Question about HP Computers & Internet
Hello, I have HP iPAQ hx2000. It was present from my cousin. she bought it in London. It was working properly befor. After about year she gave it to me. But by all the year it was shut down. I live in Polan and my iPAQ is not charging. What schould I do?
    Problem Solver:
  • 11 Answers
Sounds like she fried the power adapter, i know in the US 115volts on a normal wall oulet, outside of the US its 250/225?volts
get a new adapter, if your pc still works that is....
Posted on Sep 04, 2009
Unlock code hp hx2795b
If you mean the hdd or system is locked, contact the manufacturer with the code and they may be able to help.
Oct 29, 2016 | HP Computers & Internet
I have a fairly new HP iPAQ RX3115. I bought the charger today which also came with a USB cable to plug my iPAQ into my computer. When I connected my iPAQ with the USB charger, and plugged it in the...
2005 new, 12 years old, is new? really, and is no longer supported by HP, after 10 years.
my guess is the battery is toast,
never seen any battery last 12 years, ever.
not by a mile.
this thing has no value now.
if its LOVED, (why) then buy 2 and learn to fix them.
be like only on earth wanting to...
why not get a tablet.? modern.
here is all there is. RTM and get a new battery first.
http://support.hp.com/us-en/product/HP-iPAQ-rx3000-Mobile-Media-Companion-series/437953/model/437919/manuals
r
Mar 02, 2017 | HP iPAQ RX3115 Pocket PC
I am considering buying a HP IPAQ aviation 5910 GPS glass cockpit. Are they a good product? Where can I get info on them?
i would not buy another ipaq if someone gave me the money..the last two i bought (600.00 ea) both took a **** right after the warranty ran out....
HP did nothing to help even though it was within a day (how lucky i am) of expiring.
Aug 17, 2010 | HP iPAQ RX5915 Travel Companion GPS...
HP PDA h1940
I just found the most protracted set of instructions to reset it for reference.
1. charge on ac only = 8 hrs
2. remove battey, soft reset, reinsert battery
3. charge on ac only = 30 minutes, remove battery, remove power, hard reset then soft reset.
4. charge on ac only = 4 hrs
5. Power off. Soft reset.
Oct 13, 2008 | HP iPAQ H1940 Pocket PC
HP ipaq 6315 No power
Hello i'd be happy to help :-). Since you said that you bought a new battery and it still didn't work. I am guessing that you might have charged you Ipaq by pulling it into a regular wall outlet . This is bad because that outlet could send to much electricity into the Ipaq and can kill it. That might be the problem why your Ipaq is not working... I would recommend for you to call HP and see if you can return your Ipaq to them and see if they can send you a new one.
Jun 18, 2008 | HP iPAQ H2210 Pocket PC
HP ipaq hx 2000 pocket PC
It could be, or it could be something to do with configuration. I researched this earlier, and this CF card problem is something that has come up for several years now, on several different devices, but usually with the Windows OS 2003 or later. Here's a basic summary of the recommendations I found :
- Soft reset the device, using the reset button (on the hx2000 series, that's recessed on the left side of the bottom of the device, and you can press it with the stylus). This sometimes solves the problem, but you will often find that it recurs afterwards. It's more of a short term fix than a permanent one.
- Back up the CF card's data, then reformat it and make sure that it is FAT32. This is the most universally recognized file format and has the least problems.
- If this doesn't work, then a last resort option would be to try backing up your device's software and performing a hard reset to return the device to its factory defaults. Make sure you have everything you want backed up before you do this, though, as it will lose all programs and files that you don't have stored. To perform a hard reset on the hx2000 series :
1. Press and hold down the Calendar and iTask buttons.
2. While holding the buttons, press the stylus against the soft reset button and hold it there for about seconds.
3. Once the screen begins to fade, first release the Calendar and iTask buttons, then release the stylus from the reset button. (If you hold all three for more than two seconds, the device will disconnect itself from the battery and power off - apparently if this happens you can simply push the reset button again, or you can plug it into an AC adapter.)
The device should now begin to restart. After this, you need to select to restore the factory settings. Go to Start --> Programs --> File Explorer --> My Device, then open the iPaq File Store. In there, select all files, and then delete them.
If this doesn't work after restoring it to the factory defaults, then I think you may well be stuck with a faulty flash slot. However, let's hope it doesn't come to that - good luck with resolving this problem!
May 11, 2008 | Computers & Internet
I recently purchased 2nd hand a HP ipaq hx2000 pocket PC. It all appears to function ok apart from it will not recognise any compact flash card when I insert it into the slot. I have tried several CF...
Have you tried using an SD card? The hx2000 is supposed to support SD cards and CompactFlash Type II memory cards. If it doesn't respond, it's possible that your second-hand device simply has a faulty card slot.
May 10, 2008 | Computers & Internet
Unwanted soft reboot
Thanks everyone for looking at this problem, but I think I have fixed it. I had purchased an after market battery pack for the h5455 and the pins were not aligning up properly. The pda was coming on, but when it got banged around a little it must have caused it to reboot. I just bought a HP battery pack and all is well. Thanks again.
Bobc2
Feb 29, 2008 | HP iPAQ H5455 Pocket PC
HP IPAQ hx2000
ipaq cannot detect the keyboard
Oct 23, 2007 | HP FA118AABA - HP Compaq iPAQ Foldable...
Computers & Internet Logo
54 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
