When knob is pushed in, it doesn't stay in. have to HOLD knob in to move turn it.
  • 612 Answers
Check your door switch. If it's working, you will need a new on switch.
Please rate solution
Posted on Sep 05, 2009
Is there a trick to starting the Pyrox 400? Turned the fan on and press on low then repeatedly press the ignition pilot light, start to smell of gas after a minute. Won't start Help please
Is the ignition sparking? When you press and hold down the buttons, the ignition should be sparking at the centre electrode. At the same time when you hold the buttons down, the gas valve is manually held open to release the gas. The spark is then supposed to ignite the gas. Hold the knobs down for about 3 to 5 seconds after ignition and the gas valve will stay on. If it lights but the flame wont stay on, it could be anything from a partially blocked aeration port to a worn knob. When you push down on the knob, it is supposed to press down on an electromagnetic lock which keeps the gas valve open when the flame is burning. When the knob or shaft isn't pushing down enough, it doesn't keep the gas valve locked and the flame will go out as soon as you let the knob go.
Apr 19, 2015 | Heating & Cooling
How to light pilot on Dayton furnace and then start furnace
If this is a standing pilot system, turn the gas valve to pilot position. push in the knob & hold while lighting pilot...keeping holding knob down for a minute... this will pick & hold the gas valve. Let go of the knob & see if the pilot stays lit, if it does, then turn the knob to on position & the furnace should start if there is a call for heat from the thermostat
Sep 15, 2011 | Dayton Gas Furnace Heater
Pilot light has gone out we have no hot water how do we relight it the auto relight isnt working either
Hello, Thank You for using FixYa. I will be helping you today.Set the knob to pilot and push in on the knob and hold it in then push the ignitor button while still holding in the knob when it lights keep holding in the knob after a few seconds let go of the knob if the pilot stays on turn the setting to on.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Kitchen Ranges
How to light the pilot light on a natural gas wall heater
SEt to pilot, Push knob, push pezio ignighter until pilot lights, hold for 30 seconds. if it stays lit turn to on, if it doesn't stay lit, you have a bad thermocouple
Mar 24, 2011 | Vulcan Heating & Cooling
How do i light the pilot?
Turn the Gas Control Knob inside the heater compartment from OFF to PILOT. Push in the knob and hold it, at the sametime push the ignitor button (will probably be a Red button). Once the pilot lights, continue to hold the Control Knob down for one minute. Then ease off of it. If the pilot stays lit, turn the Control Knob to the ON position. The burner should light, if the Thermostat is set higher than the ambient temperature in the house. If the Ignitor button doesn't work, you can match light the pilot. Just be careful and follow the instructions above, once it's lit.
Hope this helps solve your problem.
Feb 23, 2011 | Williams (5009622) Ceramic Gas Wall...
I HAVE A 20+ BRYANT BOILER THE PILOT LIGHT IS OFF HOW DO I TURN IT BACK ON PLEASE HELP THANKING YOU IN ADVANCE MS I
Turn the gas valve to pilot. Push knob down & hold. While holding, light pilot & keep knob held down for one minute. Let go of knob & see if pilot stays lit. then turn knob to on position. Boiler should then turn on.
Oct 18, 2010 | Bryant Heating & Cooling
How to start a gas fire-place
Hi remove bottom cover you will see black knob with off pilot and on , turn knob to pilot push in and hold in press igntion button untill pilot lights hold knob in for 30 secs then release if pilot stays on turn to on postion if not try again ,
Mar 02, 2010 | Heating & Cooling
Re Williams 3003622 Heater Please advise how to ignite pilot light.
You will first need to turn the control knob to pilot. Then depress the control knob button and hold it. Then press the push button piezo igniter several times until pilot lights or open pilot inspection cover and manually light pilot with match/lighter. You may need to hold the control knob for at least a minute. Then release the control knob and if the pilot stays lit then turn the control knob to on. If it does not light then repeat the process again.
Oct 27, 2009 | Williams 3003622 Ceramic Wall Mounted...
My magic chef kitchen range oven won't turn on, no gas
Some of the models require you to push in the oven thermostat knob to set the pilot if it blows out. So try pushing in the knob and hold it while lighting the pilot. When the pilot lights continue to hold the knob in for about a minute. When you let go of the knob the pilot should stay lit. If it does not stay lit then try it one more time. If it continues to go out the thermocouple or aso might be bad and will need service.
Sep 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Marco gas fireplace
Turn the knob on the gas valve to pilot, push in and hold. You can push the red button to light the flame, but I always use a flame lighter of some sort, just because its faster and the spar-ker may not be working. Anyway, push the button in, and hold it after the pilot flame is on for a minute or so then let up on the button. If it stays on turn the gas knob to on and that's it.
Dec 15, 2007 | Heating & Cooling
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
