Question about Electrolux Vacuums
I have a clog inthe main tubing. It is from a
I have a clog inthe main tubing. It is from a package of cotton make up pads that were sucked up when vacumming the bathroom on the second level of our house. I checked the vacuum outlet on the second level, the main level and the basement level and their is no suction when I plug the hose in. What can I do? Please help. Deb
  • 143 Answers
Slide your garden hose up the length of the tubing after laying the tubing flat in a straight line. If the blockage is in the hose this will detect it. It may be necessary to hook the blockage out with a length of wire.
Posted on Sep 13, 2009
SOURCE: my hoover floormate won;t suck/ suction anything!
I had the exact same problem and was on my way out to purchase a new one when I came across solution #1. I decided to check the hoses more thoroughly and discovered my problem. I released the handle to extend the hose and, using a flashlight, inspected the inside of the hose leading to the dump tank. Sure enough, there was a clog where the hose attaches to the nozzle that I never would have seen without a flashlight. Works good as new!
Posted on Apr 12, 2007
chrispurs1
  • 372 Answers
SOURCE: no suction when vacuming floors
Hi.
There are 2 types of Dc07 one is clutched & has two belts the second has only one belt going from motor to brush roller.
Lay machine on its side pull back handle as if you are to vac carpet switch machine on look to see if brush roller is spinning.
If it is not spinning unplug machine from mains supply & remove the sole plate by turning the three plastic screws to unlock position, Lift sole plate away if you have non clutched machine you will now see the brush roller with A belt going from this to the motor shaft belt may have snapped or come off so replace it.
If your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive.
If you still have no brush rotation after doing all this then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
There are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/index.htm
Posted on Jul 05, 2008
SOURCE: shop vac sucks water for a few seconds then it spits it back out
Don't use the paper filter for sucking water. It can ruin it. It will still be usable if you just set it out to dry but there is no reason to use it for water in my experience. I have a sears shop vac and it will fill up more than half full without ejecting the water.
Posted on Mar 15, 2009
woobie dog
  • 1273 Answers
SOURCE: Hoover U6476-910 - Very little suction from the bottom
If you haven't already, remove the beater bar. This is accomplished by unplugging the vacuum and turning it beater bar up. Remove the clips or screws that hold the plate on the beater bar and set aside. The beater bar sits in sockets, so carefully remove the bar, noting the correct position of the sockets. This will make reassembly much easier. Slip the beater bar out of the drive belt. Now, inspect the suction cavity that the beater bar would discharge into. Usually, things clog up here as there is a flex hose that catches things, creating a pluggage.
Hope this helps, --W/D--
Posted on Jul 18, 2009
  • 11 Answers
SOURCE: BEAM VACUM DOSE NOT WORK GOOD BECAUSE SOMETING SUCKED IN THEIR
Check to see if you have suction at the outlet, if so
the plug is in the hose or wand. If no suction at the wall, check at the vacuum. If you have suction at the vacuum then the line from the vacuum to the outlet
that you were connected is where the plug is.
Try a plumbers snake to try to get plug out.
Tom
Posted on Oct 22, 2009
Vacuum will not suck when hose is put on
Bill:
Check the tube that you plug the hose onto... it's probably clogged with junk. The tube goes down to the tunnel that contains the beater bar at the front of the vacuum head. Also, the vacuum head must be flat on the floor when using the hose or there will be no suction at the hose.
Jan 08, 2015 | Vacuums
The main machine is not sucking up dirt but you can use the hose with an attachment and it still sucks up o.k.
There's probably a clog in the tube in the power nozzle. Detach hose and drop a marble or similar size object down tube. It should roll through and out at the brush. If not, there's a clog and it needs to be removed.
Oct 06, 2010 | Dyson Vacuums
Vacuum sucks up dirt and expells it back onto the carpet as I am using it. I have replaced the bag and took the bottom off to clean - even cleaned up the area where the dirt should go to make sure it was...
Good chance the tube from the base up the handle is clogged. Try removing the bag and look at the exit, that is where most clogs on this unit occur. Look for hair, string, etc. If clog is not there, then may be in the tube or at the base swivel unit to the tube interface.
Once you clear the tube, re-attach bag an d power up unit, be careful that it does not throw some debris at you.
Oct 14, 2009 | Oreck XL2600 Vacuum
I just bought a new belt for my vacuum and have a brand new bag in and it isn't sucking anything up.
1 - make sure that the belt is installed properly and brush roll is spinning as you are vacuuming.
2 - it is not unusual to have a clog in the miniemptor / fill tube assembly - black plastic shoe-like bag bottom part with tube (you can see it HERE)
3 - Sometimes something gets caught in in the exhhaust - part of the main body where you install the bag. Take coat hanger and run through it. Once I have pulled a sock out of there and I could nor see or reach it without the wire...
Rocky
Aug 09, 2009 | Kirby Ultimate G Bagged Upright Vacuum
KENMORE pROGRESSIVE WITH DIRECT DRIVE SUCKING NOISE
I had the exact same problem. The port is a relief valve to prevent the motor from burning out if the hose/bag are clogged. Check the main hose from end to end after removing the 3 screws that hold it to the body of the vacuum near the handle. If that's clear then it's almost certainly clogged in the short tube that goes from the beater bar housing to the hose extension (where the flex tube attaches). There are two ways of going about this.
Option 2
(the way I did it) -- Lock the base on the upright position and turn the unit over. Unscrew the 12 or so screws in the black base. You'll need to depress the release pedal when removing the screw at the end of the pedal. Once you have all of the screws removed carefully wiggle the base loose. You do not need to remove it completely to access the short flex tube. Clean it out and replace everything in the opposite order from how you removed it.
Option 1 (what I would do next time) -- Cut a wire coat hanger and make a small 1/2" hook at the end. Bend the straight section into about a 4" radius arc leaving plenty to handle at the end opposite the hook. Carefully snake the hanger down the tube and pull out the giant clump of hair and dirt that's clogging the vacuum.
cheers -- eric
Nov 15, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuum will not pick up, the dirt just lays inthe bottom of the hose and does not get sucked up,i looked for aclog but there isn,t one
Are the filters clean? Is the brush roll turning? Otherwise check the dirt inlet by the brush roll for a clog. Pull the hose off from the bottom, is there suction there? If there is, then the problem is below where the hose is pullged into. If no suction, then there is a clog in the hose, take it off, (if it comes off completely), drop something like a heavy marble down the hose and see if it comes out or not.
Jun 16, 2008 | Dirt Devil Vacuums
Reginna Steemer Carpet Cleaner- older model- will not suck
Check for clog in motor intake. Take off the tank and look up into the motor. There will be a round tube with a plastic grate.
Feb 10, 2008 | Vacuums
Hoover doesn't suck well
Did you check the inlet from the bottom? Take the bottom plate off, make sure that the tube(inlet)is free of any clogs. Also if the belt is stretched, then it won't drive the brush roll like it should, replace it part #38528033.
Feb 04, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Hoover SteamVac V2 - won't release water
sorry this is so late. the problem might be that the tubes are clogged. after each use most people just put the machine away. in most cases the soap is still in the tube,and when it hardens it clogs the tubes. after each use you should run clear water to get rid of any soap in the tubes before putting away.
Aug 05, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Vacuums Logo
48 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
