Question about Sharp Audio Players & Recorders
Protect in dispaly
Whenever i turn on my radio the word protect comes up and the radio goes off. how do i fix this?
  • medbiz Dec 20, 2007
    My system switches off and displays "Protect" when I have the CD play at a volume higher then 18.
    Any help appreciated
  • sebasrojas4 Dec 19, 2008
    i have the same problem... protect appears in my screen if i turn the volume up higher than 18
The word PROTECT displays when I plug it the unit. How do I fix it?
Posted on Feb 03, 2008
I have owned an NAD 705 Receiver for many years, and am just now having problems (probably over 20 years old). I'm getting a message on the screen of the receiver that says 'protection' .
if the receiver turns on and operates then eventually turns off due to protection mode its because a wire is shorting out the receiver.if it doesn't turn on or goes straight into protection mode then its probably time for repairs or a new receiver.
Jan 06, 2018 | NAD Audio Players & Recorders
2003 Nissan Altima radio still works but the clock/radio station display went blank...HELP
Just fixed this myself today. There is a surface mount component (resistor I believe) that has come off inside the radio. It was labelled 180 on my radio. It is on the circuit board actually inside the radio, not the dispaly button panel, on the left side behind the volume know. I soldered it back on and now the display works again.
Feb 15, 2012 | 2003 Nissan Altima
How do i fix my Power Acoustik LT-980/2 car amp, it keeps on going into protect mode.
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . .A thumbs up would be greatly appreciated if this answer is helpful to you
Aug 10, 2011 | Power Acoustik LT-980/2 Car Audio...
Radio aerial will not retract when radio is turned off , but will when I turn ignition is turned off, the last owner has put in a new radio.
The antenna wire has been wired wrongly to receive full time current whenever the vehicle is turned on. It is supposed to be wired to the remote turn-on wire from the radio, so it goes off whenever the radio is turned off.It will have to be rewired to work correctly.
Jul 12, 2011 | Kia Sedona Cars & Trucks
My stereo won't work. Whenever I try to turn it on, it always turns off saying "protect." How can I fix this?
The protect has come on because it senses an output load problem, Turn the unit off, unhook the speakers and wires from the stereo, now turn the unit on and turn the volume down as far as it will go, this should reset the processor ic, if the word protect stays off you have a short in the wiring or bad speaker. If the protect comes back on with everything unhooked the problem is in the audio output ic pack in the stereo and will require a technician to remedy.
Jan 17, 2011 | JVC MX-KC58 Shelf System
No power to radio wont even turn on
The most likely thing is what we techs call revers polarity. this means that the customer accedently hook up the power in reverse. this happens more often then not. The fix for this is to replace the 1 amp diode that goes between the negative and positive power input on the board. the Diode number is a 1N4007 or any 1amp silicone diode. You will also see that once Blown diode is cut the radio will come back on. this does not mean the radio is fixed what this means is that the shorted diode has been removed from the circuit. which also means the radio has nom protection until the diode is replaced.
Patrick Patterson N5SLI
Jun 01, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
High pitched tone comes on whenever radio is turn on
Hi,welcome to fix ya. if this is a bose system you have a bad amp behind the rear seat they short out inside and cause the speakers to emit a high pich squeel. you can buy these amps on e-bay pretty cheaply or send it to bose for repair .
Nov 30, 2008 | 1994 Acura Legend
DATA SET ERROR MESSAGE
This problem is internal and needs to be sent back to where you got it...use your warrenty.
May 07, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
"protection"
I ran across this problem before, the only solution the guy found was resetting the receiver, here''s how to do it:
Jan 30, 2006 | Samsung HT-DB390 System
310 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
