Question about Refrigerators
Refrigirator is about 4 years old.It is making a loud and high pitch noise from the fan behind and above the ice maker. It is like the fan is blowing against the register and crating an organ like sound;not always and varying in pitch. Any ideas?
  • tgoyarts Sep 04, 2009
    I will try yor suggestion and let you know about the outcome
    Top Expert:
  • Refrigerators Master
  • 80,288 Answers
Clean everthing around the fan, if the noise persists replace the fan motor the bearings may be bad and causing the noise.
Posted on Sep 04, 2009
I get a loud grinding noise from my ice maker. What can make that noise?
Thank you for your information you provided, could the noise be described as a clicking or ticking noise? The reason I ask is I have heard for this to be a motor driven harvest and the heating within the ice maker is not engaging to release the ice, so the unit continues to push the ice out causing the gear to jump a tooth. If this is the case the only fix is replacing the ice maker to fix the issue. Other possible cause of grinding is the water in not entering the ice maker (hollow ice cubes) so the water is accumulating around the fan motor and freezing up. As the fan turns on the grinding is the fan motor cutting away at the ice. Gain access to the fan motor and check for ice around the fan, if its there remove that ice. The cause is that the water is not getting into the ice maker and causing this issue. Good Luck, I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 30, 2014 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
Loud noise, not ice maker
There are two large motors in those. 1 is the fan and the other is the compressor. There is nothing that you can do about the compressor but the fan can get noisy if there is an ice build up from the coils not defrosting right.
Dec 30, 2013 | KitchenAid KBRP20EMSS Bottom Freezer...
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
Kenmore refrigerator making high pitch noise top front
could be the ice maker or the evaporator fan motor.you can try lifting the arm up on the ice maker and see if it stops,this will shut off the ice maker.also when you open the freezer door to lift the arm on the ice maker the evap fan motor should start when you open the door,you should hear it blowing around,is this the noise you hear?these are the two things i can think of that could make a noise up top,if not it could be the compressor or the condenser fan motor but these are down the bottom back of machine but still could be the problem,if the ice maker and evap fan motor both in the freezer are ok pull out the machine and remove the bottom back panel and check to see if the noise is coming from there where the condenser fan motor and compressor are,you're going to have to do some detective work to find the noise,hope this helps you out.
Aug 19, 2012 | Refrigerators
My Hotpoint makes a high pitched humming noise all the time.
This noise is most likely coming from the evaporator fan motor that is located behind the panel just below the ice maker. There is an air duct that the fan blows through to cool the ice maker that is why the sound is heard in the ice maker area more.
The noise does not hurt anything but the motor can be replaced if it gets too annoying, it is a fairly common complaint. The part number for the motor is WR60X10185 and runs about $60.00. It is a bit challenging to get to but can be done with a bit of patience by removing everything in the freezer and taking the back panel off the inside of the freezer.
Apr 18, 2010 | Hotpoint HSS25GFP Side by Side...
Refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Nov 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
U-line model ulr-60b
hi,
periodical clean can smooth the operation of your ice maker.
at this link you can have the ice maker cleaning guidelines:
http://lib.store.yahoo.net/lib/usappliance/echelon-icemaker-manual.pdf
Sep 09, 2008 | U-Line Refrigerator Ice Maker
GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE refrig model PSH23SGPABS
The main board needs to be replaced.
May 05, 2008 | GE Refrigerators
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
