Question about KitchenAid KAWS750L Top Load Washer
3 hours wash cycle
My front load moffat washer takes about an hour if I wash on cold and 3 hours if I wash on any other temperature.
    President:
  • 1,776 Answers
Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve ports. Make sure they are clear of rust or debris. Based on your description, pay particular attention to the hot water side. The solenoids can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Posted on Sep 04, 2009
Reduce time
you won't
most washers take an hour to wash a load
if you have a setting for low water and a light wash ,you might it down to 40 minutes
Jul 13, 2016 | Washing Machines
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
I just moved into an apartment equipped with a stackable moffat MCCH6110HSS washer and moffat 350A4502P547 dryer. I've discovered that the washer appears to repeat the rinse/spin cycle over and over again...
HI, I spent many years in apartment maintenance and most communities have maintenace staff to fix issues you have with their equipment,call the leasing office.The most likely cause is a bad timer.
Mar 06, 2011 | Washing Machines
I just moved into a furnished apartment with a Hoover washer. Please could you explain how to operate it. I have used it twice, but both times it took at least 3 hours to complete the washing.
this is probably because most front load washer heat the water. check if you can adjust temperature or turn off,or check if the washer has a quick cycle for example quick 30 minute cycle.good luck keep me informed
Jun 22, 2010 | Hoover AAA160 Front Load Washer
Front load washer FTF530FS1 stop mid cycle, sometimes for more then an hour, then starts up again, entire cycle can take more then 3 hours? Also during cycle is very loud.
Seems you have possibly 2 problems. One, check to see if the element is not faulty. If no heat during heating cycle, the washer wont proceed for a long time.. Two, if noisy, especially on spin cycle, the bearings (2 of them) and the seal are faulty. Replace them as soon as possible.
May 27, 2010 | Frigidaire FTF530FS Front Load Washer
W6021 will not heat water, but will continue to wash a complete cycle. It does take over 3 hours to complete one cycle. I have changed the temperature select module.
Sounds like heating element, should read around 30 ohms on multimeter if okay, if faulty will take forever to do wash...Good luck
Sep 29, 2009 | Asko W6021 Front Load Washer
The washer takes forever to complete it will take
front load washsher do take longer to wash than top load but it should not take 2 hours on a short cycle. has it always done this
Jun 23, 2009 | LG WM-2277HW Front Load Washer
How long should a normal wash cycle take on the whirlpool duet?
One hour and 10 minutes is normal for your washer. All front load washers take a long time. They wash a lot better than top loaders. So to answer your question.. yes its normal.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Takes 3 hours to wash a load of clothes
make sure you are using soap the is for front loading machines. (he)
Aug 01, 2008 | Frigidaire GLTF1670A Front Load Washer
Wash cycles far too long!
you may have the hot and cold hoses connected wrong way round. water flow from hot is often very slow hence the extended times. to check, put on rinse which should let cold water in. see if it is in fact hot water coming in and this confirms hoses wrong way round. just interchange them. smell could be due to using liquid detergent. change to powder type
Jul 05, 2007 | Electrolux EW1200i Front Load Washer /...
KitchenAid KAWS750L Top Load Washer Logo
351 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
