An E4 Error for your Deni means that there is a signal switch error. Turn off the pressure cooker, un-plug, and wait for it to cool. Then, try again. If it continues to give you the E4 error I would recommend contacting the manufacturer - but, unfortunately, Deni has gone out of out business.
Generally, the E4 error code means that the sensor in the pc is faulty and needs to be replaced. Contact the place where you bought it immediately (if it's still under warranty) or contact the manufacturer to ask for a replacement.
Sometimes things like that are caused by the mode switch which will either need to be cleaned or replaced. It's worth looking inside for damage inside the unit. Pay close attention to plastic parts.
A Canon MP145 E4 Error Code means that your Printer didn't detect the Ink Cartrigde. It sometimes happen when you're using a non-original cartridge or infusing it. When Canon Printer detect this abnormality, the first Canon self defense system is by Stop Printing. And then displaying some messages on your Computer Screen, indicating that your ink cartridge have to be replaced because it's EMPTY.
Below are the manual way to correct this problem :
1. Turn On Your Printer.
2. Wait Till The Printer Led Screen Show The Error Code ( E4).
3. Then Press and Hold Black & Color Button for about 5 - 10 seconds.
Hope that your problem is solved.Dont forget to give a positive feedback after pressing the accept button.
F3 - E4
Oven temperature sensor (RTD) opened (lower oven, if double oven). You will have to replace this failed sensor to restore normal operations. If your oven is a double version, it will be located in the lower part. If its a single range, it will be located in the oven compartment. The Oven Temperature Sensor has failed.
A code of E4 means that there is to much suds or the pump is blocked. use less detergent and get detergent with he in the title. turn to off and try to restart the drain to correct problem.
You will find the code in the manual. If you do not have let me know I will send you one here.
