Question about Kenmore Washing Machines
The drum drive pully is loose. How tight should
The drum drive pully is loose. How tight should it be?
  • yadayada
    yadayada May 11, 2010
    u mean the belt?
  • 15,935 Answers
The blet should have 1/4" deflection (approximately) over the longest length.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
Replace the drive belt
Remove the back
hook it on the motor pully and start to wrap it around the drum pully until it is to tight to continue then turn the drum pully to finish the job
Sep 27, 2014 | Bosch Washing Machines
Belt has come off from drive pully to drum wheel. when trying to refit, belt runs off drive pully when i turn drum wheel by hand. machine not that old and belt in good condition (checked it against new...
I always recommend the purchase of a new belt anyway- but you appear to have one!
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 07, 2011 | Washing Machines
I replaced belt on my 97 Suburban but the tention pulley did not click. But the belt feels tight. The pully moves back and forth. Is it safe to drive without me hearing the click sound.
yeah it'll be ok for you to drive it as long as its not sloppy loose or super tight you'll be ok. but if you still have doubts replace your tensioner pulley
Jul 28, 2010 | 1997 Chevrolet Suburban
Hotpoint drive belt
un plug appliance, remove lid and back plate, place belt on motor and carefully on drum pully, turn pully to pull belt onto its, its quite tight to do but is possible, watch out for trapping your fingers.
Apr 07, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
I have front loading washing machine and I need to put the belt on. I can use some tips, ideas on how to get it on
MAKE SURE THE POWER TO THE MACHINE IS OFF , THEN MAKE SURE YOU HAVE THE RIGHT BELT, FIRST YOU NEED A RACHET SET THEN LOCATE THE BOLTS AT THE SIDES AND UNDER THE TOP COVER AT THE BACK REMOVE ALL BOLTS AND THEN THE BACK PANEL, YOU SHOULD SEE THE BELT AROUND THE DRUM PULLY AT THE BOTTOM OF BELT YOU SHOULD SEE THE DRIVE MOTOR LOOK FOR A TENSIONER IF ONE TURN UNTILL BELT IS LOOSE REPLACE NEW BELT AND MAKE SURE IT VIS TIGHT , GOOD LUCK .
Nov 22, 2009 | Cars & Trucks
Belt won't stay on the pulley
These belts are really sensitive. Try messing around with it. Making srue that the belt isnt coming off the big tub pully. You tub pully isnt loose is it. Make sure the bolt that hold the pully onto the tub is tight on. Make sure the pully isnt loose. Inspect it for any small craks where that boltt tightens up. If the pully check out ok. Check the small motor pully as well. Make sure that isnt loose or anything. Pull on it if if its loose then thats you problem.. Inspect both pullys good. I would assume belt is in good shape right? If both pullys check out ok, then i would try to get the belt on and just mess around with it, spin the pully and if you se the belt starting to slip off adjust it as you keep spinning the pully....hope this helps
Jul 31, 2009 | Maytag Neptune Washer
How to put a belt on
remove lid and bottom cover 2expose moter pully lean washer towards u pass belt down and put over motor pully then start putting on drum pully can b very tight good luck
May 03, 2009 | Washing Machines
Hotpoint wf240 replacment of belt, i cant get it on.
Hi, put the belt on the bottom pully and feed the rest up to the top pully, fit the belt on to half of the top pully, now open the door of the washer and very carefuly turn the drum while holding the belt tight to the pully, take care not to get your fingers trapped, make sure that the belt stays on both pullys by rotating the drum by hand a few times, if it all looks ok and central then the jobs a good un.
Mar 03, 2009 | Hotpoint Aquarius WF000 Front Load Washer
WASHING MACHINE DRUM WILL NOT TURN
There is no adjustment provided for lining up the pulleys.
If it comes off then there are a couple of reasons that come to mind,the belt is too slack, the belt is worn,the drum is out of alignment with the motor pulley, caused by worn drum bearings, the motor is loose, a loose drum pulley, or you are not lining the belt up properly, overloading can also throw the belt off.
Hope this helps.
Plz leave feedback.
Ta.
Dec 09, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius drive belt wont go on
hook the belt around the motor spindle first then get the belt as far round the pully as you can once at that stage hold the belt firmly as you can on the pully and turn the pully round making sure that the belt does not slip off keep turning the puully round till the belt is fully on once on spin the drum around by hand to make sure that it is on the pully square with motor spindle. job done. if this helped please leave feed back.
Feb 23, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
