Question about Epson 1000 ICS All-In-One InkJet Printer
Everything I print is underlined
Eveything I print is underlined. This just started happening for no reason about a month ago. I have checked printer settings, alignment, cleaned the nozzles, and heads etc. (though you can tell it is NOT stray ink or anything) It is ask if "something" is telling the printer to underline everything. I have searched manuals and online support and cannot find the help I need to make these lines go away. I reset my computer to before it started and it fixed the problem for a day then it went right back to underlining. I tried another restore to that earlier date and it did not fix the problem. I am pulling my hair out! Any suggestion????????
HELP! :)
  • Epson Master
  • 1,879 Answers
To determine if it is the printer, try these :
>windows test page (printers & faxes, printer's properties page)
>self-test ;
Please perform the following steps to ensure your printer is physically functioning.
1) Disconnect the printer cable that is connecting printer to the computer, by unclipping or unplugging it from the back of the printer.
2) Turn the printer ON by holding down the POWER button for about 3 seconds.
3) Load A4 or LETTER size paper in the sheet feeder on the back of the printer.
4) Press the MENU button on the control panel until NOZZLE CHECK appears. Press the COPY button.
5) The printer will print a pattern displaying a number and a nozzle pattern with black & color. Examine the nozzle check pattern that has printed. Each staggered horizontal line and straight vertical line should be complete.
Posted on Jan 23, 2008
Canon MX860 prints crooked!
Does this happen when printing from the cassette (bottom tray), or the sheet feeder in the back, or both? Check that the paper guides are set snugly (touching but not buckling the paper) against the edges of the paper.
Apr 29, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Prints purple instead of black on photos only
My Canon printer has TWO slots for black ink cartridges. I assumed one was extra and didn't replace it when I ran out. Text printed just fine with only one installed, but my photos were printing with purple instead of black. I looked into it, and the two cartridges are different: one holds dye-based ink, the other has pigment based. Photos must require both kinds. If your printer is the same as mine, use both!
Jul 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
HP 4180 will not print properly or scan
check the all the catridge filled or properly installed and uninstall the printer driver and then reinstall the driver again and after installing check
Jun 02, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Ricoh CL3500N - not printing all characters on the page
It might be a print driver problem. I think there several different drivers. Go to Ricoh-usa.com and download all the drivers for the operating system you are using and try them. If there is a rpcs driver that might be your best bet.
Apr 24, 2009 | Ricoh Aficio CL3500N Laser Printer
Epson 2400 printer prints dark and with slight colour cast
try these :
1. nozzle check
2. image set to RGB color (Photoshop)
3. check driver settings
4. try another file
5. try another application
6. ¨supported / recommended¨ epson paper & inks
7. another computer (to pin down where issue is happening)
8. all else fails - the printer needs service (better check your warranty status)
Jan 03, 2008 | Epson Stylus Photo R2400 InkJet Printer
Missing print
Check the paper size within the menu as sometimes causes this fault.
Thanks J
Dec 19, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Computer doesn't print color
Hi, the problem seems with the logic board inside the printer, are you in a position to open the printer and try some stunts, that is only if you have done it earlier.. let me know??
Dec 17, 2007 | HP PSC 750 All-In-One InkJet Printer
Printing problem
Try to clean the light sensor inside the printer, you will see a white led on the top part of the case, match it to the bottom you will see a small hole on a plastic peice, that is the hole for the sensor.
Oct 29, 2007 | Zebra P210i Thermal Printer
Printing
Placing one sheet at atime is worse usually as these units feed off a minimum level. Keep them topped up to at least no less than 10 sheets. The printers sound like the have a paper feeding issue. Could be a jam. Open unit, check for paper jam. Cheers lilacgerry xxx
Sep 13, 2007 | Canon PIXMA MP180 All-In-One InkJet...
Dell 3100CN Error Message
I am a publisher here in Seattle printing full color books with this machine and I have just gotten the same message- Does anyone have a solution- I have Googled and checked everything... Now, this happened to me a few months ago and I pulled out the drum and sprayed it with air, replaced it and it worked fine for about two months- now I get the error again- does this help in the problem solving?
Jul 01, 2006 | Dell 3100cn Laser Printer
Epson 1000 ICS All-In-One InkJet Printer Logo
74 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
