Question about Compaq Evo N610C Notebook
The curser wanders off sometimes to the top others to the bottom, i changed the bios setting to only use touch pad but you can still use the stick in the middle even tho i clicked only touch pad, the curser still wanders off with an exernal mouse and there is nothing been spilt on it at all, its very clean.
  • 733 Answers
If its an external mouse that uses laser for pointer location rather than the internal ball, then you might need to purchase another one. they tend to do that. Mine still does it every once in a while, but goes away when i pick it up and set it back down. good luck
Posted on Sep 05, 2009
The touchpad is locked
On some models there is a button at the top of the touchpad in the middle that toggles the touchpad on or off.
On other models you simply tap twice in the upper left hand portion of the touchpad to toggle it on or off.
And then there are some models that you use keystrokes to toggle the touchpad. Normally you would Press and Hold the ALT or FN function key near the bottom left portion of the keyboard then hit the key that toggles the touchpad. The key that toggles the touchpad will have the icon of a finger pointing at a square which represents the touchpad.
Below is what I found in your user manual on the touchpad. It looks like your touchpad is controlled by software and there is no button or keystrokes that control the toggling.
Customizing the Touch Pad and Track Stick You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel, click Printers and Other Hardware, and then click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
Below is a link to your manual
http://www.support.dell.com/support/edocs/systems/wsM70/en/ug/keyboard.htm#wp1052329
May 09, 2012 | Dell Precision M70 Notebook
This has happened several times... so hopefully you can teach me what I am doing. I am in the middle of writing an email, my hand moves.... somewhere.... and the message is deleted. Sometimes it goes to...
What e-mail program are you using?
Try placing a piece of card or a thin book or similar item over the touch pad so it cannot be touched. Then try typing an e-mail. If the problem goes away then it is definately a problem with the touch pad. If the problem remains then there is some other problem, possibly the keyboard layout cause you to press the DELETE button by mistake.
If the touch pad is the problem then try setting the touch pad sensitivity to minimum. Plugging in a USB mouse DOES NOT disable the touch pad, so this will not help you if you accidentally brush the touch pad while typing.
Feb 16, 2011 | Acer Aspire 3000 Notebook
I have an Acer Aspire 5315 Laptop computer. The curser jumps all over the place when I am typing and when you happen to look down then look up the curser with be somewhere else and you have to correct and...
This is usually caused from the touch pad just below the keyboard. The easiest fix is to turn the touch pad off when you are going to do a lot of typing.
Jan 05, 2011 | Computers & Internet
GOT A Eee PC1008HA MY TOUCHPAD WONT WORK BUT CAN MOVE CURSER IF I CONNECT A MOUSE.THANK YOU
Sometimes you can configure the sensitivity of the Mouse pad from Control Panel, Go there and look for applet MOUSE, if it is hardware issue, you can visit the website of the maker of your Laptop, and go for Support Page with Drivers, specifically issued for Mouse or Touch pad or In put. Most new Computer Systems now have Online Support which can detect the Problem of your Computer. Download the Detect Software... Once you upgraded the Drivers for the Board. let us say ASUS, the Bios will fix and update your Hardware. Just be careful sometimes, this is irreversible, meaning cannot uninstall the Drivers for BIOS, or on Board Software.
Sep 07, 2010 | ASUS Computers & Internet
Dell 1545...... How do you disable the touch pad.
If you double click on the touch pad icon in the task bar it will bring up the Dell Touchpad Settings. Then click "Device Select / Button Settings". There should be two tabs there. Make sure "Device Select" is selected, and at the bottom of this tab, there should be a check box that says "Disable Touchpad/Pointing Stick when external USB mouse is present".
If you cannot find those settings, they may also be in the BIOS. Try pressing F2 while booting and look around in the BIOS for a similar option.
Aug 15, 2010 | Dell F3534 Touchpad
My Hp Laptop's touch pad is not reponding to touch. Please help me. The curser reponds but not the touch reponse. The touch pad reaponds to scrolling but not to finger tappings. The two right and left bars...
there is a key combination that enables/disables the touch pad. it's the Fn key + the function key that shows a little mouse icon in blue at the top of your keyboard. on Fujitsu this would be Fn+F6 for instance. if this doesn't work, it is possible that the touch pad has been turned off in the BIOS setup. you will have to enter the BIOS and enable or automate the "internal pointing device"
Apr 21, 2010 | HP Pavilion dv6000z Notebook
I have an Hp Pavillion a170n System by can't
Go to Printers . Put curser over the Printer icon . Press Right button on mouse . Go to bottom of meue PROPERTIES> when open at top menue selct ports. Configure port. other approach deleat printer and reinstall new printer. during set up will ask what port. USB sometimes uses virtual printing Ports. Another aproach is if USB ..Just pull cable from computer and stick in some other USB port forcing computer to reload driver to that port.
Nov 07, 2009 | HP Pavilion a1700n PC Desktop
Acer aspire touchpad over sensitive
Your laptop should have software pre-installed for your touchpad. This should probably be in the Control Panel. Once you find the software there should be options to change the sensitivity. Hope I helped.
iSpearz.
Jan 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
How can I stop my curser from jumping around whilst typing ?
Hello
Most probably because your 'Touch Pad Mouse' is touched by your palm (hand or something) while you are typing. Avoid contact with the mouse touch pad while typing.
Option 2:
If you have a centre moveable mouse on your laptop, start using it and disable the 'Touch pad mouse'
Best of luck!
Jul 23, 2008 | Acer Aspire 5100 Notebook
Touch pad is not working
I had a similar problem which I remedied by removing and cleaning the touchpad, there was some dirt which had collected around the edges of the pad underneath the case. The only drawback is that the majority of the laptop must be disassembled to get to the touchpad.
Sep 07, 2006 | Dell Inspiron 8200 Notebook
Compaq Evo N610C Notebook Logo
81 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
