Question about Dell Computers & Internet
Laptop monitor has a 2 inch black band along ride
Dell inspiron 6000-widescreen laptop monitor has a 2 inch black band along ride side instead of displaying entire screen
  • 558 Answers
You may have a bad display or a bad converter.Have you tried reinstalling the video drivers?However you may try reseating the lcd cable which is attached to the mother board or the inverter which sits just below the lcd itself,behind the lcd bazel.Remember if you are going to attempt this you must remove the battery and the ac power.
Good luck
Posted on Sep 14, 2009
It is a hardware problem. May be your screen has been faulty.pls repaired it.
Posted on Sep 12, 2009
    Problem Solver:
  • 13 Answers
Most likely the tab connectors have been damaged and you will need to replace the screen. To test the video driver connect your laptop to an external monitor. If it displays a normal screen then your laptop screen is faulty. If its the same as your laptop then you will need to replace the motherboard. You could also try pressing on the bezel to the sides of the band to see if this improves matters.
    Problem Solver:
  • 15 Answers
Either the video driver is corrupt on your comp, The monitor is broken, or your motherboard is broken
How to fix blank screen on dell laptop
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jun 09, 2012 | Dell INSPIRON 6000 CENTRINO...
Replaced inspiron 6000 screen with 6400 screen
the screen is bad just look for something to do about it.
Jul 06, 2009 | Dell Inspiron 6000 Notebook
My Inspiron 6000 screen is blank. I can get an image on a monitor through the serial port, but when on its own, the notebook screen is black. I have noticed that there is a brief flash when booting up, but...
Hi ,
1. You can check the display on external monitor>If the display is blank on external monitor also, its pretty clear that there is an issue with system board
2. If the Exernal monitor comes up fine, it will be an issue with the display of the laptop, you can cross check the issue by booting the computer to BIOS, IF you get same response on BIOS as well. Its an issue with the Display itself you can replace the display panel.
Hopefully, its covered under warranty ;)
Jun 29, 2009 | Dell Inspiron 6000 Notebook
My Dell Inspiron Laptop is having some issues with its screen. Whenever I start up the computer, it narrows itself with these black lines on either side. It kind of looks like a widescreen DVD screen,...
You might want to try altering the resolution of the display in control panel.
Some DVD's and games you used may have reset the resolution to a new setting in order to run. try 1024x768 or higher and if none of those do it try 800x600 not that many monitors use that res these days they are all much higher, but see which one comes close to the real res. there is also a facilty to "stretch" 9 without distortion.
Jun 23, 2009 | Dell Latitude D600 Notebook
Dell inspiron 6000
u need to check the same issue using another monitor or a display device if u get the same 4 screen resolution then its the video card or else the issue is with the LCD.
May 15, 2009 | Dell Inspiron 8600 Notebook
Dell inspiron 6400 screen black
you will need to have the Inverter on the screen replaced by a qualified technician
Feb 02, 2009 | Dell Inspiron 6000 Notebook
Display flashes DELL logo on power up and then goes black.
Try pressing Fn + Monitor. It sounds like you have it set to pipe video out to an external monitor.
Hope this helps.
Dec 12, 2008 | Dell Inspiron 6000 Notebook
1440 x 900 setting for monitor means I can't see my whole desktop on my toshiba laptop...
Not all laptops display adapters will allow the individual settings for a screen and a monitor to take effect correctly.
This happens especially when one is a widescreen and the other is a standard screen.
It seems your settings are taking effect on both screens at once instead of on each screen individually.
I assume you have adjusted te display sizes in your display settings ?
If so, did you adjust each display separately ?
You may also have to see if your display adapter has the most correct drivers. That may help.
Fran
Sep 15, 2008 | Acer AL1916W 19" LCD Monitor
Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Jan 03, 2008 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
867 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
