Question about Whirlpool Washing Machines
How do you get the back off of an old Whirlpool washing machine? My washer won't spin so I think it needs a belt but I can't even look because I can't get the back off of the machine. I also can't find the model number. It only says Whirlpool and Heavy Duty.
  • 612 Answers
The back does not come off. You lift the case off of these. The model number should be either on the back of control panel or lift the lid and look around the inside lip of the opening. To get inside the machine:
There is a screw on each end of the control panel. Pull the panel forward while lifting and it will pivot back out of the way. Then there is a clip on each back corner, un-clip them and unplug the wire in the middle. Grab the inside of the opening on each side and lift up and forward. This takes the case off. This machine has no belts. It's a direct drive, meaning it has a coupler. Look behind the motor and there will be a black rubber piece. This is part of the coupler. To get it off, un-clip the pump, take screws out of the clips on the motor. Then un-clip the motor. The piece attached to the motor is the coupling. There is another piece still attached to the transmission. Replace the coupler and it will fix the problem.
Please rate this solution
Posted on Sep 04, 2009
It won't spin out everytime and unlocks by self while running
I have a similar model HE doing the same thing. I just had a friend to look at it and when he pulled out the machine there was nut on the floor that apparently belonged to the screw that was holding the pulley in place for the belt. The belt was totally off. He put the belt back on, but it is still not spinning. So I think you shoukd check that. I've only had my washer for 1 year and 3 months.
Apr 19, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whirlpool wfs1072Aw 7.5kg washer that has stopped spinning and won't start even the wash cycle
You probably have either a bad gearcase, timer, or lid switch. Defective motor is also possible.
May 08, 2012 | Whirlpool Washing Machines
WASHER DOES NOT DO FINAL DRAIN AND SPIN. USUALLY GIVES YOU THE F2 WARNING. WAS TOLD TO CHECK OHMS. HAD 17.2 OHMS WITH METER SET ON 200. TODAY IT SAID SUD ON LED PANEL. COULD PUMP MOTOR SOMETIMES WORK AND...
Hello.
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work
down to the more difficult causes.
BELOW ARE TOOLS AND INSTRUCTION THAT WILL HELP IN SOLVING THE PROBLEM.
1 A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Thanks.
Nov 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't spin
Hi
One of the most common problems with washing machines, however, is that they won't spin. Usually this is caused by an issue that easily can be fixed, but other times it can be more serious. In some cases, just the balance of the load can cause the machine not to spin.
First open the lid and reposition the clothes. Close the lid and retry. The washer may not spin at all if the tub is unbalanced.
Examine the lid switch for wear. Replace a worn lid switch by first using a screwdriver to remove the top of the machine. Remove the cabinet holding the old switch in place by unscrewing the two console screws, tilting the console back, removing cabinet clips, and unlocking the lid switch block. Unscrew the mounting screws, and disconnect the ground wires before removing the old switch. Insert the new switch in it's place.
Look for excessive glazing or cracks on the sides of the belt. If these signs appear, remove the old belt by tipping the washing machine over on it's side, and unscrew the clamps securing the pump coupling with a screwdriver. Place the new belt over the transmission pulley, and then over the motor pulley's nearest edge, slowly turning the motor pulley to pull the belt around and into the pulley.
Replace the washer's motor by firmly grasping on the metal slip-on connectors holding the wires in place, allowing you to pull the connectors apart. Use a screwdriver to unscrew all of the screws holding the motor in place, and remove the old motor. Insert the new motor in its place. Secure the new motor to the machine with screws, and reconnect the motor's wiring harness.
Replace the washer's pump by removing the service panel on the back of the machine with a screwdriver and disconnecting the washing machine drain line and the rubber pump outlet hose. Remove the fasteners holding the pump to the bottom of the machine, along with the drive belt from the pulley below the pump. Replace the old pump with a new one, and reinstall the drive belt back on the pulley, reinsert the fasteners and reconnect the rubber pump inlet and discharge lines.
Also check this link to get a detailed idea related to your issue:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntspin
Please get back to us if you have further query or else please accept the solution.
Sep 03, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer don't spin or drain the water
welcome to Fixya.
There are several reasons why a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Find some possible cause and how to solve the problem:
Good luck.
Apr 08, 2011 | Whirlpool Washing Machines
Washer stopeed spinning
if machine spins while washing, transmission is good. if it does not turn at all, could be control panel .need more details
Aug 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
