Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso GVW9959KKL2 sometimes doesnt turn on and sometimes has a code of LS which I just read is a lid switch..we cleared this code but it sometimes still appears and will not turn on?
    President:
  • 1,776 Answers
The lid switch is most likely defective and will have to be replaced. It can be tested using a multimeter or ohmmeter. Check out the video at the link I am providing and see if it helps you out with your problem. Sure hope so and best wishes.
http://www.youtube.com/watch?v=fC8SY3cU1Yc&feature=PlayList&p=A8EAB62928245279&playnext=1&playnext_from=PL&index=61
Posted on Sep 04, 2009
My calypso GVW9959KQ2 displays L5
its probably LS not L5 code,which is a lid switch failure and this will result in a machine that will fill and possibly agitate,but wont spin out.replace lid safety switch located underneath top of units outer case
Aug 01, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Hello, When trying to wash we are getting a LS code in the time slot. Not sure how to reset or what that code means.
LS is the error code for Lid Switch not detecting closure. The switch is located under the top of the machine on the right side. It is triggered by the lever attached to the pivot point of the lid. The lever might be missing the contact point of the switch or the switch might be broken.
Google Calypso Washer Service Manual and you sould be able to find a pdf download. It is most helpful and gives error codes and tells how to get into the machine.
May 12, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso has unbalanced "L5" message
LS is a "Lid Switch Error"
The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display. If opening the lid or pressing STOP/CANCEL does not clear it, unplug your washer for 5 minutes.
Here is a link to a PDF manual for it also.
Calypso Manual
Nov 21, 2010 | Kenmore Washing Machines
What does LS on the display and dont end the cycle?
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 09, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What is L5 mean
Hi dear.That should be LS Code instead of L5.Please check the followings.I hope that helps.Thanks.
LS
Lid Switch Error
Sep 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
MY WHIRLPOOL WASHER WILL NOT WORK STATUS WASH CODE LS
lid switch error,thecontrolshould flash this error code if it cannot detect the lid switch opening and closing properly.this error code may also be used if there is a disagreement between the motor and machine controllers on the stat of the lid switch.the control should not allow the unit to run in this condition.
Jan 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
L5 show in display and won't work in calypso washer
ss13679,
I believe your code is actually 'LS'. This codes shows up when the controller cannot detect the lid switch opening and closing properly. This error code may also be used if there is a diagreement between the motor and machine controllers on the state of the lid switch. The control should not allow the unit to run in this condition. This code will also appear if you press the start key while the lid is open. Open the lid or press STOP/CANCEL to clear the display.
Your lid switch may be bad. Click here for some help. Also it looks lik this: click here
Hope this helps. Please give me a vote!
-samson39
Jul 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
L5 flashing on my calypso washer
The error code is actually a LS not L5, it stands for a lid switch error, it could be a bad lid switch or you may have forgotten you had a previous load in and went to rewash and went and started the machine without opening the lid which automatically throws an LS error.so check the lid switch .hope helps p-ls appreciate by rating as fixyaa
Feb 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
L S or L5 error code on Calypso top load washer (Color - grey)
LS Lid Switch Error The control should flash this error code if it cannot detect the lid switch opening and closing properly. This error code may also be used if there is a disagreement between the motor and machine controllers on the stat if the lid switch. The control should not allow the unit to run in this condition.
Dec 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso washer
Code LS=Lid Switch. I had the same problem and found that if you pressed down firmly on the lid when closing I would not get the LS code. An uneven load will sometimes cause enough vibration to the lid to stop the washer and display the LS code again. Just lift lid and press down firmly again and start. Eventually I will open it up and adjust the switch.
Mar 08, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
80 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
