I cannot get my speakers to work. In the control, panel under sounds and devices, under volume, it states "no audio device". What does this mean? I have the speaker plugged into the back of the computer.
  • lynn30646 Sep 04, 2009
    I did not install any drivers. This is the way my computer came to me. I purchased a used business Dell refurbished computer. Should I still uninstall all audio devices?
  • 596 Answers
If you have not done so uninstall any drivers you may have installed on your computer. (Control Panel>System>Device Manager: look at the audio part and uninstall anything there.)
Once done, reboot your system and take note when your os open, do you see a popup saying new hardware found. If so, chose to install this device and use the online search for the correct drivers. Again, when the drivers finish installing, you will need to reboot your pc.
Most of the time when I encounter this problem, it's usually the drivers have been disabled, corrupt, or missing. Reinstalling them usually solve the issue. Post your results and we will go from there.
Good Luck,
C2Solutions
Posted on Sep 04, 2009
  • Nouveau IT, LLC
    Nouveau IT, LLC Sep 04, 2009
    Lynn30646,
    Yes, go ahead and uninstall all drviers, this will enable the pc to locate and download the corrrect drivers needed to make the speakers function. To many drivers will confuse your pc which is correct and it will diable that source until corrected.
    C2Solutions
I have the Pulse 424 speakers and they are like 8 years old. The speaker with the power and volume knob is out. It works to turn on speakers and control volume but no sound. The woofer and the other...
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 31, 2011 | Labtec Pulse 424 Computer Speakers
No audio output device is installed
Not knowing what type of motherboard you have, it could be one of the following:
1. No audio chipset installed
2. No drivers were loaded
3. drivers are corrupted
If running Windows XP go under "Control Panel","System","Hardware","Device Manager" and
check under Sound ( click on + ) to see what is installed..
Feb 06, 2011 | Computers & Internet
No sound not working everything is plugged in
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
Feb 01, 2011 | Dell AX210 2 Speakers
My speakers dont work
also
hope this helps
Jan 31, 2011 | JBL CREATURE II Computer Speakers
Thera are no sound divice
also
you might have to get a portable usb sound card if you mean dont have a sound card installed
hope this helps
Jan 31, 2011 | Compaq Audio card Sound Card
Sound is not working
also
hope this helps
Jan 31, 2011 | Computers & Internet
Stopped working
also
hope this helps
Jan 30, 2011 | Logitech X-540 Computer Speakers
My speakers stopped working. How can i fix them?
virus run your antivrus program
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
also
hope this helps
Jan 30, 2011 | Gateway Edison Computer Speakers
My speaker is not working with my computer
also you if this does not fix the problem
hope this helps
Jan 27, 2011 | MidiLand MLi SW190 Computer Speakers
It says my audio device is disabled.
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 26, 2011 | Toshiba (4CH-VOUT) Sound Card
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
