Question about Hunter Fan Company 5/1/1 Programmable Thermostat
Need a wiring diagram for thermostat/hunter model44260
I need wiring diagram for Hunter thermostat model44260
  • slmndaniel3 Sep 04, 2009
    the product say easy installation,,
    Problem Solver:
  • 19 Answers
Hello please try this link and see if this contains the information that you need
Reply to bsix@hotmail one way or the other Thanks
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/42711.pdf
Posted on Sep 14, 2009
Unable to get ac compressor to start
HI,
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
Goodluck,
Please don't forget to rate the solution
Apr 23, 2008 | Hunter Fan Company 5/1/1 Programmable...
I need to find an owners manual/wiring diagram for a Hunter model 44250A programmable thermostat.
Hope, you can get it from:
personafile.com/Hunter-Fan-Company-Thermostat-44250A-P0496942301829.htm
Dec 29, 2010 | Heating & Cooling
Replacing 2 honeywell thermostats with Hunter.
The hunter uses batteries and a ram chip to "remember" how you set it, the common is not needed with the Hunter. Some thermostats used the 24 volts of the thermostat circuit for powering up displays or for internal functions such as relays etc. Modern stats consume such a small amount of juice it is not typically required these days.
Aug 21, 2009 | Hunter Fan Company 5/1/1 Programmable...
Changing a White-Rodgers 1F56-444 to a Hunter 44155c digital.
The W- terminal is for the HEAT RELAY.
Connect the brown and white wire to the WB terminal which is heat relay of the Hunter thermostat.
Aug 09, 2009 | Hunter Fan Company 5/1/1 Programmable...
THERMOSTAT INSTALLATION
I am trying change from a Honeywell ct701A1001 to Hunter 44110 the old one has 7 wire and new one 5wires
Nov 01, 2008 | Hunter Fan Company 5/1/1 Programmable...
Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Jun 17, 2008 | Coleman Mach III Air Conditioner
Need help !!
have you tried there web site for the wireing instructions or manual to installing it.
riz.
Feb 17, 2008 | Hunter Fan Company 5/1/1 Programmable...
How to wire hunter 44155
Go to the hunter web site. They will have the proper wiring diagrams on the site. If you cannot do that pick up a basic wiring book at your local electric parts supplier. the place you got the thermostat would be a good start. I do know that menards has some books in the electric area that would be a great help to you. You also will need to be sure that the thermostat is able to handle both air and heat. many only do heat. If this does not help let me know and I will try and get more information to you
Feb 07, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
Jan 12, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
2,786 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
