Question about Sanyo Split System Air Conditioner
Fault p10 on a ducted system is there a lift pump within the unit ?
  • Sanyo Master
  • 1,144 Answers
Http://www.sanyohvac.com/docs.php
Go to this web site and look up your exact unit. Plenty of manuals on Sanyo unit. Hope this helps.
Posted on Sep 12, 2009
Centeral heating system not heating house
To receive any assistance your question needs to be more specific regarding the type of system you have and any and all symptoms.
Feb 15, 2016 | Biasi B-6 Oil Boiler w/ Riello Burner -...
I have MAN TGS 33-360 with hard starting.It operate with no problems until it is switched off.Then have to pump lift pump in order for it to start.No fault codes
if you have to pump lift pump that indicates a loss of pressure in the system to the pump/in the pump
check for fuel leaks and faulty non return valve in the pump
take it to a service dealer or an accredited diesel shop
Jul 12, 2015 | Cars & Trucks
How to fix lg with code CH05
Fault Code 05
This fault code indicates a communication error between the indoor and outdoor units; this is usually caused
by wiring errors or condensate pumps connected to the inter-connecting cable.
The communication between the units is a fluctuating DC voltage commonly called a serial signal, it can be
easily lost if the wiring is not done correctly. If there is a communication error fault CH05 will appear within 5
mins of powering up the system.
May 08, 2012 | LG Heating & Cooling
My Miele 1374 washing machine just had a fehler f63 error. What does this mean and is it fixable?
heres your problem..
3.33 Fault code F63, water path control unit In normal operation mode the display shows Technical fault. The Check inlet LED flashes rapidly. The programme is interrupted. The drain pump is activated for 120 s. Cause Water path control system faulty. The power-programme module (ELP) cannot register a valid position of the water path control unit within approx. 80 s of it being switched on.
Note: Water intake monitoring is not active if a valid position of the water path control unit cannot be registered.
Remedy Check the water path control system. tool1.gif?leaf=true Check the water path control system circuit for an open or short circuit, and correct insulation.
Jun 05, 2011 | Miele W 4800 Front Load Washer
My HT-P10 displays "protection" and
The amplifier has a bad channel or is bad in general, and will need replacing. In some cases, it's a separate board and can be replaced itself, but in others, everything is on one board(except the power supply unit) and warrants just having he unit replaced.
Dec 04, 2010 | Samsung HT-P10 Theater System
I have an HRV system and want to know if it is possible to run a heat pump through my HRV ducts in the ceiling?
Hi, can you tell me what kind of heat recovery ventilation system you have? Is it a Honeywell, Lennox, ect.? Also tell me about how you have it set up as far as the duct work you are talking about and what kind of heat pump system you plan to install. If you tie your central air heat-pump ducts into the HRV ducts, it will interfer with the air flow. If you will, please tell me what you plan on doing as far as installing what to your home? New duct work for a new central air heat-pump unit, or what, so I will have some idea on what you are doing. Thanks so much. Contact me through my user name below.
Sincerely,
Shastalaker7
Apr 13, 2010 | Heating & Cooling
Dryer overheats, already checked venting
Does the unit shut off when it overheats? According to the wiring diagram it could be the Heater Relay or High Limit Thermostat. See the wiring diagram for instructions on error codes and how to obtain them. It is easily found on their website. Hope this helps
Nov 25, 2009 | Frigidaire FEQ1442ES Electric Dryer
Carrier Infinity with existing ducts
if the duct work is to small the unit cannot get enough air flow and will shut down on pressure faults.
Feb 04, 2009 | Heating & Cooling
C1 Fault
code CL.(C1) This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem. Calypo washers do have a history of break downs within the drive system.
Dec 08, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Sanyo  Split System Air Conditioner Logo
229 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
