Question about GE 29267GE3 Telephone
Older ge range with cleaning lever in front will not unlock--- I've ran a complete cleaning cycle thinking that would fix. I've also unplugged it but nothing is working
  • 3 Answers
It has to cool COMPLETELY. This could take 24 hrs maybe.
Good luck with it.
Posted on Sep 05, 2009
Display on GE Convection JSP968 keeps saying LOC ON when I try to turn it on?
the self cleaning lever (that locks the door) is moved to the clean position. try moving it to clean then back to the off position and that should fix it.
Dec 11, 2011 | GE JSP57 Electric Kitchen Range
Ran the self cleaning cycle - Now it keeps posting un lock dor. Lock bar easily moved to the unlocked position after cycle completed and oven was cooled. I have unplugged the oven waited 10 minutes and...
Your switch isnt right ,check the wiring on the switch or make sure the switch is closing or opening when its suppose to,you should hear a click each time it opens or closes. your problem is in the switch area no where else,the computer on the oven needs tosee that switch input and doesnt
Feb 15, 2011 | GE Profile 30" Self-Cleaning Slide-In...
After self-clean cycle, oven will not unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option
Apr 12, 2010 | GE JDS26 Electric Kitchen Range
GE JBP79 door locked, no led readout after self clean
Hello- Control is about 250$. Could save 100$ by installing yourself, but the popular "self-destruct" cycle can cook other switches and what-not. Find a tech and inquire up-front if completed repairs are too high, they keep parts, you pay trip charge.- Hope this helps- ED
Mar 01, 2010 | GE Spectra JBP78 Electric Kitchen Range
Touch pad will not unlock after running self clean cycle,
ran the SCC and the oven door unlocked when completed but the touchpad did not. Can;t use over at all, top of stove works fine. None of the bottons for the oven works. still says self clean completed, will not go away, can't use oven at all.
Dec 14, 2009 | KitchenAid KESC307 Electric Kitchen Range
Oven door locked and will not unlock
hi friend,
step 1
Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • Step 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • Step 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • Step 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Who Can Help Sponsored hope this helps u
    please rate me.................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | Tappan TEF242 Electric Kitchen Range
    Lost instructions - I have my oven cleaning how
    Typical oven self clean cycle is 3 hours. Oven needs to cool down to under 550 degrees before door will unlock. Download a use and care manual at http://www.geappliances.com/service_and_support/literature/
    Nov 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Ge xl44 after self clean cycle the door won't open and the display says "locked door" flashing.
    Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
    or
    Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
    If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
    Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
    Sep 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    I have an older GE self-cleaning oven. It has an
    Latch may have been damaged from heat of self clean. lift top where burners are, should see cover over latch assy(turn power off to unit) remove screws for cover and should be able to free latch.
    Jun 08, 2009 | GE 30" Self-Cleaning Freestanding Electric...
    GE Hotpoint electric stove
    If you ran a self cleaning cycle and now the door won't open you may just need to wait a while. The door locks to avoid anyone from opening it as the over heats up to around 700 or more degrees to burn anything off. Sometimes what will happen however is that the heat will get to intense and cause the door lock mechanism to jamb. If the door doesn't open for you after a good few hours or so you can try unplugging the oven for a while to try and reset it. If not though you will have to go through the front panel and go down to manually unlock the door. Let me know if you have any other questions and let me know if this was helpful. Keep me updated on the outcome too if you wouldn't mind. Good luck and glad I could help.
    Jan 22, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
    GE 29267GE3 Telephone Logo
    Top GE Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Dudeman321
    Are you a GE Lands Phone Expert? Answer questions, earn points and help others
