Question about Samsung SBH-100 Wireless Headset
My SBH100 bluetooth stero headphones' light stays blue whilst charging and the unit will not turn on. I have been charging them for over 3 hours now and still nothing. I purchased the unit brand new last week from talklinesales on eBay. Any help will be grately appreceated. I would like to try and find a soloution to the problem before I have to return the item to the retailer. Maybe i've missed something in the instruction manual.
SOURCE: Can't Turn on/Charge
I had the same problem when I purchased mine. There was nothing to do except return it for a replacement.
Posted on Aug 08, 2007
SOURCE: can't power on
Same problem
Posted on Oct 24, 2008
SOURCE: wep170 won't turn on....when charging its blue and blinking
I have the same problem? some can help us ?
Posted on May 05, 2010
Strattrpt
  • 159 Answers
SOURCE: I am charging from new
This could be a problem with your battery. If you have ever let the battery TOTALLY discharge (left it dead for a long time because you couldn't find the charger or whatever) it may not be able to hold a charge any more. If this is the case, the charger will constantly try to charge the battery, but it will lose its' charge even as it is charging. If you can replace the battery that might help.
If your battery is new, and you are still having this problem, it could be a problem with your charger setup. The headset might be getting enough power to turn the light on, but not enough to charge the battery. Try cleaning the connections with an eraser (one on the back of a #2 pencil works great). Just erase any corrosion on the contacts, and your power connection should improve. Alternatively, you could buy a new charger and see if that helps.
If neither of the above issues is the problem, then your headset probably has a short circuit, and will not accept a charge. If it is new, there might be a manufacturer's defect in the wiring (it is rare, but these things do happen on occasion) If it is a defect in manufacturing, you should be able to get a replacement for free if you talk to Customer Service at Samsung. If you have to deal with sending your headset in to the company and wait for them to send out a new one, ask if there is any monetary compensation, or upgrade that they can give you for your inconvenience. A lot of the time manufacturers will either upgrade your purchase, or give you some sort of discount on a future purchase (or even a rebate on what you have bought) to keep you as a customer. They might not give you anything, but it doesn't hurt to ask :-)
Posted on May 26, 2011
  • 274 Answers
SOURCE: my bluetooth seems to charge up but will not turn on
Yes, when it is charged, light will turn blue.
It is alright.
electronics wholesale
Posted on Nov 09, 2011
My JBl Synchros E50BT Bluetooth headphones wont charge or turn on.
sadly the battery has possibly died and will never charge .
Oct 19, 2016 | Cell Phones
Why is my USB Bluetooth Adapter not showing up under settings?
Make sure the headphones are in the searchable mode or try searching from the headphones instead of the PC.
Oct 17, 2016 | Insignia Bluetooth Wireless Headphones...
Headset will not re-set according to instructions. Indicator light is half red, half blue. What should I do?
I had the same issue with green light always on and not turning off. Call button plus volume up button did not work when the unit was not plugged in. When I plugged the unit in to charge, the volume up and call button (together) did reset the unit.
Oct 14, 2015 | AUVIO Bluetooth Headphones
Can I connect to Vizio TV with blue tooth
If your ear buds have been connected to any device before your TV then it won't work. If you want to connect it to your TV you turn on your headphones, hold the call button for 3 seconds, and you will see ur light flash and connect it to your TV. If this didn't help then go to the manual and check how to connect your headphones to your TV.
May 24, 2014 | AUVIO Bluetooth Headphones
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
Bluetooth paired but not connected?
There are several kinds of Bluetooth Profiles. If you're only looking to send and receive phone phone calls, A Bluetooth headset only needs a Hands Free Profile or HFP.
The EM227 cannot be used as a stereo headset because a different Bluetooth Profile is required. If this is what you're intending to use it for, You may want to invest in Bluetooth enable Studio Headphones.
Try these steps to Troubleshoot the issue:
1. Make sure that your EM227 has been fully charged. the User Guide suggests that you charge the Headset for at least 5 hours before you use it for the 1st time.
2. Go to your device's Bluetooth Settings and scan for nearby devices.
3. Turn ON your EM227 Bluetooth Headset and place it in pairing mode. The Bluetooth indicator light will flash RED and BLUE.
Don't Forget to keep your Bluetooth Headset and your device within 3 feet of each other.
4. If your device asks for a Pass Code, try entering "0000" ( Four Zeroes)
Once you've paired the device, the LED indicator should now blink as a steady Blue light. Try making a test call.
Remember, The EM227 was only designed for Hands free calling ONLY.
Mar 15, 2013 | Emerson Radio Communications
How do I acitivate it
Charge your headset
Charge the headset's battery fully before using the headset for the first time.
1 Put the headset in the supplied charging case and close the cover.
2 Plug the travel adapter into the case's charging socket.
Put your headset in pairing mode
1 Ensure that the headset is off (see Turn headset on/off below).
2 Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Turn on Bluetooth on your phone and pair with headset
1 Set your Bluetooth phone to discover the headset by following your phone's guide.
Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200
headset.
2 Select Samsung WEP200.
3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK.
4 Enter the headset passkey or PIN, 0000.
Your phone and headset are now paired and ready to make and receive calls.
1 Place the headset over your ear.
2 On your phone, make a call to the number you want.
3 If your phone and headset are successfully paired, you will hear ringing on the headset
After you have successfully paired your phone and headset, you do not need to repeat these initial setup steps each time you use the headset.
To turn the headset on
Press and hold the Multi-Function button for4 seconds until you see 4 blue flashes on the indicator light, then release.You will hear a tone and see the indicator light flashes while the power is on.
To turn the headset off
Press and hold the Multi-Function button for 4 seconds until you see 2 blue flashes on the
indicator light, then release.You will hear series of 2 tones and see the indicator light stops flashing.
http://ars.samsung.com/customer/DownloadAnsTempl?AT_ID=70171&SEQ_NO=2
Jun 07, 2011 | Samsung Bluetooth?® WEP200 Headset...
Have blackberry flip phone, blue tooth worked fine,now shows bluetooth:disabled, can't get it to work HELP gene
Hi to enable Bluetooth follow the steps given below: 1. Click on OPTIONSfrom the main Menu 2. Click on Bluetooth then 3. Click on the Menu key (which is next to track ball) 4. click on Enable Bluetooth If you find any problem please contact the Service Provider of your SIM Thank you for using Fixya
Nov 13, 2009 | Cell Phones
How do you pair your Insignia Headphones/ Headset with a PS3? It is called an insignia NS-BTHDP/NS-BTHDST. In the instructions it only talks about pairing it with a computer. Can someone help me?
Go to Accessory Settings on your PS3.Then go to mange bluetooth devices and hit register new device. while doing this take your headset and put it in discovery mode. You do this by holding the power button and the it alternates between blue and red lights.It should work after that.
To test it go to audio device settings and see if it shows up.
Mar 26, 2009 | Insignia Bluetooth Wireless Headphones...
Bluetooth not picking up mp3
@psychurmine you may need to go into the settings of the actual music player application on your phone and tell it to output to headphones.
@ejr420hotora it could be several problems. Did you have it working at one point or is this your first time installing it? Is this your first bluetooth device or do you have others?
Feb 12, 2009 | Insignia Bluetooth Wireless Headphones...
Samsung SBH-100 Wireless Headset Logo
81 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
