Paper is out of range Samsung printer when printing in word it always says paper out of range
  • 22 Answers
Check your default margins on the printer. Open Word, open a document, click on File then Print. When the printer's printing window opens, click on properties. You should now be able to see the Margins or a Margins tab in the window. Check you margin settings. If they are below .5" in any of the 4 margin settings then you printer probably cannot print the document. Change the settings and save them as the default settings.
You may also try updating your printer driver, too, depending on how old your printer is.
You should also check the settings for the paper type you are using. If it is not the normal 8.5" X 11", then you will need to change this setting as well.
Hope this answers your problem.
Posted on Sep 05, 2009
Testimonial: "Thank You. I was able to fix it by going into page setup and changing the margins. I have a vista operating system Thank you again"
Hi i want printer setting in epson LQ2090
Posted on Jul 01, 2010
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
My samsung ml-1610 printer always getting paper jam on print job. Is this problem related to fuser or something else? please help me...
There are a series of rollers which are made of rubber in the unit. When these rollers become dry or covered with dust (usually from cheap paper) they arent able to pick up paper correctly any longer.
Think of it as though you are trying to turn a page, and you have to lick your finger to do so.
Its the same concept. When your printer grabs the paper, it cannot hold it while it is rolling it through the printer.
There are kits available through your manufacturer or a local print shop which can clean your printer and help to restore it to its working order.
Hope this helps!
Feb 23, 2011 | Samsung ML 1610 Laser Printer
Page is not loading during printing
Occasionally, paper cannot be load during a print job.
Some of causes include:
• The tray is overfilled.
• The front cover has been opened during a print job.
• Paper that does not meet paper specifications has been used.
• Paper that is outside of the supported size range has been used.
If a paper jam occurs, the On Line/Error LED on the control panel lights red.
Find and remove the jammed paper. If it is invisible, look inside the printer.
Note: U would find the complete instructions along with the screen shots in the below link
http://tinyurl.com/notloading
Best of Luck
Dec 05, 2010 | Samsung ML 2010 Laser Printer
Printing on 394mm length paper
put, the margins to 0. and customize paper a little longer, more 5mm each side, top and bottom
Jan 09, 2010 | Office Equipment & Supplies
I hv samsung 3160 fn & HP laserjet 1008 printers installed on one system.when i am commanding print to HP 1008 by selecting HP 1008 printer from all printer menu.my HP printer always blinking orange...
Just pull the ink toner and check there is not any paper jam also check in back side of printer for paper jam.
Refix toner cartrdge in its position.
Tehn check.
Jun 07, 2009 | Samsung CLX 3160fn All-In-One Printer
Scorching paper
fuser exit rollers faulty
Jun 03, 2009 | Samsung CLP 300 Laser Printer
ML1610 SAMSUNG PRINTER PROBLEM
The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do
Sep 13, 2008 | Samsung ML 1610 Laser Printer
Printer saying paper jam, checked it out, there is no paper in it
Always it is giving the same error are,sometimes after some print outs?
IF it is always then u need to open the printer.
Regards
T.Boopathy
Aug 06, 2008 | Samsung Office Equipment & Supplies
Paper empty message when pdf
Could be a page size problem.
A4 paper in the paper tray, but what page size does the PDF think it is?
Dec 30, 2007 | Samsung CLP-510 Laser Printer
Samsung CLP 550N paper jams
Make sure the paper guides are not too tight and always fan the paper to rid static build-up before loading.
Jan 19, 2006 | Samsung CLP-550N Laser Printer
238 people viewed this question
k24674
jasbo
jasbo
