Question about Whirlpool Washing Machines
I have the dog agits to replace Whirlpool top load washer LLR6233AWO I have the dog agits to replace in my top agitator and cant figure out how to take the top off the bottom
  • 432 Answers
On mine I pulled on the fabric softener plastic top.And under it was a cap. I pulled the cap off and looked inside to see a bolt (I think it was a 1/2" size. I needed a 1/2" socked and a 6" long extension and took the bolt completly loose. Righty tighty ,Lefty loosey. Then I just pulled up on big center plastic part and the dogs are under it. I hope this helps you.
Posted on Sep 04, 2009
    Problem Solver:
Only the bottom part of the agitator works the top does not move and the clothes dont circulate also there is a grinding sound
Posted on Apr 19, 2010
Whirlpool top load washer. Agitator seems to be wearing out. It barely turns now. if you apply pressure to top of agitator during wash cycle it will agitate. Sound like the agitator is stripped out so...
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. Here is a video this will walk you thru checking and replacing the agitator dogs . You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Dec 17, 2010 | Whirlpool Washing Machines
+whirlpool LSQ8243HQ0 water valve works. wont wash or spin. new motor coupling and timer.
Under the agitator you have what is called (agitating dogs). The agitator will have to be removed. The top should spin off, you will be able to look down into the agitator and see a bolt. Remove this bolt and the agitator can be pulled out. The agitators are small pieces of plastic with small teeth. These teeth get worn out over time or if the washer is overloaded. When the agitator free spins one way the teeth grab a (gear) on agitator and this is how you get the washing action (agitating). These dogs are easy to replace and cost about $5. If you need more info check out *how to replace agitating dogs)
Dec 15, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Top load whirlpool agitator isn't working. Have replacement dogs but I cant figure out how to get to the agitator. Beyond the fabric softener dispenser
The following link explains step-by-step how to replace the agitator dogs on a Whirlpool top loader:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
You can find exploded view illustrations of your washer at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
Enter your model number and use these illustrations to assist you with disassembly and reassembly of your agitator (if needed).
If you have any questions, please post back and let me know. I hope this helps you.
Apr 30, 2010 | Washing Machines
Problem for Whirlpool LXR9445JT Top Load Washer Whirlpool top-loader LSQ9200LQ0 The top half og the agitator is not turning.
Whirlpool has a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs or the agitator cam assembly. The following link explains what the dogs are and how to replace them:
The part number is included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. For the model number you have listed, the part number for the kit is 285811 and sells for about $11.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Dec 14, 2009 | Whirlpool LXR9445JT Top Load Washer
How to remove agitator cam from the upper part of the agitator?
Had same problem with my washer. Check to see if there are little plastic tags holding top/bottom of agitator. after replacing dogs just ensure that you realign with tags so they do not break off.
Oct 10, 2009 | Whirlpool LSN1000LW Top Load Washer
Top agitator won't spin
Your agitator dogs must be replaced.
With a flat blade screwdriver pry off the top cover on the agitator.
Remove the 7/16 bolt inside.
Pull up on the agitator and remove it.
Purchase the agitator dog kit from the appliance parts store.About $10.00.
Mar 10, 2009 | Whirlpool LSB6200KQ Top Load Washer
TOP LOAD WHIRLPOOL WASHER MODEL#LLR6233AWO
Check the agitator dogs, and the motor coupling
Jan 26, 2009 | Washing Machines
Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Agitator Dogs
Nothing is manufactured to last these days. What brand of dogs are you using ? FSP is the original brand and should be used. Also, check the inside of the agitator. Are the gear teeth in good shape ? It only take one bad tooth to destroy the dogs.
Dec 12, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
453 people viewed this question
Dan Webster
Dan Webster
Sal De
