should be able to be pulled away from the frame now. Lay the door on a flat surface.
2) The oven will normally be attached to the surrounding built-in cupbpard. If so, unscrew all attachment screws (mine had at least three per side) and pull the whole oven out about seven inches, supporting if neccessary. Each side panel has a locating screw in bottom front corner, so remove the screw. Peel back the side panel (only thin alloy, but watch for sharp edges) sufficiently to see.....
3) The two side securing screws for the door hinge receiver should be visible. After pulling receiver forward, if loose, tighten securing screws (use lock washers if available, as Electrolux don't provide them).
4) Reverse the procedure to finish job, fitting the door in the near vertical position to engage hinges in the receivers. Support the door, lower to open position and flip the locking hinge covers back.
[This technique works if the hinges aren't worn and if the door doesn't close properly, it usually means that the receivers are loose and have been pushed back into the oven frame].
Apr 11, 2006 | Electrolux EOG9330 Gas Double Oven
Frigidaire 24" Built-in Single Electric Wall Oven - Black (Special Order) Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
