Question about HP Photosmart M415 Digital Camera
Hp m417 shutter problem.
What can i do to fix my camera? :-/
the problem is that when i turn the camera on, the shutter doesn't open automatically. i have to zoom in first, then shoot. after that i zoom the camera out and pray that the shutter would work right. if it does, the great. but if it doesn't, omg, my pix would have stripes all over it. the shutter doesn't shut properly i guess...
so again... what can i do??? :(
  • 3 Answers
I had the same problem but it cleared up after a phew weeks on its own awkwardly, but the only advice i can give you is to open it yourself before you start taking pictures.
Posted on Apr 08, 2008
SAMSUNG S1070 - When I take pictures, white lines appear on them. They don't appear on the screen when I am not taking a picture, and they do appear when I transfer them to my computer. I have tried...
How do outdoor pictures look when taken with the camera? If overexposed, first check that your camera is in automatic mode, and not some other manual exposure mode of the camera. Next, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 29, 2011 | Samsung S1070 Digital Camera
Shutter appears to be stuck closed.
Theirs oil on the shutter blades causing it to stay closed, Thats why you can't see though the lens or the viewfinder also, This comes from the grease from the zoom assy, It's a major job to fix it, Has to be fixed by a repair shop
Jun 04, 2010 | Canon PowerShot S3 IS Digital Camera
Shutter will not open to take the picture
there must be dust or rust in lens cover so with the help of the finger open it if the image no appar see the sutter or ccd
Sep 08, 2009 | Kodak EasyShare Z730 Digital Camera
Panasonic FX-01 Lens zoom ring (around shutter release) loose on
must to open ur camera and completly open that lense and clean well all gears then fix it back it will work
Jul 11, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Canon powershot s2 15 shutter won't open
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
May 10, 2009 | Canon PowerShot S2 IS Digital Camera
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Shutter won't open/close, and blank screen on "capture."
It prolly took a bump at some point or has crud inside...try cleaning it GENTLY with alcohol NOT WATER.
Aug 27, 2007 | HP Photosmart R727 Digital Camera
Noise Reduction
This function reduces the noise that generated during long exposures. When shooting night scenes, shutter speeds become slower and noise tends to appear on images. When noise reduction is turned on the camera automatically reduces noise to produce clearer images. Since shooting time is approximately twice as long as usual, noise reduction is only activated when the shutter speed is slower than 1 second.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
HP Photosmart M415 Digital Camera Logo
44 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
