Question about Dell Dimension 4700 PC Desktop
I think I updated BIOS from Dell incorectly. Downloaded to "C" drive,replaced old BIOS with update. Resart. Blank screen, six beeps ( four then two), power light green,hard drive spins fast & blank screen. Boot cycle "D' drive. then "A" drive. Will not recognize factory re-install cd's.
    Scholar:
  • 118 Answers
Sounds like the BIOS upgrade didn't take. Those beep codes are audible indicators that the motherboard has failed POST (Power On Self Test).
Here's is a list of the codes for your specific BIOS/PC:
http://support.dell.com/support/edocs/systems/dim4700/sm/adtshoot.htm#wp1052968
Posted on Sep 04, 2009
Short-short-short-long beeps repeated
NOT GOOD My Friend....you just blew the BIOS:
Never update BIOS unless the computer is not working all that well. When doing new Bios, the Precise BIOs for the computer are required. Any change can damage the instruction set and render the BIOs useless. Also...any interruption during the rewriting of a BIOs will mess of the Chip and blank out the instruction set. If you can, with the correct BIOS downloaded to a flash drive, you may restructure the BIOS if they can be flashed again.
Dec 11, 2013 | Lenovo Group Limited Lenovo Thinkcentre...
Tip
Dell Vostro 1000 Bios - Flash Failure
I attempted to update the BIOS on my Vostro 1000 to cure the bad battery message. My original BIOS was 2.6.1 and I intended to update to 2.6.3.
I could not flash under Windows 7 so I installed XP but the flash failed half way through.and the computer did not power up again. All that happened after I pressed the power switch was the light came on and the CD drive shuffled a couple of times. No screen illumination.
Various posts were scanned but no solution found until my buddie came up with the following sequence.
Get the file posted in this link on a computer running XP
http://hotfile.com/dl/113520903/05689ed/VOSTRO1000_CRISDISK.ZIP.html
To Create a Crisis Recovery USB you must use a Win XP system
Note: Running XP through compatibility more in Win 7 will not work
1. Insert Blank USB Drive
2. Open "CRISDISK" folder
3. Open "WINCRIS" application
4. It should detect the USB Drive
5. Click "Start" Button WINCRIS should create the USB recovery drive
6. For Crisis recover, be sure to Power drain system.
. A. Remove Battery
. B Depress power button for 10-15 sec.
7. Insert USB drive into USB port of the Dell.
8. Hold END button while plugging in power cord in system
9. Continue to hold END and depress and release the system power button.
10. Continue holding END until USB drive begins to flash and a single beep is heard.
11. System may remain blank as it enters recovery mode - Anoying Beeping will be heard - Beeping will stop and FANS will function Another series of Beeps will be heard
12. System should complete recovery in 5-10 min. If system has not powered down in 15 min, power down by pressing the power button
This worked for me and as a bonus I do not have the battery error message anymore.
on Apr 06, 2011 | Computers & Internet
Turns on blank screen with 4 beeps
This is a list of beep codes for a different Dell laptop, but the chances are they will use the same codes for each product.
4 Beeps indicate a RAM issue. Try taking it out if you are able. If you have two memory strips, alternatively remove one and leave one in, see if its just an issue with one of them.
If you only have the one, the only way to see if this is the issue is to get a replacement in. Might be worth going to your local pc shop
Beep Code indicators
One - Possible system board failure or BIOS ROM checksum failure
Two - No RAM detected
NOTE: If you installed or
replaced the memory module,
ensure that the memory module
is seated properly.
Three - Possible system board failure or Chipset error
Four - RAM read/write failure
Five - Real Time Clock failure
Six - Video card or chip failure
Seven - Processor failure
Aug 22, 2013 | Dell Inspiron 1545 Notebook
Bios update version for hp a1420n
keep the flash drive in hand. try to install xp. while install it was asking for bios update and ask for press f8 for bios update and insert pen drive and select the path it will automatically update the bios and start installing
Apr 03, 2012 | HP Pavilion a1420n PC Desktop
Laptop powers on fine , I can go into and change BIOS settings and everything is fine.. After the COMPAQ post screen the laptop wont boot from any media what so ever. It just displays a blank black...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 13, 2011 | Computers & Internet
MuWhen i turn the computer on the screen stays blank, the light on the far left hand side come on, but the screen stays blank - any solution? Thanks the computer is a Dell Inspiron 1525
clean the ram and check .. if same then u need to update the bios with programer.. u need to open laptop and remove the bios ... its all diffcult ... if any one has bios programmer ... i can send u bios updating file... u can contact me... thanks
Sep 13, 2010 | Dell Inspiron 1525 Notebook
My acer aspire one 532h-2db blank screen but the power is on. please help me! thanks.
Thank you for contacting Fixya. This is Anil.
I understand that the Netbook starts but there is not display on the screen.
It may happen due BIOS failure on the computer. Try updateing the BIOS. Updating the BIOS will require a USB flash drive to store the BIOS information on during the update. To perform the update to the BIOS:
Go http://gd.panam.acer.com/home/ and download the latest BIOS for the netbook.
Extract the files from the downloaded zipped BIOS file.
In the Dos folder, Copy Flash.Bat; Flashit.exe; Nav50.fd to the USB flash drive
Ensure that the AC adapter is plugged in.
Insert the USB flash drive into a USB port.
Press and Hold down the Fn and the Esc keys together and press the power button.
When the unit's power light comes on wait a few seconds and release the Fn and Esc keys.
After the keys have been released the power light will start to blink.
During the BIOS update process the display will be blank.
Let the unit run and after approximately 1 to 7 minutes, the unit should reboot and the BIOS will be updated.
If the unit fails to reboot, or the BIOS was not updated sucessfully, try the steps again. If the unit continues to fail to reboot, the unit may need service.
I believe the above resolution should resolve the issue, however, if the issue still persists, please contact us. We will be glad to help you.
Thank you. Have Great Day.
Regards,
Anil.B.R
Jul 30, 2010 | Acer Aspire One PC Notebook
Loud beeps at start up dell inspiron mini
Beep codes for the Inspiron Mini are as follows:
Beep Code Possible Problem
One Possible system board failure — BIOS ROM checksum failure
Two No RAM detected
NOTE: If you installed or replaced the memory module, ensure that the memory module is seated properly.
Three Possible system board failure — Chipset error
Four RAM read/write failure
Five Real Time Clock failure
Six Video card or chip failure
Seven Processor failure
Eight Display failure
Jun 10, 2010 | Dell Inspiron Mini 10 Notebook
Blank sreen after bios update
Update BIOS with Boot Block Error Code/Beep:
Definitions Error Beeps Error Code (Port 80H)
BIOS updated successfully. 2L-1S-1L F1h
The BIOS file size is not equal to the BIOS ROM size; wrong BIOS file. 1L-1S F1h
The BIOS file can't be read; it is defective. 1L-2S F2h
The model ID is mismatched; wrong BIOS file. 3S F3h
The BIOS ROM has failed to be erased. Try to flash again. 2L-1S E1h
The BIOS ROM has failed to be programmed. Try to flash again. 2L-2S E2h
No diskette, or cannot locate the BIOS file.
Try to use a new formatted diskette and copy the BIOS file again. 2S D1h
Mar 27, 2008 | Acer Aspire 1640Z Notebook
Dell Dimension 4700 PC Desktop Logo
131 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
