Question about HP Pavilion dv9000z Notebook
HP Pavilion Notebook Monitor display is green and have not been able to get back to blue . The computer is working but you can not see the icons, text, etc very well.
  • 448 Answers
Try uninstalling the display driver from the Device Manager then restart the Computer. After restarting the Computer, reinstall the display driver.
Perform the steps given below to access the Device Manager:
(i) Please press the Windows logo on the Keyboard and then press the "R" key while holding down the Windows logo key to open the Run dialog box.
(ii) Then, please type "devmgmt.msc" in the Run dialog box and click OK to open the Device Manager window.
(iii) Click on the plus sign next to the "Display Adaptor" category to locate the display adaptor.
(iv) Right click on the display driver then click Uninstall.
You can download the display driver from the support site of the Computer manufacturer.
Posted on Sep 05, 2009
I have an hp pavilion dv9815nr notebook pc. My laptop turns on, but when I enter the first letter of my password the screen goes black. Computer sound like it is still running but just black screen
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 30, 2012 | HP Pavilion dv9815nr Laptop
Hp Pavilion DV-4000 Screen
Are you saying the lcd screen is black? It seems like it booted up but nothing appears on the screen?
May 03, 2012 | HP Pavilion dv4000 Notebook
Hp pavilion dv200 it powers on but no displaying
Apr 26, 2012 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp dv6833 laptop boots up fine but after that it display complete white screen then after sometime Blue...then Red ...then Green etc. this pattern repeats in a cycle.
Hi, have you tried isolating by using external monitor? if you use external monitor and it displays then something wrong with your built in video card.
Jun 16, 2011 | HP Pavilion dv6833us Core 2 Duo T5550...
I have an HP dv6707us laptop. The display started getting fuzzy and turning redish and would fail to display anything after a few minutes. I plugged in an external monitor and it works fine. I disassembled...
The screen replacement is defective or the part number is wrong, check the part number on the back of the original screen and compare it against the the one you replaced, it should match.
Jun 15, 2011 | HP Pavilion Dv6707us Entertainment...
I have an hp pavilion a720n desktop with an hp pavilion mx70 monitor and windows xp home. There is a problem with the color displayed on the monitor. I see mainly black and white, but blue shows up fine....
First of all you can check the computer by connecting another monitor to it to see if the problem goes away...if so then the problem would be in the monitor. If not , then I would try to change the video grafics card in the computer(assuming you don't have built in video). If you have built in video on the mother board then you will either need to replace the motherboard or disable the onboard video and install a video card
Dec 19, 2010 | HP Pavilion MX70 17" CRT Monitor
Using notebook display and external monitor: HP Pavilion zd8205us primary display is garbled, secondary display is clear and good, It doesn't matter which display device you set as primary or secondary
try to switch the blue VGA cable that is connected from the laptop to the external monitor. You may also restart your laptop and set aside the external monitor to check if the laptop is still experiencing garbled display... If it still is, then it is a monitor issue and need to address to HP personnel by calling HP hotline. Otherwise your issue will be resolved by simply doing that..
Nov 14, 2010 | HP Pavilion zd8000 Notebook
Screen is black when I turn on notebook
Sounds like you may have the monitor set to an external monitor. look for a Fn key and press it in combination with the monitor key - typically located near the F8 key it should be an icon in blue that looks like a monitor. press this combination and see if it comes back up.
Aug 29, 2010 | HP Pavilion dv6000z Notebook
Hp slimline pavillion 1503 LCD 15"
plug the speaker cord into the LIME GREEN port on your computer.
Click on the speaker icon at thee bottom of the display to make sure you are not MUTED.
Dec 19, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Display does not show the color green. Green comes in as black
why not use a known good monitor
in 1 minute flat the truth.
not only that you can move or bad monitor to another pc
and see if it works.
also the cable can be bad.
Mar 13, 2017 | HP VF15 15 in.
HP Pavilion dv9000z Notebook Logo
136 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
